More Issues with 2005 toyota tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 9997432, Aug 31, 2023.
  1. Aug 31, 2023 at 6:52 PM
    9997432 [OP] Member
    Kirstie
    Yuma, Arizona
    2005 Toyota tacoma 2wd 4 cylinder
    We are having new issues with our 2005 toyota tacoma. Today my boyfriend was driving home and he says the tacoma made a weird noise and died while in the middle of driving. He had to push the truck home (I wasn't with him) by himself and the truck wouldn't start up again. He said the temperature gage didn't indicate that it was overheating when it died. After he pushed it home, it wouldn't start. But, I tried it and got it to start but it was sluggish. I checked the temperature gage and it went straight to 'H' so I turned it off and let him know. We smelled something burning, and noticed that the engine oil was burning.
    He put in more coolant, but it was still overheating. We checked to see if there were any leaks/dripping under the truck, but it was dry. He has a friend looking at it right now.
    Before all of this happened, we noticed that the air conditioner was giving us warm air. He decided to add freon to see if the cold air would work again. It did, but it would go from warm air to cold air. Not sure if he put too much in. I don't know if that has anything to do with what happened today.
    I think it might be something with the thermostat. Can anyone help? Advice?
  2. Aug 31, 2023 at 6:57 PM
    EL DUDE
    EL DUDE Well-Known Member
    Any leaks?
    Coolant in oil, oil in coolant?
  3. Aug 31, 2023 at 6:57 PM
    EL DUDE
    Sounds like possible head gasket, I’ve blown several in my life
    ToyoTaco25 and TXpro4X4 like this.
  4. Aug 31, 2023 at 9:50 PM
    9997432 [OP] Member
    Kirstie
    Yuma, Arizona
    No leaks, but we just found out that the thermostat was rusted shut
    ToyoTaco25 likes this.
  5. Aug 31, 2023 at 10:01 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Ugh,I m hoping you can just replace that and it didn't blow a head gasket,preventive maintenance is a must.
    Your quick thing too turn the truck off immediately was spot on.
    O'DubhGhaill likes this.
  6. Aug 31, 2023 at 10:11 PM
    EL DUDE
    Only thing to do,
    Clean out system, replace thermostat, water pump, all hoses, pressure test the system, make sure rad is clean
    O'DubhGhaill and TXpro4X4 like this.
  7. Aug 31, 2023 at 11:39 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    I'm going to go with this possible
    Rusted thermostat is no good
    Someone adding water?
  8. Sep 1, 2023 at 1:34 AM
    EL DUDE
    Or the coolant was factory (unlikely but possible) and was broken down and allowing water condensation to build in the system
    Toyotas are forgiving, but each is different and luck varies
    mcpcartier likes this.
  9. Sep 1, 2023 at 3:22 AM
    mcpcartier
    mcpcartier Well-Known Member
    mike
    SoCal
    2012 DCSB TX PRO
    yeah...rusted thermostat does not sound good. won't be the only thing that won't be happy if that is the case.
  10. Sep 2, 2023 at 6:38 PM
    lynlan1819
    Tacoma
    Lifted
    Truck was not maintained properly and this is the outcome.
