More lift in the front!?
Discussion in 'Suspension' started by PhilipRoth, Mar 23, 2011.
  1. Mar 23, 2011 at 4:48 PM
    PhilipRoth
    PhilipRoth [OP] Well-Known Member
    Az
    06 Tacoma
    King shocks!
    Currently i have TC UCA's with Kings in the front! Its 4x4 and wish the front end could sit up higher. Is there anything i can do without cranking the shocks up? Im pretty sure i have them set at 2 in and dont want them any higher. Anything would help thanks! :confused:
  2. Mar 23, 2011 at 4:50 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    if you don't want to crank the CO's then there's nothing you can do.
    edit: you could go with a DB lift but that would be a pretty big downgrade from your current setup.
  3. Mar 23, 2011 at 4:55 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    Op you don't happen to go to asu poly....do you?
  4. Mar 23, 2011 at 4:56 PM
    PhilipRoth
    Az
    06 Tacoma
    King shocks!
    No i go to yavapai in prescott! Theres probably a few trucks exactly like mine down there haha
  5. Mar 23, 2011 at 4:57 PM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    x2
  6. Mar 23, 2011 at 4:58 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    just crank em up a wee bit thats pretty much the only way...
    or a spacer...:ohsnap:
  7. Mar 23, 2011 at 5:06 PM
    PhilipRoth
    Az
    06 Tacoma
    King shocks!
    Ha i used to have a spacer.. hated it!
    Here are some pictures of its currently set at. Could i crank them up any more without hurting anything?
  8. Mar 23, 2011 at 5:31 PM
    PhilipRoth
    Az
    06 Tacoma
    King shocks!
  9. Mar 23, 2011 at 5:37 PM
    mxnborder
    mxnborder Well-Known Member
    Santa Barbara
    05 4x4 sport - black on black on black
    DR coilovers AAl 285 kelly safaris lightbar/skidplate need more!
    What exactly happens when the CV is cranked too much? the boot rips or something?
  10. Mar 23, 2011 at 7:11 PM
    PhilipRoth
    Az
    06 Tacoma
    King shocks!
    Anyone?
  11. Mar 23, 2011 at 7:21 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    first of all it looks like your camber is WAY off in the second pic:eek:.
    second I wouldn't crank on those any more because you will start ripping CV boots which are not fun to replace.
    Definitely take it in for an alignment though unless its just the pic making it look like that.
  12. Mar 23, 2011 at 7:31 PM
    PhilipRoth
    Az
    06 Tacoma
    King shocks!
    I think its just the picture but ill check it out! the tire should be perfectly straight correct?
  13. Mar 23, 2011 at 7:47 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    yeah. did you ever get an alignment after installing the lift?
  14. Mar 23, 2011 at 7:48 PM
    PhilipRoth
    Az
    06 Tacoma
    King shocks!
    Tell me what you think. Its also parked on a downhill
  15. Mar 23, 2011 at 7:48 PM
    PhilipRoth
    Az
    06 Tacoma
    King shocks!
    Yes i did.
  16. Mar 23, 2011 at 9:17 PM
    PhilipRoth
    Az
    06 Tacoma
    King shocks!
    Thanks!
  17. Mar 24, 2011 at 6:45 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Yep.
  18. Mar 24, 2011 at 7:52 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    x2.
