more lift on top of 3" spacers
Discussion in 'Suspension' started by houndsmen, Oct 2, 2009.
  1. Oct 2, 2009 at 9:37 AM
    houndsmen
    houndsmen [OP] Well-Known Member
    I currently am runin a 3" leveling kit on my 01 tacoma double cab and was wondering if any of you have heard of adding a 1 1/2" coil lift or some kind of lift on top of the 3" to lift it more without have to change out my spindales?... can you guys give me advise on what to do?
  2. Oct 2, 2009 at 9:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Use a drop bracket lift if you need to go higher. Stacking lifts is a BAD BAD idea.
  3. Oct 2, 2009 at 9:50 AM
    98tacoma27
    Ben
    Not Beech Creek
    X2 Definitely don't stack lifts.
  4. Oct 2, 2009 at 9:51 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    How does one "stack lifts"?
  5. Oct 2, 2009 at 9:52 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You dont.
  6. Oct 2, 2009 at 9:53 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    haha how does one stack lifts? you dont
  7. Oct 2, 2009 at 9:54 AM
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    Is Camburg spindles with 4" and Bilstiens at 2" consider a stacking lift?
  8. Oct 2, 2009 at 9:54 AM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
  9. Oct 2, 2009 at 9:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No.
  10. Oct 2, 2009 at 9:59 AM
    08pretaco
    az
    no its not cause the spindles though give you lift arent associate with the springs or whatever. stacking lifts refers to doing more than one spring associated lift ie: using ome coils that give 3" then putting revtec 1.5" lift spacers. spindles have nothing to do with stacking lifts thats why im almost at the 1000 dollar mark in the bank for my camburg spindles :) im really excited
  11. Oct 2, 2009 at 10:01 AM
    tim920
    Tim
    Boston, MA
    What are the options for the rear to even it (truck's height) out if one was to install Camburgs and Bilsteins in the front?
    By the way, am I thread jacking?
  12. Oct 2, 2009 at 10:03 AM
    08pretaco
    az
    shackles and some new leafs. then get some 5125's with extended length
  13. Oct 2, 2009 at 10:05 AM
    tim920
    Tim
    Boston, MA
    What are shackles? Does this method require cutting of crossmembers like other 6" lifts?
  14. Oct 2, 2009 at 10:10 AM
    08pretaco
    az
  15. Oct 2, 2009 at 10:13 AM
    houndsmen
    i have a one inch block in the back with shackels! but i want more lift in the front so what should i do? i dont wanna go with a 5" lift!
  16. Oct 2, 2009 at 10:17 AM
    08pretaco
    az
    what do you have now in the front?
  17. Oct 2, 2009 at 11:20 AM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    just my input. I have AALs with 1'' shackle lift with the 5125. great setup. im close to 4 inches in the rear and it rides great
