More lift
Discussion in 'Suspension' started by raswank, Dec 8, 2010.
  1. Dec 8, 2010 at 8:16 AM
    raswank
    raswank [OP] Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    Already have the 5100's in at 1.75 with rear TSB. Obviously I want more, so what do i need? Going with Eibach springs, top plate spacer on the drivers side. 1.5 AAL in rear. (Axle shims if needed, diff drop if needed, carriage bearing drop kit if needed.) And rear Bilstein 5100's. Shouldn't need anything else correct. As of now shouldn't need new UCA I don't think. Any help will be greatly appreciated.
  2. Dec 8, 2010 at 9:26 AM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2006 Tacoma double-cab TRD Sport
    Homertaco grill, Light Racing UCA's, 2.8" front lift (5100's at 0.85 setting and Eibach springs) 2" AAL with rear 5100's, Wet Okole seat covers fr/ bk. 17 x 9 Incubus Crusher wheels w/ 4.5" backspacing. 30% tinted front windows.
    I think that a CB drop would be a good idea...I added one to mine and it worked great. My drive line is now totally straight. Other then that you should be good. You will probably end up with a lift exactly like mine...
  3. Dec 8, 2010 at 12:06 PM
    raswank
    Rick
    Auburn,Ma
    You don't have the diff drop installed, or shims? Any alignment issues, or vibes? Thanks for your time
  4. Dec 8, 2010 at 12:25 PM
    Fabulous
    Fabian
    Calgary, AB
    No diff drop, and none of my fins touch on the front drivetrain. I also don't have UCA's as they weren't needed...if I was any higher they would be though. I had to have a couple alignments to finally get someone who knew what they are doing, and it is great. My caster is not as high as the "prefered" one always listed here, but it feels good to me. I have 1.9/ 2.08 caster, 0.5 camber, and 0.02/ 0.03 toe. I was getting a very mild vibe at 40 mph as well as the take off shimmy that the truck has stock, so I tried the OME CB drop kit, and it got rid of the take off shimmy, and 99% of the vibe at 40...so good enough for me. Every truck is different, so what worked for me, might be different for you. Best thing is to put the stuff on, and see how it goes from there.
  5. Dec 8, 2010 at 1:49 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    You are going to have to drop the billy's back to 0.85 with the Eibach springs.
    If you don't want to spend the cash on new springs you could just set the billy's to 2.5.
  6. Dec 8, 2010 at 2:09 PM
    raswank
    Rick
    Auburn,Ma
    No i have heard of to many issues with setting the bilstein's at 2.5
  7. Dec 8, 2010 at 2:21 PM
    KPT
    09 Prerunner
    What issues in particular? Setting the billy's at 0.85 with the Eibachs (1.6") will give you ~2.5" as well.
  8. Dec 8, 2010 at 2:35 PM
    raswank
    Rick
    Auburn,Ma
    Alignment. c.v. angles. I read a lot on here.
  9. Dec 8, 2010 at 2:38 PM
    KPT
    09 Prerunner
    Alignment and CV angles depend on the amount of lift, not how you are achieving it. You'll see all the same issues with the eibachs + billy's at 0.85.
  10. Dec 8, 2010 at 2:46 PM
    Fabulous
    Fabian
    Calgary, AB
    I think that the only diff between the two would be that I've heard the 5100's at 2.5 are rougher...same lift amount though, and CV's etc will all be the same. I just went with the eibach because I wanted it a bit smoother, and I was looking for 2-2.5" max lift. I think as long as you can find a shop that knows how to do alignments correctly (not just to "spec") then you should be alright, other then maybe having to hunt down some vibe gremlins, which isn't that hard...CB drop, shims.
  11. Dec 8, 2010 at 2:57 PM
    KPT
    09 Prerunner
    Agree completely. The only difference would be a small improvement in ride quality.
    OP: I'm sure you have read that some people need to get UCA's with billy's at 2.5 to get their alignment right, and some don't. Eibachs will make no difference there.
