More Offset Questions! 18mm Offset with 18 x 9 wheels
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Shotgunwilly, Sep 27, 2017.
  1. Sep 27, 2017 at 6:18 AM
    Shotgunwilly
    Shotgunwilly [OP] Well-Known Member
    Excuse me if this has been asked as I know offset is beat to death. Anybody out there running 18mm offset on stock height or leveled? Looking at Method NV 18x9 with 18mm offset. Will either run stock height or at most level with 265/65-18 tires. Don't want to have to cut/trim anything.
  2. Sep 28, 2017 at 8:27 PM
    modifiedtaco
    modifiedtaco Well-Known Member
    Alex
    2016 Magnetic Gray Tacoma Limited
    Tuff Country 3 inch spacer kit with aal Tuff Counrty 1/4" spacer on LF (for taco lean) Bilstein 5160 rear shocks Bilstein 5100 adj front struts (removed tuff country front spacers) set to 0 lift OME 886 coil springs Front sway bar relocation bracket N-Fab Rock Rails 17x9 -12 Fuel Beast wheels Toyo AT2 285/70/17 tires Led light conversion on all interior lights Morimoto 35w HID kit 5500k OE all weather floor mats OE Tonneau cover OE Door Sill Protectors Bed Mat De badged all factory emblems matte black vinyl tailgate letter and Tacoma emblem on door silver vinyl insert on glove box and door sill protectors OME Carrier Bearing Drop Insain Fab cab mount chop plates Weathtech Rain guards
    I ran a 17x9 -12 offset on stock suspension with no mud flaps and no rubbing tire size was 265/70/17 so basically the same size as those 18's
  3. Sep 29, 2017 at 6:24 AM
    Shotgunwilly
    Good to know. I have been to a couple of shops and one says yes and one says maybe but if I order them and they don't fit it's on me.
  4. Sep 29, 2017 at 12:57 PM
    modifiedtaco
    Alex
    is there a reason you want to go with a 18mm offset? the problem people run into with a higher offset is that tires tend to come close to the upper control arm.. It shouldn't be an issue with the 265 however if you ever decided to go bigger or wider that may become an issue. Then you'll need a spacer to push the wheel further away if you went with a lower offset wheel to begin with down the road you wouldn't have this issue. Also try and see if the shop has any wheels with that size and offset already that can be test fit prior to ordering if everything checks out then you can have them order the wheels and tires you want.
