More power for going up hill with a 2.7
Discussion in '4 Cylinder' started by shovel, Jul 5, 2011.
  1. Jul 5, 2011 at 8:08 PM
    shovel
    shovel [OP] New Member
    Southern California
    Prerunner
    Bone Stock
    Are there any mods that will help? When i hit the big hills in my 2.7 I have to down shift. It was loaded with a sh*t load of camping gear and 4 adults though.
  2. Jul 6, 2011 at 6:14 AM
    ohdrj1all
    ohdrj1all Well-Known Member
    AZ
    2003 XtraCab 4x4 SR5 2.7L 5spd
    I guess I don't understand why a person would be surprised (or care) that they have to downshift when climbing a big hill... that is just normal. Many vehicles with larger engines (and automatic transmissions) do so too. It's totally normal to do so... you are asking the engine (any engine) to work harder when climbing a hill... when you do that you have to give it more gear do to maintain speed... don't worry about it... just downshift when you are supposed to. It's like complaining that you have to give it more gas when climbing a hill.
    Now if you just want more power because you want more power... that is fine... but the fact that you have to downshift climbing a big hill is not necessarily indicative of lack of power of the 2.7L I4... as I said above... that is just normal for most any engine/transmission combo.
  3. Jul 6, 2011 at 6:42 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Headers provide the best bang for your buck for the 2.7 hands down. But you'll still probably have to downshift as ohdrj1all said...unless you're going 60+ MPH up the hill.
  4. Jul 8, 2011 at 9:27 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I could not agree more. Good post.
  5. Jul 8, 2011 at 9:37 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Try riding a bike up even a slight incline and you'll be scrambling for the shifter to downshift real quick:D you don't have the torque in a 4 to pull a hill with the ease you seem to be expecting, HOWEVER that is a beautiful engine for what it is, and a hard worker too. Your truck is still 4000 lbs empty which is pretty heavy. With people and gear, I say your truck does fine.
  6. Jul 22, 2011 at 8:39 PM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    As others have said, downshift . I do it In anticipation of every oncoming hill and she climbs like a friggin koala bear up a Eucalypts tree. Nothing that an automatic transmission doesn't already do.
  7. Jul 22, 2011 at 8:41 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    lower gears
  8. Jul 28, 2011 at 8:28 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I have the 2.7L, and even myself being a big fan of the 2.7L, I knew people would complain with the power of the Double Cab, 4 cyl offered this year. If your not into speed and power, two couples or 4 adults could cruise around with no problems, but if the same two couples or adults loaded up for a weekend out of town, with personal gear for 4, that alone will begin to challange the truck's limits. Then, add toys, etc. and your probably dogging it up inclines for sure. Does this sound about right? My truck (AC Cab) empty has no issues with inclines, but loaded up with gear I am down shifting for sure... :confused:
  9. Jul 29, 2011 at 4:47 PM
    gusher
    gusher SUPERCHARGED!!!
    Greg
    Hudson NH
    08 Tacoma Double Cab 4x4 long bed, TRD Sport
    '08 Indigo Double Cab TRD Sport 4x4 Long Bed, Grillcraft grill, Pioneer AVH-P3200BT head unit, XM receiver, Boyo backup camera, Custom devil horns Toyota logo, Black headlight mod, Fog lights on anytime mod, Maglight mount, Weathertech floor liners, Debadged, Trex color-matched eyelids, Access tonneau cover, Toyota bed divider, Sno-way 7'4" snow plow, Auxiliary backup lights, Rear spring TSB, Removed front mud flaps, 2.5" Hell Bent Steel front lift, 285/70-17 Goodyear Wrangler Duratracs, Satin black MB TKO wheels, Black Go Rhino Dominator II nerf steps, custom HomeLink install, CompuStar remote starter, Redline Tuning QuickLift Elite hood struts, Toyota bed mat, Custom short Taco antenna, TRD cold air intake, TRD exhaust, TRD supercharger
    Turbo that bitch! :burnrubber:
  10. Jul 29, 2011 at 4:55 PM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    this is America, what do you expect. we want to be able to do more with less, haven't you seen the budget situation? :D
    but none the less i agree with you
  11. Jul 29, 2011 at 8:01 PM
    11Taco2.7
    11Taco2.7 Active Member
    Downshifting is easiest way if you dont do any modifications, or while you are waiting to do them. Ive noticed my 2.7 doesnt always downshift by pushing harder on the gas, and Sometimes I dont feel like waiting for it to shift. Whenever I am on the freeway if I need some quick passing power I push it over the third, or if I am going up a hill in like city streets or residential areas I pop back into second.
  12. Jul 30, 2011 at 10:19 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    As mentioned, the auto will shift itself when needed, but if your about to go up a nice incline, just switch off the overdrive prior to the incline...:cool:
  13. Jul 31, 2011 at 9:10 AM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    You could install the URD Supercharger System.
    G
  14. Jul 31, 2011 at 9:16 AM
    MartyMcfly
    MartyMcfly Time Traveler
    Rob
    Pahrump Nevada
    15' 4runner Limited 4wd
    see Build page for details.
    Does this mean they're ready to ship out?:eek:
  15. Jul 31, 2011 at 10:00 AM
    ohdrj1all
    AZ
    Touche'! :facepalm: :)
  16. Jul 31, 2011 at 10:19 AM
    joes06tacoma
    Joe
    Central Coast, CA
    From what I have heard, this is your best bet for power without killing your mileage. I'm sure it's also $$. But you'd be hard pressed to spend less money for the same power gains.
  17. Jul 31, 2011 at 10:24 AM
    joes06tacoma
    Joe
    Central Coast, CA
    This is gonna be the cheapest way to make a noticeable difference on hills, but it's gonna cost you gas mileage on the flats.
    I don't hear you complaining about speed up these hills, just that you have to downshift.
    I personally would accept it as the nature of the beast and leave it alone.
    My 09 5 lug Regular Cab 2.7 5 speed requires 3rd gear and 4400 RPM to climb a 7% grade at 70 MPH with 1,000lbs in the back. It's noisy, but the truck does not seem to mind it. It's smooth, doesn't overheat, doesn't sound like it's going to come apart. It's a 4 cyl, it has barely enough power to get the job done and that power only comes at high rpm.
  18. Jul 31, 2011 at 10:29 AM
    joes06tacoma
    Joe
    Central Coast, CA
    Since there are 4cyl double cab guys reading this, where are the pictures of your trucks? I haven't seen one yet. Thought they were supposed to be the lower suspension (5lug)?
  19. Jul 31, 2011 at 11:33 AM
    YotaMan2007
    YotaMan2007 Well-Known Member
    Brian
    where my boots and ruck lay
    07 Tacoma 2wd
    K&N Drop-in airfilter, secondary airfilter removed, Satoshi Mod, Kenwood Stereo System, Gibson catback system , Painted Steelies, Offroad Lights, Fatbob's spacer lift
    I have seen two in my city. they look like the normal 5 lug but when you look at it from the side it kinda messes with you mentally. It leaves you asking why doesn't it sit higher.
  20. Jul 31, 2011 at 11:44 AM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    i llove my 4 cycl. it doesnt have the power or torque but it does fine going uphill. with now the deck plate mod, it helps out alot.
