More power
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Natedogg320, Jul 6, 2018.
  1. Jul 7, 2018 at 8:27 PM
    #101
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
  2. Jul 7, 2018 at 8:36 PM
    #102
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    The main difference between a manifold and a header is back pressure. In a header, each cylinder gets to 'breathe out' all on its own, by its self. This is due to each cylinder having its own little exhaust pipe bolted up to it. Three individual pipes per side, 6 little pipes total. One for each cylinder. Now, all 6 pipes eventually meet up, but that's farther down the exhaust pipe and away from where other cylinders are trying to push exhaust out. On a manifold, each cylinder must 'breathe out' into the same pipe as 2 of its brothers. So 3 of your cylinders are all trying to push exhaust into the same pipe, very close together. This creates an issue of pressure. The more pressure you have effecting the ability of a cylinder to breathe out, from its brothers into the same pipe, the less effective you will be. The better a cylinder can exhaust, into its own header pipe, the happier your engine will be and the more power it will create. Look into your engine bay. You do not have 6 little pipes twisting around and dropping down under your truck. You have one. A manifold.
    Natedogg320[OP] likes this.
  3. Jul 7, 2018 at 9:51 PM
    #103
    Kamille.bidan
    Kamille.bidan Well-Known Member
    2017 Blue TRD OR MT
    I could be wrong about this, but it looks like the manifold is integrated into the block or bottom-end. It appears that there is absolutely no way to ever put headers on this engine without a new bottom end.
  4. Jul 7, 2018 at 10:51 PM
    #104
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    This is a true statement. Headers on that engine aren't gonna happen
  5. Jul 7, 2018 at 11:35 PM
    #105
    N2DesignsInc
    N2DesignsInc --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    By far the best post ever. I’m going to do this and tell people I’ve got a V8 under the hood...on a Prius.
  6. Jul 9, 2018 at 6:04 PM
    #106
    Natedogg320
    Natedogg320 [OP] Member
    Nathan
    Butler Pennsylvania
    2018 tacoma trd sport
    So I can't put headers on then?
    MOC221_ likes this.
  7. Jul 9, 2018 at 6:06 PM
    #107
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    No, but you can put on aftermarket pipes that eliminate 2 or all 4 of the cats. URD makes em. Each head has one fairly large oval exhaust port. That's it.
    Have a look at the diagram in post # 100. Part labelled "1". That bolts up to the head.
  8. Jul 9, 2018 at 7:36 PM
    #108
    deuceb
    deuceb Well-Known Member
    Denver | Austin
    2018 Taco BBPDCLBTRDOR | 2004 MB SL55 | 86 VW GTI
    Why do so many people here waste their own time, and OP's, to tell him he's dumb for wanting to change his truck? It's not your truck, why can't you just ignore the threads that you don't want to help on? I'm just starting to feel sorry for some of these people though that just takes what the factory gives them. If that's all you want the vehicle for then great, but some want to customize and make the truck theirs.
    Anyway OP since you want more power it's still done the same way as almost every other car. Get more air in and then get the air out faster. That means an intake (not much increase cause modern intakes are pretty good), a cat-back exhaust (again the same issue of not much increase), URD y-pipe minus 2 cats (unproven but gave great results on the 2nd gen), OVTune (sounds like great results), and then a supercharger or turbocharger is all that's left but no one is making a kit yet. There's gears, but those don't really "add" power, but they do potentially help with your torque. That's a different thread, however. Have fun with your truck! I'm waiting for the supercharger to come out cause it should just make a fun truck even more fun.
    MOC221_ and Natedogg320[OP] like this.
  9. Jul 9, 2018 at 7:42 PM
    #109
    aleriance
    aleriance Well-Known Member
    Jorge
    Naples, FL
    2017 TRD Off-Road 4x4
    CMC 285/70/17
    OVTune, Regear, stay away from large tires, buy a lamborghini.
    Try them in that order until satisfied.
  10. Jul 9, 2018 at 9:40 PM
    #110
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    :facepalm: Nope. A header is like a individual exhaust pipe for each cylinder. The way your engineis set up, each side of the engine dumps into a single outlet, with no way to split that up. But like @MOC221_ said, there are things you can still do to improve your power.
  11. Jul 10, 2018 at 3:42 AM
    #111
    MOC221_
    Frank
    Not gonna happen on TW lol. Just ignore it, you'll be happier at the end of the day.
    Agreed on making the truck "yours".
  12. Jul 10, 2018 at 6:27 AM
    #112
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Pull the engine and install a LSX. Probably want to replace the transmission too.
    TheFang likes this.
  13. Jul 10, 2018 at 7:09 AM
    #113
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    Only $16,348 from Chevy! That's a steal of an upgrade.
