More Random Parts for Sale
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Darkgoatracer, May 11, 2020.
  1. May 11, 2020 at 6:39 AM
    Darkgoatracer
    Darkgoatracer [OP] Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    1. 16" 650lb x 3"ID eibach springs $50 + Shipping.
    2. Excedy stage 2 friction disc with stock weight pressure plate. has maybe 10 miles on it. $200 + Shipping. 20200509_112151[1].jpg 20200509_112118[1].jpg 20200509_112103[1].jpg 20200509_112040[1].jpg
  2. May 11, 2020 at 2:00 PM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    Curious, why clutch was removed & what clutch you replaced with?
    Darkgoatracer[OP] likes this.
  3. May 11, 2020 at 3:13 PM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    That is a great question and it has to do with the longest, most expensive troubleshooting adventure i've ever been on with a car...ever. if anyone wants more details let me know but here are the highlights.
    This is one of 4 total clutch sets i bought to resolve a horrible clutch release point issue. Basically the throwout bearing of the performance clutch i had failed. In effort to get my truck off the side of the road i over adjusted the master cylinder (this is where the problem started).
    I bought this clutch, had it put in the truck and the clutch pedal readjusted but we couldn't get the pedal release point anywhere near right. I jumped on the phone with excedy and they sent me over shop drawings and such and everything was the right part, assembled height etc.
    I bought a parts store cheapy clutch, had the same issue, then bought an oem toyota clutch and had the same issue.
    I rode with the oem clutch until i couldn't deal with it anymore. I finally bought a new master cylinder, clutchmasters tob bearing kit with shims and an excedy 2+ clutch and said "f it, i'll replace everything with something different and i'll set my own free air space". Well when i pulled it all apart i found this (which was "replaced" along with the everything else about 37 times)
    The short and sweet was i spent 3,000$, my truck sat on a lift for 2 months and all over a broken bit of plastic and an inability for people to do what they say they did.
  4. May 11, 2020 at 3:24 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  5. May 12, 2020 at 3:24 PM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    Added lower ball joint cradles
  6. May 12, 2020 at 5:46 PM
    Tacomajoe06
    Tacomajoe06 Well-Known Member
    Joe
  7. May 14, 2020 at 5:34 PM
    Darkgoatracer
    Nick
    Northern VA
    Stock
  8. May 14, 2020 at 6:38 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    where did you add them?
  9. May 14, 2020 at 6:50 PM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    Theyre gone now. I will have another set in a few weeks
    fatfurious2[QUOTED] likes this.
  10. May 19, 2020 at 6:01 AM
    Darkgoatracer
    Nick
    Northern VA
    Stock
  11. May 19, 2020 at 7:40 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    How much lift do the springs provide?
  12. May 19, 2020 at 7:41 AM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    So i could be wrong, but i believe the springs will only work for long travel applications and will be around 2" of lift. I believe for most stock travel applications you would want a 13-14" coil in either a 2.0 or 2.5
  13. May 22, 2020 at 7:25 AM
    Darkgoatracer
    Nick
    Northern VA
    Stock
