more suspension questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by 49erfan, Oct 14, 2014.
  1. Oct 14, 2014 at 6:52 PM
    49erfan
    49erfan [OP] Well-Known Member
    Kevin
    Dallas
    04 DC Prerunner Lunar Mist
    the more research i do, the more confused it get. just purchased a 04 DC SR5 Prerunner, looking to do mild lift as i rarely will be off road if any, plus i still want to fit in the garage.
    after research, i have decided on the bilstein 5100 for front set to achieve 2.5" lift. will probably go ahead and get 5100's for rear as well for improved ride quality. what is recommended for the rear in order to sit level? i do not want any rake or lean. also, want to stay away from blocks so i am thinking AAL??
    any help is greatly appreciated
  2. Oct 15, 2014 at 9:01 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    An AAL would be a good option to lift the rear of your truck to match the front, as long as your stock leafsprings are in good shape. Wheeler's has several options for AALs depending on how much lift you want . The other option would be to replace the leaf packs with Dakars, Deaver, All-Pro, or something similar. The good thing about replacement leaf packs is if your stock leafs are getting worn out, these will give you a lot of extra capacity for towing, hauling, etc.
    If you haven't already read it, check out the Lift FAQ.
    I've never had 5100s on my truck, but the general consensus seems to be that the ride quality will be quite a bit stiffer, which some people prefer but others find jarring. I have Nitrochargers on my truck, which maintain a pretty good ride IMO.
  3. Oct 15, 2014 at 10:04 AM
    49erfan
    Kevin
    Dallas
    i researched the FAQ thread but there seemed to be majority of comments relating to second gen. ill look into the nitrochargers as well, 5100's seemed to be a popular choice. i wouldnt be doing much towing or hauling
  4. Oct 15, 2014 at 2:21 PM
    TacomaRaider
    TacomaRaider Well-Known Member
    TumbleWeed
    Northern California Shasta county
    2002 3.4l 4x4 Tacoma SR5 TRD
    Bilstein 5100 front and rear OME 882, OME Dakar, American Racing baja AR172 15x8, BFG KM2 32X11.50
    I have 5100s on my 02 ex cab. The front did not lift very much. I put 5100s on front and back and still have a slight rake. The rear being higher that the front. I bought a 1.5 3 leaf progressive for the rear and did not install it.
  5. Oct 15, 2014 at 2:24 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Look at combining 5100's with an OME coil. On my second gen I got almost 3 inches of lift with an OME 885 and 5100's...I don't know about first gens, I wanna say like an OME 881 or something I've heard.
  6. Oct 15, 2014 at 5:27 PM
    49erfan
    Kevin
    Dallas
    considering the OME's as well, my truck as 105k and not sure how worn the stocks are. id rather do it right the first time than have to go back and install new parts
