More Torque?
Discussion in 'Performance and Tuning' started by RickW, Apr 12, 2021.
  1. Apr 12, 2021 at 1:52 PM
    RickW
    RickW [OP] Well-Known Member
    Rick
    Stockton, Ca
    07 Tacoma daily driven
    Forum: For a long time all I have seen for more Torque is getting a supercharger.
    A big ticket item for sure.
    I have to wonder what some cyl head porting and an extra point of compression would do?
    I have been skiing and the hills are tough at 8K.
    More grunt at 2K rpm would be nice.
    No I am not suggesting this for a good running engine.
    But for one that needs the heads to come off.
    It seems like an interesting option?
    R
  2. Apr 12, 2021 at 2:00 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    2023 Ford Raptor
    Cylinder head porting is going to be just about as expensive as the supercharger (for quality work) and yield a much lower return especially considering the hp/$ ratio, even if you skim the head to increase the static compression. The stock rods/pistons will now allow you to rev the motor out to take advantage of a high flowing N/A setup. The camshafts are also not well suited for high RPM operation as they are designed around a OE engine that primarily operates around 2-3K RPM. Upgrading the camshafts and valvetrain (required) is at least 1/2 of what a supercharger.
    Anything you do to the truck N/A is going to shift the powerband to the "right" away from "low-end", aside from a few select mods which help in that area. Intake manifold spacer, exhaust cam gears, equal length headers, and a tune are about all you can do to improve the low end and general powerband of these motors without shifting all the power to the higher RPMs.
    My 2cents.
  3. Apr 12, 2021 at 2:06 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Bigger diameter pistons, 2 more cylinders, longer crank throws.......
    oh,,,,,thinking an old 455 cu in with a 4 bbl. Or for the new guys, 6.0L V-8. Shoe horn that sucker in......
  4. Apr 12, 2021 at 2:11 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
  5. May 13, 2021 at 8:43 AM
    RickW
    Rick
    Stockton, Ca
    I was thinking of pocket porting the heads, not a full CNC porting job. lol
    Milling the heads should gain a half point in compression?
    Together they should add some HP/TQ from idle on.
    I'm surprised no one has done this?
    But then again these engines are very reliable! lol
  6. May 18, 2021 at 2:02 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
  7. Jun 14, 2021 at 7:29 PM
    parel
    parel Well-Known Member
    Kin
    Calgary, AB
    (ex. 2014 Black Tacoma TRD)
    OEM FJ TRIBUTE EDITION (REPLICA)
    If I were to do all those mods you suggested using a -3* gear, 1/2” spacer and specU pipes, along with your magical touch, could I see 10-15% more power for my stock truck? I live at 1km above sea (3500ft). Thanks in advance, I hear your engine tunes are 110% worth it.
  8. Jun 14, 2021 at 9:37 PM
    RickW
    Rick
    Stockton, Ca
    I'm interested in the intake manifold spacer.
    Does it do anything?
  9. Jun 14, 2021 at 9:41 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Nitrous Oxide, 125HP boost shot will work.
    Shellshock likes this.
  10. Jun 14, 2021 at 9:49 PM
    Shellshock
    Iowa
    125 shot of nitrous will definitely fix the problem one way or another
    Mully[QUOTED] likes this.
  11. Jul 16, 2021 at 10:56 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    more than likely higher temps
    the extra compression offset by detonation under load
    essentially the 2 reasons most dont do what U inquire
    a properly tuned SC will give U what is available long term
