Morimoto bi xenon battery connection help
Discussion in 'Lighting' started by thedude, Jul 29, 2011.
  1. thedude
    thedude [OP] Well-Known Member
    Lucas
    Little Rock, AR
    Do the two wires on the drivers side hook up the battery or is one hooked up to the neg and one a grounding wire? Thanks
  2. thedude
    Lucas
    Little Rock, AR
    Not sure if it matters, but I grounded the neg wire instead of hooking up to battery. Hi/Low Beams work so I guess it did it correctly.
