Morimoto D2S retrofit with Apollo Shrouds (lots of really big pics)
Discussion in 'Lighting' started by tooblutacoma06, Oct 16, 2010.
  1. Dec 14, 2010 at 5:45 PM
    #61
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    So this is a correct setup, right? No extended wire necessary?
    Bi-xenon Morimoto Mini Stage III Kit (D2S)
    • CCFL Angel Eyes: No thanks
    • Projectors: LHD (North American Standard)
    • Bulbs: New Philips 85122+ D2S
    • Ballasts: Morimoto 3Five (35w)
    • Wire Harness: H4 Bi-xenon
    • Shrouds: Apollo
  2. Dec 14, 2010 at 6:12 PM
    #62
    tooblutacoma06
    tooblutacoma06 [OP] Member
    Kellon
    Houston
    Sorry dude, haven't been to the boards in a while. I actually cut the rubber washer down so that I could get more threads in. It was annoying to do but I used an exacto knife with a sharp blade and it worked well.
    On the shrouds, I just trimmed wherever it would hit the reflector bowl. I tested the shroud around the projector and looked for the reflections to touch, and that's where the shroud was hitting the reflector, marked it then sanded with a roto-zip.
    I'm sure you wont need this advice now but maybe it will help someone later
  3. Dec 14, 2010 at 6:13 PM
    #63
    tooblutacoma06
    Kellon
    Houston
    Yep that's correct.
  4. Dec 14, 2010 at 6:22 PM
    #64
    Nightstr
    Nightstr Well-Known Member
    Felipe
    Sacramento CA
    05 prerunner sr5
    BLHM BLWM 3" TOUGH COUNTRY LIFT TRD SEAT COVERS THULE RACK M/T KM2 265/65/16
    Make it look so easy.:(
  5. Dec 15, 2010 at 9:42 AM
    #65
    Muy Grande
    Muy Grande Well-Known Member
    Dallas, TX; RGV, TX
    06 DC TRD
    Suspension: DHoes up front, Dakar and OME out back. Audio: Alpine w205 w/ pair of Alpine Amps, Image Dynamic 6.5 Component Speakers up front and Image Dynamic Subs in the Back. Armor: ARB Bull Bar, Rocktek rear bumper and custom rock sliders. Other: Rigid Industries LED Light Bar, Platinum DieHard Battery, BlueSea Fuse Block, rear lights, bed lights, leds inside.
    I really like this setup and the pics and "how to" are excellent. Thanks OP! I'm going to try this when I get some funds. :D
  6. Dec 15, 2010 at 3:50 PM
    #66
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Another question. When it comes time to adjusting them, how is that accomplished? I didnt see any adjustment on them. Is it just the stock up/down and left/right adjustment screws that are used?
    Btw, Is there an "UP" or similar type of marking/label to tell me how they go in initially? (I'm just thinking this install through in my head first before anything)
  7. Dec 15, 2010 at 3:54 PM
    #67
    SmilingMark
    SmilingMark Well-Known Member
    Mark
    Ogden, UT
    2010 Access Cab
    Color matched grill w/ grillcraft. BHLM and Morimoto Mini HID's Debadged.
    Yes, the stock adjustments do up and down, left and right. There is no "Up" marking, but put the relay for the cutoff on the bottom, the projector inverts the image, putting the cutoff line on top.
    Make sure you get them level before your seal them up, that's the only adjustment you can't make after you're done.
  8. Dec 15, 2010 at 4:21 PM
    #68
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Cool, Thanks Mark! Any tips/tricks to having them level w/o reinstalling in the truck first? Or do they fit relatively level right off the bat? (sorry if this is a dumb question, but I dont have them in my hands yet to test fit anything)
  9. Dec 15, 2010 at 4:34 PM
    #69
    SmilingMark
    Mark
    Ogden, UT
    2010 Access Cab
    I leveled them to the housings themselves and found that wasn't good enough. You should mount them back on the truck before you put lenses back on. Wire them up and use a carpenters level on the cutoff line against the garage wall. I was able to tweak a bit afterwards but still not totally satisfied. I'm the only one who notices, but I'm a perfectionist.
  10. Dec 15, 2010 at 4:40 PM
    #70
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Got it. Thanks!!
  11. Dec 29, 2010 at 9:40 PM
    #71
    Zizo
    Zizo Engineer Extraordinaire
    Anthony
    Greenville, SC
    '06 DoubleCab 4x4 TRD Sport
    TRD Supercharger, 3" lift w/ Fox Shox, Pioneer Sound System, Remote Start, Avid Off Road Bumpers, All Pro Sliders, LED light bar, HID headlights, much more...
    Hey guys, I just did this retrofit this weekend. I can't seem to get the lights to stop vibrating. I mounted them both using the H4 adapter ring, without the rubber washers, aside from the big white one. I clamped them down pretty good, but when the truck is in Drive and I'm stopped, the lights vibrate slightly. Should I try clamping down the nuts further? what can prevent this?
  12. Dec 30, 2010 at 7:59 AM
    #72
    blawrie
    blawrie Well-Known Member
    I would recommend reinstalling the nuts with ALL the rubber washers provided and using a little loctite on the threads to insure they don't move from road vibrations. There is a reason TRS provides those washers. Just be careful you don't over tighten the nuts too much or they will split on you!!! Good luck and let us know how that works.
  13. Dec 30, 2010 at 10:25 AM
    #73
    tooblutacoma06
    Kellon
    Houston
    Yep, I would use the white washer to help with the vibrations.
    You can trim it out like I did and you will be able to get more threads engaged. But yea, be careful with the nuts.
  14. Dec 30, 2010 at 6:14 PM
    #74
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Yeah, that's what I told her too.
  15. Dec 31, 2010 at 7:15 AM
    #75
    tooblutacoma06
    Kellon
    Houston
    I figured someone would take the bait on that one!:D
  16. Feb 5, 2011 at 2:17 PM
    #76
    schiz94
    schiz94 Thread Jacker
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    Morimoto Projector Retrofit, alpine cda-105,Wheelskins leather wheel cover, wet okoles,5% tint on back and 24% on front two windows,Debadged tailgate,custom sockmonkey centercap decals, xr rims pced gloss black.
    How do you get the reflector bowl off the grey back of the headlight? im painting mine black and need to get it off right now?
  17. Feb 5, 2011 at 4:55 PM
    #77
    schiz94
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    NVM figured it out
  18. Feb 25, 2011 at 5:29 PM
    #78
    AK27
    AK27 Well-Known Member
    how's my alignment for the cutoff?
    pic is at ~50 feet away
  19. Feb 25, 2011 at 6:56 PM
    #79
    Nightstr
    Felipe
    Sacramento CA
    05 prerunner sr5
    That's nice! I've been adjusting mine for the past week and can not get it were I want it.:(
  20. Mar 1, 2011 at 8:10 AM
    #80
    tooblutacoma06
    Kellon
    Houston
    Looks good! About how mine is. Just make sure when you pull up to a car at a red light that the cutoff is below their side view mirrors.
