Morimoto Elite HID System and LED Fogs for your '16+ Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRSAndrew, Oct 5, 2015.
  1. Nov 9, 2015 at 6:39 AM
    #221
    mulishan909
    mulishan909 Well-Known Member
    Mulishan909
    2017 Tacoma TRD Sport
    @TRSAndrew @moe2o4 I have confirmed the stock rubber swap to the morimoto. They are stiffer and has very minimal play vs the morimoto. The morimoto are squishy feeling Iike gummy bears. The stock have actual hardness feel like any rubber washers. Will confirm if they move when driving tonight. But I have a good feeling it will solve the problem.
    :fingerscrossed::thumbsup:
    moe2o4[QUOTED] likes this.
  2. Nov 9, 2015 at 6:44 AM
    #222
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    Sounds good now to find my bulbs later after work lol!
  3. Nov 9, 2015 at 6:45 AM
    #223
    mulishan909
    Mulishan909
    I think home depot or hardware store will have an o right washer to fit
  4. Nov 9, 2015 at 6:45 AM
    #224
    moe2o4
    Corey
    Pittsburgh PA
    It's a o ring on the bulb?
    mulishan909[QUOTED] likes this.
  5. Nov 9, 2015 at 7:00 AM
    #225
    mulishan909
    Mulishan909
    Not really. But you would need to measure or compare your and find one that fits. By the look of it it's about 1/8 inch thick. All it does is when you screw it on it pushes against the base of the bulb to the socket so it doesn't move. But then again water/moisture leak. So bad idea scratch that out. Find your Olds ones
  6. Nov 9, 2015 at 7:17 AM
    #226
    moe2o4
    Corey
    Pittsburgh PA
    I believe i know where the old bulbs are at at home, I'll have to check after work! I put the new hids in and work and thought i left the bulbs here but i guess i didn't.
  7. Nov 9, 2015 at 6:14 PM
    #227
    barnett
    barnett Well-Known Member
    Brian
    Franklin, Tx
    16 DC 4x4 Off-Road
    Changed the rubbers out on the hid's. The ones that come on the Trs kit are a lot softer than the ones that came on the factory bulbs, will find out in the morning. I did get the fogs in yesterday, very happy with everything.
    moe2o4 likes this.
  8. Nov 9, 2015 at 6:53 PM
    #228
    mulishan909
    Mulishan909
    I did swap out the stock rubbers from the stock bulbs to the Morimotos. Still has the Shake/move up and down when driving.
    Please come up with a fix or new bulb replacement or a solution. I have never seen something like this before. @TRSAndrew
  9. Nov 9, 2015 at 6:54 PM
    #229
    oelakkad
    oelakkad Well-Known Member
    MD
    16 DC TRD Off-Road
    Can someone make some install instructions? where are you putting the ballasts? Video would be great too. Thanks
  10. Nov 9, 2015 at 6:57 PM
    #230
    mulishan909
    Mulishan909
    So what happens if people don't have their stock bulbs to take the rubbers off. How can they fix this?[/QUOTE]
    Did you swap your rubbers over to the Morimotos? I did mine but its the same. feels stiffer in the socket but its the same thing. still moves up and down :/
  11. Nov 9, 2015 at 7:01 PM
    #231
    UberDingu
    UberDingu Well-Known Member
    CT
    21 Off-Road AC 4x4 V6
    I'm new to HIDs, so bear with me... but this kit is just the low beams, correct? If so, can I just buy the harness/bulbs for the high beams and plug them into this as well?
  12. Nov 9, 2015 at 7:03 PM
    #232
    mulishan909
    Mulishan909
    you will need a separate kit for high beams= bulb, wires, and ballast ( find the correct bulb size)
    so if you want low beams= 1 full kit,
    if you want high beams= another full kit,
    fog lights= 3rd full kit
    Doomsday likes this.
  13. Nov 9, 2015 at 7:08 PM
    #233
    UberDingu
    CT
    Thanks. Good to know
  14. Nov 9, 2015 at 7:14 PM
    #234
    mulishan909
    Mulishan909
    i would spend the money on high beams, just get a white color bulb for the highs.
    SandyTaco4x4 likes this.
  15. Nov 9, 2015 at 7:16 PM
    #235
    UberDingu
    CT
    I'm definitely going too. If I cheap out and leave them alone I'm gonna be mad as hell every time I turn them on, I already know it. The fog lights I'm still not sure about as I almost never use them. Like ever.
  16. Nov 9, 2015 at 7:28 PM
    #236
    mulishan909
    Mulishan909
    i dont even use my high beams. only to flash people, i got hid in the low beams and will get yellow for the fogs.
    my truck is already 3 inch of 33's so its already blinding people, i dont need to draw attention
  17. Nov 10, 2015 at 5:15 AM
    #237
    mulishan909
    Mulishan909
  18. Nov 10, 2015 at 5:17 AM
    #238
    moe2o4
    Corey
    Pittsburgh PA
    I am going to change out the rubber seals on my bulbs today but if you guys said it don't really make a difference then idk. Hopefully the guys from retro fit source can resolve the problem!
  19. Nov 10, 2015 at 5:20 AM
    #239
    mulishan909
    Mulishan909
    I was super happy before I left work yesterday. But then as I was driving home, it's the same still moves on bumpy roads. :notsure:
  20. Nov 10, 2015 at 5:22 AM
    #240
    moe2o4
    Corey
    Pittsburgh PA
    Ya idk either........ :help::notsure:
