Morimoto Elite HID System and LED Fogs for your '16+ Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRSAndrew, Oct 5, 2015.
  1. Nov 23, 2015 at 4:46 PM
    #401
    barnett
    barnett Well-Known Member
    Brian
    Franklin, Tx
    16 DC 4x4 Off-Road
  2. Nov 23, 2015 at 4:48 PM
    #402
    barnett
    Brian
    Franklin, Tx
    16 DC 4x4 Off-Road
  3. Nov 23, 2015 at 6:08 PM
    #403
    solscooter
    solscooter Sh!t Outta Luck
    Brian
    Minnesota
    2016 TRD OR DCSB 4x4
    i was starting to contemplate other members statements of getting highs flashed at them after installing HIDs (I got the 55w 5500K, w/ the LED fog lights). i also see that after the install the course of light out of the headlights is level, i mean both the driver and passenger side are casting a beam of light at the same horizontal level.
    thinking back to other vehicles i've had w/ factory projector HIDs the driver side casts light slightly lower than the passenger side. I'm not sure if this was designed as part of the factory projector housing or if they were aimed slightly downward from the factory.
    Is this something we should consider doing with our driver side light? angling the beam slightly lower than the passenger side? or leave them level as it was for the standard halogen bulbs? maybe this would help avoid being flashed by oncoming drivers
    moe2o4 likes this.
  4. Nov 23, 2015 at 6:23 PM
    #404
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    When I installed my hids in my factory projectors they needed lowered a little cause stock height is way to high for hids. It's ok for halogens since they arnt as bright!
    Ars3nalTRD and MannyS like this.
  5. Nov 23, 2015 at 7:41 PM
    #405
    UberDingu
    UberDingu Well-Known Member
    CT
    21 Off-Road AC 4x4 V6
    Mine are fine where they were set from the factory. Driver side is SLIGHTLY lower than passenger. Never considered that it may be intentional
  6. Nov 23, 2015 at 8:09 PM
    #406
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    is there a "standard" for lights on the height we should aim them at?
    Like for example, "At 25 feet from a wall the lights cut-off should be at X inches/feet"
  7. Nov 23, 2015 at 8:34 PM
    #407
    Tacoma2GR
    Tacoma2GR Well-Known Member
    Hesperia, CA
    2020 TRD Sport 4x4
    Any shaking on bumps?
  8. Nov 24, 2015 at 4:59 AM
    #408
    moe2o4
    Corey
    Pittsburgh PA
    Well I did put a 265 75 16 tire on mine so it raised the whole truck up almost a inch.....
  9. Nov 24, 2015 at 7:51 AM
    #409
    barnett
    Brian
    Franklin, Tx
    16 DC 4x4 Off-Road
    On the road normal driving No, I do live in the country and cross cattle guards every day and live off a long gravel driveway, on that type of driving yes I get a lil jiggle. It's nothing major, and the difference in light output is phenomenal.
  10. Nov 25, 2015 at 6:22 PM
    #410
    NWTacomaDave
    NWTacomaDave Well-Known Member
    David
    Seattle, WA
    2016 Double Cab TRD Sport LB, Blazing Blue Pearl
    Curious on people's set up. Is everyone using the power harness with relays to run power directly from the battery. Or just using the existing harness with ballast, canbus, to HID bulb?
    If you are using the power harness does it only require to plug in one oem plug. What I am trying to say is that the harness has one plug labeled oem input. I am confused on how to incorporate this. Can someone either explain or provide a diagram or pictures. Much appreciated
  11. Nov 25, 2015 at 6:25 PM
    #411
    unixadm
    unixadm Well-Known Member
    Super White 2015 DCSB 4x4 Off Road
    Just bought my Tacoma today. Anyone have a valid discount code for TRS?
  12. Nov 25, 2015 at 7:39 PM
    #412
    chealy86
    chealy86 Well-Known Member
    South Carolina
    2016 SR 2.7L 6spd
    I ran the power lines to the battery and used one oem plug, don't think it matter which. It just depends on where you mount relays/power harness. The ballasts need separate pkwer from what the oem plug provides. The oem plug is to control the hids.
    Hope that made sense....
  13. Nov 25, 2015 at 7:56 PM
    #413
    KalihiforniaTaco
    KalihiforniaTaco Well-Known Member
    Honolulu, HI
    '16 Limited Tacoma
    A DIY would be perfect if anybody doesn't mind.......Thank you in advance.
  14. Nov 25, 2015 at 9:22 PM
    #414
    AFMurse2014
    Devin
    San Antonio
    I will do one, if I ever get my damn truck...
  15. Nov 30, 2015 at 10:27 AM
    #415
    SAMROD87
    SAMROD87 Well-Known Member
    Sam
    Coachella
    99 SR5 4x4 / 2016 White TRD off road 4x4 DCSB
    Has anyone else had trouble with the connection going to the OEM plug? The connection does not seem like a very good one and I had a headlight go out while driving, I turned head lights off and on and it turned back on... the only connection I was not very sure about was the oem plug sending the signal to power on lights.
  16. Nov 30, 2015 at 1:10 PM
    #416
    8102
    8102 Well-Known Member
    British Columbia
    2016 Toyota Tacoma Limited
    VLEDS LED Low Beam Headlights, VLEDS High Beam LED Headlights, VLEDS LED Fog Lights, VLEDS LED Triton Turn Signals and Brake Lights, VLEDS LED Interior Lights, Reverse, Licence Plate Lights, Stainless Steel OEM Exhaust Tip, Leer XL Canopy, Bed Rug, Diablo Grill Logo, mattgecko Engine Compartment Lights and Bed Lights.
    If you have installed your system using the relay which supplies power to both lights then one light would not go out because of the connection from the OEM connection to the relay, all I can suggest is to recheck the connections from the relay to the faulty headlight to make sure they are all tight and are making connection (male to female).
    You can check the operation of the relay as well by listening or putting your hand on it when the headlight switch turns on, you should hear it or feel it when the lights are turned on, but if the HIDs are working then the relay is most likely working fine, it is most likely a loose connection between the relay and the bulb, or, a faulty bulb.
    Hope this helps, the connections can be "finnicky".
    SAMROD87[QUOTED] likes this.
  17. Dec 1, 2015 at 9:52 PM
    #417
    mulishan909
    mulishan909 Well-Known Member
    Mulishan909
    2017 Tacoma TRD Sport
    No its bouncing. I see it when I am on a bumpy road. And when I romp over railroad tracks. It's the bulb moving. No illusion tricks. I drive on both smooth and rough streets that how I know they move. Or shake
  18. Dec 1, 2015 at 9:57 PM
    #418
    8102
    British Columbia
    I noticed when I installed mine there was "2 ways" they would "lock in" one way they were a little loose and the other way they were super tight, maybe try taking them out and putting them back in "in a different rotation" if that makes any sense...
    Mine are Morimotos and they came from VLEDs.
  19. Dec 1, 2015 at 10:03 PM
    #419
    mulishan909
    Mulishan909
    Only one way it can go with the rod pointing down when locked in
  20. Dec 1, 2015 at 10:07 PM
    #420
    8102
    British Columbia
    Maybe we are not talking about the same thing, I was referring to putting the socket back in the projector housing.
