Morimoto Elite HID System and LED Fogs for your '16+ Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRSAndrew, Oct 5, 2015.
  1. Apr 22, 2016 at 1:51 PM
    #1001
    Ronin229
    Ronin229 Well-Known Member
    Clearwater, FL
    2016 Limited 4x4 Silver Sky
    Ceramic tint with Air Blue80 on front windshield and sunroof Nfab bars
    Yeah it seems to be a mystery. TRS says its the housing, but if that were the case, then you should have the bounce with the OEM bulb. Like I said earlier, before I ordered the kit, I grabbed the back of the projector housing to see if there was any movement. There was a little flex, but for the most part they were solid.
    From the video's I've seen showing the bounce, it almost seems like the issue is with the bulb vibrating in the housing. I can't see how one cannot install the bulb properly. Once the 3 tabs engage the housing, the bulb catches and the gasket compresses as you lock the bulb in place. I will say when the bulb starts to lock in, it does get really tight, so maybe people aren't turning them to full lock? Not sure I'm only guessing.
    But for now I don't have the bounce.
  2. Apr 22, 2016 at 4:50 PM
    #1002
    Tacuache345
    Tacuache345 Well-Known Member
    Mario
    Los Angeles, CA.
    2016 DCSBOR/BBP
    None
    I installed my kit today and only passenger side works, everything is is hook up nice and firm. Kit is the 5500. 11B I gues is time to call tech support.
  3. Apr 22, 2016 at 6:50 PM
    #1003
    Ronin229
    Clearwater, FL
    UPDATE!!
    So tonight I was driving around with my new lights, and I noticed that I needed to adjust the beam downward out of respect for other drivers.
    Initially, I did not have the bounce issue. HOWEVER, I noticed that as soon as I touched the adjustment knob for the driver's side, the beam bounced like crazy. If I taped it gently with my finger, I could get the beam to bounce.
    I adjusted both beams down and took a test drive. Now on jarring bumps, my drivers side beam bounces a little.
    So I think the bounce problem has nothing to do with the grommets on the bulb, or the bulb itself, but with the adjustment knob.
    So if you have the bounce issue, try adjusting your headlights up or down slightly and see if that helps. Not sure how the adjustment system is built, but perhaps the dial is between a set point.
  4. Apr 22, 2016 at 6:53 PM
    #1004
    Ronin229
    Clearwater, FL
    I'd call support. Or if you want, start switching components one at a time. Start with the ballast from the passenger side and move it to the drivers side. If that doesn't work, put it back, and switch the igniter. If that doesn't work, swap the bulbs. If that doesn't work, well don't know what to tell ya lol.
  5. Apr 22, 2016 at 7:00 PM
    #1005
    Tacuache345
    Mario
    Los Angeles, CA.
    2016 DCSBOR/BBP
    None
    I went out to check it for the second time and this time both are on. Thank's for your hints, I'll drive it tonight or see how it works. Still driver side don't turn on, so I check power from relay to ballast ok 12.5 volts then I swap igniters and bingothe driver side come and the passenger side don't, so I got a defective ignator. Will call company on Monday.
    Ronin229[QUOTED] likes this.
  6. Apr 22, 2016 at 7:05 PM
    #1006
    muchostacos
    muchostacos Member
    Houston, TX
    2016 White DCLB TRD Off road
    I just finished installing the 35w/5500k Morimoto kit from Retrofit Source. Holy crap! Night and day difference from the factory halogens. I don't see the bounce some have experienced. One of the things I did was to zip tie the igniters to the frame of the truck with enough wire so it isn't pulling on the bulb.
    Tacomainflorida17 and Positronik like this.
  7. Apr 22, 2016 at 7:07 PM
    #1007
    Ronin229
    Clearwater, FL
    Awesome. I did the same, secured the igniters, relay's and ballasts to the frame, and zip tied the wires in place.
  8. Apr 24, 2016 at 7:18 PM
    #1008
    Malibu7tss
    Malibu7tss Can' t think of anything to type here right now.
    Central pa.
    2016 trd sport dcsb 4x4 bbp 6spd manual
    Old man emu with 888's and headstrong off road progressive aal, trd pro wheel, Cooper Stt Pros 285/70r17
    Are we to order the kit with canbus or the relay kit?
  9. Apr 24, 2016 at 7:57 PM
    #1009
    Ronin229
    Clearwater, FL
  10. Apr 25, 2016 at 5:21 AM
    #1010
    Malibu7tss
    Central pa.
    Thank you. That is the first time that link has worked. The links on here before the one you just gave me always went to the home page of their site. Could be operator error..... or should I say most likely operator error.
  11. Apr 25, 2016 at 8:10 AM
    #1011
    Ronin229
    Clearwater, FL
    No problem man. Yeah that happened to me too, and then I spent time looking for the individual parts on the website. Then I saw that search box in the corner and was like, "hummm."
  12. Apr 25, 2016 at 9:19 AM
    #1012
    Tacuache345
    Mario
    Los Angeles, CA.
    2016 DCSBOR/BBP
    None
    So one of my igniters are defective, I called tech support and they ask me to cut the wire in the faulty ignator and send a picture ( email ) back, so they can send me the replacement.
  13. Apr 25, 2016 at 9:25 AM
    #1013
    Ronin229
    Clearwater, FL
    They probably want to make sure your not asking for spare parts.
  14. Apr 29, 2016 at 11:34 PM
    #1014
    tacoma28
    tacoma28 Well-Known Member
    Sergio
    Arizona
    05 Speedway blue sr5 4X4
    UPDATE!!
    I installed a different brand of hid bulbs.....THEY DONT BOUNCE!!!!... something is wrong with the morimoto bulbs!
    somebody knows what's the difference between the bulb size h11 and h11b?
    Tacomainflorida17 likes this.
  15. Apr 30, 2016 at 12:42 AM
    #1015
    Mr. Torgue
    Mr. Torgue Explosions!!?!!?!?
    2016 7544HHBBP
    LED lighting
    Bulbs are the same size, the difference is where the filament is placed in the bulb.
    Which HID kit did you go with?
  16. Apr 30, 2016 at 5:19 AM
    #1016
    Ronin229
    Clearwater, FL
    I managed to get most of the bounce out by adjusting the height of the beam using the adjustment knob on the housing. But I still have a little bounce on the drivers side that's omming from the bulb.
  17. Apr 30, 2016 at 10:31 AM
    #1017
    tacoma28
    Sergio
    Arizona
    I kept the morimoto ballast, I only replaced the bulbs from some eBay $10dlls bulb. But I still want to fix the bouncing from the morimoto bulb because they're brighter and good color.
    The other bulbs are H11 maybe the regular morimoto h11 won't bounce ??
  18. Apr 30, 2016 at 5:11 PM
    #1018
    Malibu7tss
    Central pa.
    I have not been this pissed at a product in a long time. I talked to the retro fit source and they told me what to check to make sure that the headlights would not bounce. That it was a problem with the truck and not their lights. That the bouncing was very rare. I checked my truck and found no problem. So I spend the 158 dollars on these things. And guess what. The bounce. Shame on me. Hopefully they will take them back.
  19. Apr 30, 2016 at 5:27 PM
    #1019
    Ronin229
    Clearwater, FL
    Did you try adjusting the height of the beam with the adjustment knob. That helped me reduce some of the shake.
  20. Apr 30, 2016 at 5:28 PM
    #1020
    Malibu7tss
    Central pa.
    I read that you had done that and I did try. No change.
