Morimoto Elite HID System and LED Fogs for your '16+ Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRSAndrew, Oct 5, 2015.
  1. Nov 4, 2015 at 11:18 AM
    #141
    Ars3nalTRD
    Ars3nalTRD I Know Nothing!
    NoVA
    2016 BRM Tacoma TRD Sport
    If you wait until I get mine I will make a video of it... you can then decide whether or not you would do it yourself or pay someone to do so.
    I mean, they shouldn't charge you more than 20 bucks to run some cables... if they do, they better make it look like it came from factory LOL
    DCLBTRDORFTMFW likes this.
  2. Nov 4, 2015 at 12:03 PM
    #142
    ericsan777
    ericsan777 Well-Known Member
    Eric
    Annette Island, Alaska
    2016 Tacoma MGM DCSB 4X4 TRD Sport Delivered to me 11/20/15
    Yeah, it was $160 for installation plus an up charge on the actual products. When do you expect your truck to get in?
  3. Nov 4, 2015 at 12:05 PM
    #143
    Ars3nalTRD
    NoVA
    F-that!!!! that is about as much as the kit itself... they can go pack sand... Anyways, truck is supposed to be here last week of this month and I purchase this kit first week of December (x-mas special @TRSAndrew *hint hint*)
  4. Nov 4, 2015 at 12:28 PM
    #144
    ericsan777
    Eric
    Well, that includes the LED fogs too...
  5. Nov 4, 2015 at 12:29 PM
    #145
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    I will be ordering the LED Fogs when i get bezels for my 16. Waiting on the dealership to get some in that have holes cut out in them for the fogs!!!
    0uTkAsT likes this.
  6. Nov 4, 2015 at 12:40 PM
    #146
    ericsan777
    Eric
    If I already have fogs, should be easy right?
    moe2o4[QUOTED] likes this.
  7. Nov 4, 2015 at 12:41 PM
    #147
    moe2o4
    Corey
    Pittsburgh PA
    Yep they are plug and play. I don't have fogs in my SR so i need the bezels and a wiring harness and switch!!! Just curious where is your stock switch in your 16? On the Stalk on the column? Any chance you could snap a pic of it?
    0uTkAsT likes this.
  8. Nov 4, 2015 at 12:42 PM
    #148
    ericsan777
    Eric
    Mines not in until 11/14-20th time frame. Hoping to pick up 11/20!
  9. Nov 4, 2015 at 12:44 PM
    #149
    moe2o4
    Corey
    Pittsburgh PA
    Ah Sweet!!!!!
  10. Nov 4, 2015 at 12:55 PM
    #150
    atrouth
    atrouth Well-Known Member
    Anthony
    2016 MGM Tacoma TRD Sport DCLB 4x4
    Installation is easy, you dont have to move anything if you dont want to. I moved my washer fluid reservoir so I could mount the ballast behind it for a cleaner install. The battery side the ballast is just mounted beside the battery on an existing bolt. Took about 20 minutes or so and another 10 for LED fogs. I didnt replace the housing on the fogs, just added 2800 lumen philips LED bulbs
  11. Nov 4, 2015 at 2:43 PM
    #151
    mosesofthesouth
    mosesofthesouth Well-Known Member
    I had the same problem, i could get it to fire after i played around with the connections on that side. turned out one of the wires had backed out a bit, in one of the connectors, and the direction had changed on one of the female inputs. easy fix.
  12. Nov 4, 2015 at 5:37 PM
    #152
    atrouth
    Anthony
    I need to figure out a way to keep the license plate lighting out of the camera. I have directional bulbs which helped but it needs a little shroud that extends over the top of the cover to keep it from glaring upwards. Even the halogens have this issue and it's super annoying.
    Replaced the reverse lights with LED. Man they are insanely bright image.jpgimage.jpg
  13. Nov 4, 2015 at 5:42 PM
    #153
    hamiltonuh60
    hamiltonuh60 Well-Known Member
    Texas
    2016 DCSB TRD OR 4WD
    Frontrunner, CVT RTT, Foxwing, Switch Pros, OGE, Fox, ADS, TC UCA, Dakar, Superbumps, U bolt flip, blah blah blah
    Which bulbs did you go with and where did you get them? Eventually I'd like to replace all my lights with LED. Just got done doing the interior.
  14. Nov 4, 2015 at 5:46 PM
    #154
    kevr6
    kevr6 Narragansett Nation
    Kevin
    New Jersey
    2016 Tacoma 4wd Double Cab/ Inferno Orange
    Tint, weathertech mats, neoprene cover, Sill protection, 20" Fuel wheels, ICON Stage 4 3" lift with UCAs, BD Customs Grill w/ Rigid 3x3 floods, Rear bed mat, Bed extender, n bed bike rack, RCI skid plate, Front Recover shackle, etc
    I work 15 min from you guys! Can I stop by and get you to install?
  15. Nov 4, 2015 at 5:47 PM
    #155
    atrouth
    Anthony
    I've tried to keep manufactures the same for certain things. My interior fronts are from VLEDS but their dome light is 360 degrees and there's no reflector in ours. In retrospect I should've bought the morimoto chip LEDs for the front so they would match the dome. Waiting for a morimoto XB led dome light, tag lights are the Philips 194 from Amazon. Not super bright which is good but still look nice. The reverse lights are from some company on Amazon. JDM A star I believe. Claim to be 800 lumens. But all I know is they are really bright. Front LED fogs are from VLEDS the vx3 ones. Headlights are morimoto XB HID
    0uTkAsT and ericsan777 like this.
  16. Nov 4, 2015 at 6:25 PM
    #156
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
  17. Nov 4, 2015 at 6:32 PM
    #157
    AndyNguyen
    AndyNguyen Well-Known Member
    I have the same problem with the plate lights, thinking about putting the OEM bulbs back. Please post your solution once you got it figured.
  18. Nov 4, 2015 at 6:34 PM
    #158
    atrouth
    Anthony
    Even my oem ones have that glare. I don't remember if it was an issue on my 2nd generation or not but there's gotta be a way to fix it
  19. Nov 4, 2015 at 8:37 PM
    #159
    A1Cfuji
    A1Cfuji Well-Known Member
    Branden
    Wahiawa,HI
    yea mine was the connector too. still havent tried to fix it yet. maybe this weekend ill try.
  20. Nov 4, 2015 at 8:40 PM
    #160
    dylmatik
    dylmatik Well-Known Member
    Dylan
    16 DCLBTRDOR
    What bulb size are the LED reverse lights? Is it this one?
    http://www.amazon.com/JDM-ASTAR-Lum...698482&sr=8-4&keywords=jdm+a+star+reverse+led
