Morimoto LED Tail lights at Got Exhaust
Discussion in 'Got Exhaust' started by GotExhaust, Jun 20, 2022.
  1. Jun 20, 2022 at 3:50 PM
    GotExhaust
    GotExhaust [OP] Well-Known Member Vendor
    Nick
    Got Exhaust is offering these killer Morimoto LED tail lights!
    Compatible: With all versions of the Toyota Tacoma from 2016 on up, they are extremely easy to install. These plug and play with the factory wiring harness, use all of the stock mounting points, and should not take more than 15-20 minutes to install both tail lights.
    Style: Inspired by the design of OEM tail lights, these look at-home on the rear-end of the third gen Tacoma. The prominent light blades are illuminated from the rear with integrated TIR optics, and serve the brake light, parking light, and turn signal. Despite the fact that the optics are molded from red polycarbonate, they still illuminate in amber for the turn signal, giving them a unique look. Pair that with the surrounding muscular trim, optional clear or red outer lens, and we've easily got what is the best looking set of Tacoma tails on the trail.
    Turn Signal: The Amber LED turn signal can be setup according to preference as a reverse sequential or a more conventional on/off setup. Deciding which path to take is easy, since its only a matter of changing a plug on the back of each tail light. No modifications required, everything will plug n play with the factory wiring without any concerns of hyper flashing.
    Reverse Lights: Are often over-looked when it comes to tail lights, but that is not the case here! The Morimoto XB Tails for the Tacoma have a full LED reverse light integrated. With eight LEDs dumping light into the reflector-based optic, its safe to say these will outshine most factory headlights, but in reverse. They are extremely effective.
    https://www.youtube.com/watch?v=-JF6igPFHzw
    Message us for pricing
  2. Jun 26, 2022 at 5:35 PM
    GotExhaust
    Nick
    Great style and function!
  3. Mar 11, 2024 at 3:22 PM
    GotExhaust
    Nick
    Contact me for info and pricing
  4. Jun 13, 2024 at 3:24 PM
    GotExhaust
    Nick
    Great way to upgrade looks and light ouput
  5. Aug 9, 2024 at 5:02 PM
    GotExhaust
    Nick
    Contact me for pricing
