Morimoto LED XB Headlight review
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Apr 3, 2019.
  1. Jun 18, 2019 at 8:00 PM
    #221
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Triple Bi will produce so much better high beam than the XB single.
  2. Jun 18, 2019 at 8:02 PM
    #222
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    1 M-LED produces more low and high than all 3 XB's combined:cool:
    Speaking of..when do yours come in?
  3. Jun 18, 2019 at 8:38 PM
    #223
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yeah, those Bi-LEDs look sick.
    Got them today, already hooked them up on my rack and tried them out for some initial testing fun. Will need to spend some more dedicated time with them though.
    r1200gs4ok and Inferno__Taco like this.
  4. Jun 18, 2019 at 8:59 PM
    #224
    DaBigDogg
    DaBigDogg "Say when..."
    Jay
    Mid-Suffolk, LINY
    2024 Celestial Silver DCSB TRD OR Hybrid
    And this is why I almost want to have a retro done with the M-LED instead of the RX350 lmfao.
    Inferno__Taco likes this.
  5. Jun 18, 2019 at 9:04 PM
    #225
    MESO
    State of Jefferson
    RX's are still the best. But I don't have the room for a standard length projector like that(they are too deep) and access to the bulb would be impossible. Which is why the M-LED fit the build perfect.
    Inferno__Taco and crashnburn80 like this.
  6. Jun 18, 2019 at 9:04 PM
    #226
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You’ll need more than 1 per side to outperform the RX350 projectors with quality HIDs.
  7. Jun 18, 2019 at 9:06 PM
    #227
    DaBigDogg
    Jay
    Mid-Suffolk, LINY
    See...this is why I come to this forum. When I absolutely want to have the ability to seer the retinas of oncoming drivers you fella's always have the knowledge. And knowing is half the battle! :cheers:
  8. Jun 18, 2019 at 9:14 PM
    #228
    tacotroy17
    tacotroy17 Well-Known Member
    Dustin
    SoCal
    2017 DCSB TRD-OR
    Exactly. I need to get mine on before the market gets flooded with OEMs.
  9. Jun 18, 2019 at 9:31 PM
    #229
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    Jokes on you, cause I am!
  10. Jun 18, 2019 at 9:35 PM
    #230
    MESO
    State of Jefferson
    This is true.
    Although not much, the MLED Isn’t too far behind the RX. Chip flip helps. more like 1:1.2:p
    So 3 should do it I hope:D
    what
    I actually plan to angle them similar to what Acura does in their JewelEyes.
    A few degrees and it shifts the hotspots for much more width of light.
    Since there are only 3, Im going to do something like;
    10°
    20°
    Hopefully the cutoff will stay at the same or lower levels as they angle.
  11. Jun 18, 2019 at 10:15 PM
    #231
    Redline870
    Redline870 Well-Known Member
    2018 Cement Tacoma TRD Off-Road
    Dude what is your deal with shitting all over these? They look good perform better than stock, and have you ever even purchased an OEM LED headlights from another manufacturer? $1200 ain’t all that bad.
    kakwvu, tacotroy17 and Inferno__Taco like this.
  12. Jun 19, 2019 at 4:52 AM
    #232
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    I can’t read this post because you’re lighting up the east coast from NorCal :)
    These things are gonna be stupid bright. Does California inspect lights, too? I would love a live stream of the inspector’s (or referee’s) face when you click those bad boys on :rofl:
  13. Jun 19, 2019 at 7:10 AM
    #233
    Semper_Fi
    Semper_Fi Well-Known Member
    AZ
    '17 TRD OR
    Stock Tacoma headlights
    Morimoto XBs
    MESO Customs Triple MLED build
  14. Jun 19, 2019 at 9:49 AM
    #234
    Cement TRD
    Cement TRD Well-Known Member
    2004 Dbl Cab 4x4 2018 Dbl Cab 4x4
    Meso will you ever come out with your own headlights???? I’d be a customer for sure!
    Snaeper and BlazinBlueTaco like this.
  15. Jun 19, 2019 at 11:44 AM
    #235
    MESO
    State of Jefferson
    Prob not:(
    One of these is not like the other
    All projectors are bolted together and on the same level.
  16. Jun 19, 2019 at 12:33 PM
    #236
    MESO
    State of Jefferson
    How much more output do you really gain??
    Here's the answer:
    STOCK XB's @13V pulled 1.57A
    Decent cuttoff. No color
    LUX(yes I know this isn't 100% accurate with LED readings..but if gives us some type of comparison.
    And don't mind my dirty shop door
    Now for the "TRI-LED"
    13V was pulling just over 6A
    3 cutoffs:
    Final output? It was off the scale, to I had to move the meter to the next level so X the number by 10
    4X:eek:
  17. Jun 19, 2019 at 12:37 PM
    #237
    Inferno!
    Inferno! Well-Known Member
    El Dorado Hills
    2018 TRD OR Inferno 285/65/17
    Supercharger, sway bars, lift, leather, tires, Gobi, etc.
    California does not inspect vehicles, so no light inspection. California is pretty lax when it comes to vehicle "rules".
    kakwvu[QUOTED] likes this.
  18. Jun 19, 2019 at 12:38 PM
    #238
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    Very nice. I will say I would love to have that color in mine, but I know it won't happen unless I upgrade.
  19. Jun 19, 2019 at 12:58 PM
    #239
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    I’ve only failed a smog and told to go to the ref.. at which point I said I’d plate it in WV. They didn’t like that.. and I didn’t know / see if there were any other parts of the test.
    Inferno![QUOTED] likes this.
  20. Jun 19, 2019 at 2:10 PM
    #240
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    Don’t you have the same lights as me? Pro tuning with Morimoto HIDs. I have that blue color cutoff. I have the Morimoto 50watt A/C ballast and Morimoto 6500k bulbs.
    You should be able to get it with yours?
    Not like Stew’s, but still blue cutoff.
    C38328EF-BD8F-4C5A-8B81-7D1C33F9897E.jpg 159CBA96-2CFA-489D-AAAD-2C14765D0056.jpg 934ABA6E-F5C0-4A61-AFD0-E2712E2E60BE.jpg
