Morimoto LED XB Headlight review
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Apr 3, 2019.
  1. Apr 5, 2019 at 1:46 AM
    #61
    fullsend604
    fullsend604 Well-Known Member
    2018 Tacoma TRD Sport 4x4 DCLB
    Yukon 5.29 gears, Eaton ELocker, Stoptech 6 Piston front BBK + Stoptech 4 Piston rear BBK conversion (Tundra master cylinder upgrade), 315/70R17 Falken Wildpeak AT3W, Advan RG-D2 17x8.5 wheels (Indigo Blue), Fox 2.5 PE mid travel w/DSC adjust, Icon RXT leaf pack, DRT shackle hangers w/crossbar, BTF high caster LCA, SPC UCA, OVTune 5.29 (87 regular tune), C4 Hybrid front bumper (30" Rigid light bar + 3" pods), C4 Rock Runner HC rear bumper (Baja Designs S1 wide cornering reverse lights), C4 oversized tire fender kit, Cali Raised trail rock sliders, Cali Raised Overland bed rack, Cali Raised bed stiffeners, RCI engine/trans/tcase skids, CBI fuel tank skid, Prinsu cab rack, Borla Type-S exhaust, Morimoto XB LED head + tail lights.
    Is it possible to get a lux meter measurement so we can determine how bright these actually are? I had the XB LED fogs and they only seemed to appear brighter due to the whiter color but the lux reading was actually very low (close to stock) as proven by crashnburn80's studies which can be easily found on TW. Since these are made by the same company I think many of us would like to see actual output readings before pulling the trigger. Don't get me wrong, they do look really amazing and I am very interested however I am sure I am not the only one who is after performance more than looks especially at that price tag.
    Skydvrr, crashnburn80 and TacoTheTaco like this.
  2. Apr 5, 2019 at 6:44 AM
    #62
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    It’s on my to-do list I just haven’t had time.
    I’ll try and do it tonight. I can compare a stock VS OEmassive VS my LED retrofit VS Morimoto XB
  3. Apr 5, 2019 at 10:17 AM
    #63
    skynyrd87
    skynyrd87 Well-Known Member
    2023 TRD Pro Solar Octane AT 2001 TRD OR White MT
    Meso headlights? I'm already in.
    Spazum888 likes this.
  4. Apr 6, 2019 at 11:37 PM
    #64
    Rexus Ranger
    Rexus Ranger Well-Known A-Hole
    Albert
    Reno, NV
    2018 TRD Off-Road
    Once I get this one. I will attempt to modify the original headlight assembly and retrofit a 2009 Lexus IS HID adaptive light assembly into it. This should be a fun project. Wouldn't it be nice if your Taco headlights turn with your steering wheel?
  5. Apr 7, 2019 at 1:39 AM
    #65
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    Good luck!
  6. Apr 7, 2019 at 4:22 AM
    #66
    ptat
    ptat Well-Known Member
    2019 Tacoma SR5 4WD DCLB
    Did these come pre aimed or you have to aim these when you install it?
  7. Apr 7, 2019 at 7:08 AM
    #67
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    I was thinking $1,200 was steep but manageable for a superior light until I read that these aren’t serviceable by the customer. Total miss.
    Thanks for the quick review. They do look nice, otherwise!
  8. Apr 7, 2019 at 7:57 AM
    #68
    MESO
    State of Jefferson
    I am not making my own headlights. But I will be modifying them
    Good luck! Not sure how much space is on the interior and if it can fit an adaptive light (motor +projector). we will find out
    They do not come pre-aimed (at least in my case). It was close but required fine tuning.
    I think that's the goal for Morimoto; the end user should not have to change/service anything. With every internal light being LED it doesn't need to be messed with. Just take a look at other LED lights; Factory LED DRL board is not serviceable, OEM LED fog lights are not serviceable, mirror signal LEDS's are not serviceable etc. It's going to be the norm
    SandyTaco4x4 and Inferno__Taco like this.
  9. Apr 7, 2019 at 8:15 AM
    #69
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    That’s fine, I just don’t like the idea of spending $1,200 knowing I can’t change a bad LED bulb out on my own knowing that you can buy replacement bulbs. Seems like a simple enough solution but there’s built in repair costs for something that’s easily serviceable by the customer.
  10. Apr 7, 2019 at 8:15 AM
    #70
    morcheez26
    morcheez26 Well-Known Member
    Brian
    New Orleans
    18 trd sport
    Same with any oem led lights... go look up prices to replace the headlight on a q50 :annoyed:
    Inferno__Taco and kakwvu[QUOTED] like this.
  11. Apr 7, 2019 at 8:24 AM
    #71
    MESO
    State of Jefferson
    To their defense, it would be close to impossible for the end user to service the LED. It is usually tucked deep inside the projector with a chip on board.(entire projector has to be disassembled) NOT like your typical "drop in" led H9/H11/etc bulb style.
    Pic for reference
  12. Apr 7, 2019 at 8:27 AM
    #72
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    The benefit of having one of the first units :)
  13. Apr 7, 2019 at 8:32 AM
    #73
    MESO
    State of Jefferson
    I have a ton of stuff planned to modify on these, but I have to restrain myself until production assemblies are shipping out to customers.
    Swapping out projectors will be the first on my list. I know.. crazy to spend $1200 only to rip them apart.. but that's what I like to do:D
  14. Apr 7, 2019 at 8:34 AM
    #74
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    If it’s not broke, break it :)
  15. Apr 7, 2019 at 8:37 AM
    #75
    MESO
    State of Jefferson
    exactly!
  16. Apr 8, 2019 at 4:50 AM
    #76
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    Inferno__Taco likes this.
  17. Apr 9, 2019 at 2:09 PM
    #77
    ohgeezTRD
    ohgeezTRD IG: liftedbro_lifted
    Seattle, Wa
    2019 Super White Tacoma TRD OR Prem/Tech Package
    Baja Designs, Cali Raised, CBI, Prinsu, Rotopax, Southern Style Offroad, King Suspension, Kibbetech, Stealth Custom Series, BFG, TRD, Undercover.
  18. Apr 9, 2019 at 11:03 PM
    #78
    bfaris1
    bfaris1 Well-Known Member
    Brian
    2018 White TRD OR
    6112 #700/5160 w/ Wheeler’s AAL RCI Skids Front to back RCI sliders SSO Slimline (Hi-clearance soon) Sungtop Various other crap
    What projectors do you plan to swap to once you can?
  19. Apr 9, 2019 at 11:09 PM
    #79
    MESO
    State of Jefferson
    Triple Morimoto MLED. I have a set in my T4R retro and they are pretty damn impressive. Color, cutoff, and beam.
  20. Apr 10, 2019 at 5:44 AM
    #80
    Tacoma2020
    Tacoma2020 Well-Known Member
    I certainly would not buy these until they can be compared to the 2020 Tacoma enclosures.
    House Forsaken and kakwvu like this.
