Morimoto mini stage 3 kit (H1) install help
Discussion in 'Lighting' started by JTaco386, Jun 1, 2012.
  1. Jun 1, 2012 at 7:34 PM
    JTaco386
    JTaco386 [OP] Well-Known Member
    JT
    Fort Rucker, AL/ Home: Port Orange, FL
    13 DCSB TRD Sport 4x4
    Today I Was working on installing my retrofitted headlights with the morimoto mini stage 1 kit. I hooked everything up properly, ballasts, relay, bulbs, etc. I go to turn the headlights on and the driver side lit up but the passenger side didn't.
    I swapped the ballasts around thinking that this might be the problem and I went to turn them on and nothing lit up...so I swapped them back to where I had them originally, turned them on and nothing...ugh!
    Any ideas as to this problem? Anyone else running this kit? Thanks for any help.
  2. Jun 1, 2012 at 7:48 PM
    JTaco386
    JT
    That seems like what would of caused it, but I checked the fuse on the driver side ballasts after I swapped them and it looked ok, I didn't see a fuse on the other ballast. I will recheck in the morning, it's too dark out right now. I hope it's the fuse, that would be a simple fix. I wired everything where they were supposed to go according to the labels on them.
  3. Jun 1, 2012 at 7:52 PM
    JTaco386
    JT
    I appreciate your help....the fuses seems like the logical thing as to why theyre not working. I'm going to double check it.
    Hopefully some other members have this kit and can help me out.
  4. Jun 1, 2012 at 7:55 PM
    JTaco386
    JT
    That's where I ordered from, I'll give them a call tomorrow, hopefully they're open. Thanks again!
  5. Jun 3, 2012 at 10:10 AM
    JTaco386
    JT
    I got everything working except the high beams do not come on...any ideas?
  6. Jun 3, 2012 at 10:14 AM
    BuzzardsGottaEat
    BuzzardsGottaEat "Pick up some speed.. You'll make it."
    Chaz
    South Dakota
    93 Pickup 4x4 [22R-E] 5MT
    OME suspension, LCE Performance parts, Konigs, etc. [see build]
    I'd call up TRS when they're open or maybe pm some of the members on here who do retrofits for people, only thing I've read to do is swap ballasts and you've already done that. GL
  7. Jun 3, 2012 at 10:19 AM
    JTaco386
    JT
    Thanks, I'll just wait to call them. I'm inpatient and want these to work ASAP lol.
  8. Jun 3, 2012 at 10:22 AM
    BuzzardsGottaEat
    Chaz
    South Dakota
    Pm AsianAnts? also I think it's Andrew from TRS is a member here now, check the round 8 group buy, he's in that thread, maybe he can help ya
  9. Jun 3, 2012 at 10:25 AM
    JTaco386
    JT
    Will do, thanks!
