Morimoto Mini Stage III Kit (H1) step by step with pics!
Discussion in 'Lighting' started by stattonmw, Feb 28, 2012.
  1. Feb 15, 2016 at 11:36 AM
    #201
    awoit
    awoit Well-Known Member
    CA
    08 TRD, SR5
    Got it, last thing I'm curious about is how to run the wires coming off the solenoid through the boot? Do you cut or drill a small hole for where they can come out?
  2. Feb 15, 2016 at 3:18 PM
    #202
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    A tiny slit in the rubber boot works for me
  3. Feb 21, 2016 at 10:00 AM
    #203
    cmyersgo
    cmyersgo Well-Known Member
    Carter
    Queen Creek AZ
    So I'm getting ready to do this mod and have read through most of this thread but haven't found the answer I'm looking for. I watched a video on YouTube where a guy did this mod to a newer tacoma 2011-2015 headlights and he had to grind down back of the headlight in order to mount the projectors. Do I have to do this with my 07 headlights or is that just with the newer style ones?
  4. Feb 21, 2016 at 11:26 AM
    #204
    TRSJimmy
    Jimmy
    Gainesville, GA
    This is what Andrew said
  5. Feb 21, 2016 at 2:55 PM
    #205
    cmyersgo
    Carter
    Queen Creek AZ
    Okay I believe I have the smaller washer.. thanks!
    TRSJimmy[QUOTED] likes this.
  6. Mar 17, 2016 at 5:02 PM
    #206
    TRSJimmy
    Jimmy
    Gainesville, GA
    There is definitely dremel. Well just the rear flange
  7. Mar 17, 2016 at 5:04 PM
    #207
    TrapComa
    TrapComa Well-Known Member
    Mason
    Cedar Park, TX
    07 Indigo Ink LT PreRunner
    Wannabe prerunner, wannabe overlander
    Even on 2005-2011? Also I'm planning on doing Mini H1 if thats any different. I have no idea how any of this stuff works
    edit: thought this was a d2s. disregard that last part
  8. Mar 17, 2016 at 5:12 PM
    #208
    TRSJimmy
    Jimmy
    Gainesville, GA
    Actually, I think you don't have to with mini H1 7.0s since the shaft is longer. I'm not sure though
  9. Apr 10, 2016 at 7:39 PM
    #209
    Jmad1997
    Jmad1997 Well-Known Member
    2005 TRD sport long bed 6" fab tech lift
    Great write up I'm about to start mine now!:bananadance:
    TRSJimmy likes this.
  10. Apr 11, 2016 at 3:29 AM
    #210
    TRSJimmy
    Jimmy
    Gainesville, GA
    Good luck and take your time!
  11. Mar 15, 2019 at 11:32 PM
    #211
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Glad to see another mini h1 build. Just ordered my parts
  12. Mar 15, 2019 at 11:36 PM
    #212
    20somethingwidataco
    Will
    Washington State
    What's your light output like? I might use my current set and build up a d2s build
