Morimoto Mini Stage III Kit (H1) step by step with pics!
Discussion in 'Lighting' started by stattonmw, Feb 28, 2012.
  1. Jul 4, 2012 at 11:26 AM
    #41
    BG KY Jets Fan
    BG KY Jets Fan Dagger Taco *****
    Joe
    Bowling Green Ky
    2011 TRD Sport 2WD DC
    Roof Rack, TRD skid plate, TRD cat back exhaust, Pioneer AVIC-930BT, subwoofers, Avid bar, Westin side steps, FLYZEYE strip, and Blacked out Badges. More to come....
    Whats the best way to align the headlights? The plug and play ones have that nut that holds the projector in. Does that basically line it up after tightening it down? I really want to do this mod and I have an extra set of lights, but I need more confidence to go with it!
  2. Jul 4, 2012 at 3:18 PM
    #42
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    its a halogen bulb in the shape of a ring and u either mount it in front of the shroud or behind the shroud, depending on which shroud choose, and wire it in and there is your angel eye. Very simple to do
  3. Jul 4, 2012 at 6:23 PM
    #43
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
    not plug and play as i found out.
    yes they do plug in without cutting your lights up, but the alignment ring is not right. You will need to do some cutting on the little tabs that the alignment ring sits next to. once you get the projectors in dont seal them up, its hard to do but resist. You need to install the ballasts and all the wiring first and then put the lights in the truck without the lenses on and fire em up and check the horizontal alignment. it will most likely be off about 20 degrees cocked clockwise.
  4. Aug 14, 2012 at 11:22 PM
    #44
    ronjon04
    ronjon04 Member
    Orlando
    09 silver DC SB TRD Off Road 4x4
    -Fog Lights on anytime -KN Filter -Satoshi Grill -Black out Projection headlghts (Morimoto) -HID fogs -Bilstein shocks with 2" lift and add-a-leaf
    I just finished putting my mini D2S projectors together. Was wondering if the back where the projector sits in the housing gets recovered? The original bulb had that rubber boot around it and was concerned that it being open like that in the back might get moisture inside. Anyone do anything about this? Thanks! Will probably be posting my retrofit here once I get the final pics ;)
  5. Aug 14, 2012 at 11:52 PM
    #45
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    i just zip tied it shut
  6. Aug 15, 2012 at 12:00 AM
    #46
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    So i read somewhere that people used RTV sealent to connect the shrouds to the housing. is this ok? or should i use something like jbl weld?
  7. Aug 15, 2012 at 12:02 AM
    #47
    wrxRome
    Brandon
    they have 4 screw holes to just screw into.
  8. Aug 15, 2012 at 12:06 AM
    #48
    CayucosTacoma
    2004 Double Cab 4x4
    shrouds do?
  9. Aug 15, 2012 at 12:44 AM
    #49
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    I didn't reuse the rubber boots, and so far (two years) no problems. That said, I'm in a Prerunner, so light off-road and no deep water, so YMMV.
  10. Aug 15, 2012 at 7:05 AM
    #50
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I cut mine up so they fit and put them on just to be sure, and with high humidity I haven't had issues either... only took about 1min per light so it seemed like cheap insurance heh.
    I used the black silicon you can get from lowes (high temp stuff). I beat the hell out of my truck and do some fast desert stuff and hard hitting bump stops... they haven't moved at all. If you use the cheap RTV stuff from Autozone or what not... they fall out constantly.
  11. Aug 15, 2012 at 10:29 AM
    #51
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
  12. Aug 15, 2012 at 11:22 AM
    #52
    ronjon04
    ronjon04 Member
    Orlando
    was thinking about doing this. Thought it was kinda weird that the boot was attached to the original light.... never seen that before.
  13. Sep 5, 2012 at 6:01 AM
    #53
    REDTRD
    REDTRD Woods & Water Edition
    Anthony
    Western NC
    07 DCSB SR5 4x4
    Click my build thread!
    subbed for reference!
  14. Sep 8, 2012 at 9:43 PM
    #54
    Socalrunner
    Socalrunner Toyota Its Like A Jeep Thing Only Better
    Glendora
    2010 TRD Offroad 4x4 DCSB
    Icon Coilovers
    Hey man, Im curious to know what part of the shroud you cut down to let them sit so low.
  15. Sep 9, 2012 at 6:18 PM
    #55
    YFZ450MOE
    YFZ450MOE When you blow off steam you get an eyepatch
    Moe
    Auburn, WA / Roseburg, OR
    09 white DCSB TRD (it's getting there)
    Icon Extended Travel 2.5" Coil Overs All-Pro U-Bolt Flip Kit Bilstien Rear Shocks Fabtech Add-a-Leaf Icon Upper Control Arms All-Pro Rear Bumper w/ Wrap Arounds & Hitch with custom LED plate light BHLM and Morimoto III D2S retrofit Satoshi Grill 2 Hella Black Magics behind Grill Bestop Supertop BAMF sliders
  16. Sep 9, 2012 at 7:07 PM
    #56
    YFZ450MOE
    Moe
    What looks better for painting the bezel:
    Gloss black
    or a Satin black
    I have done Gloss black on my last 2 and am somewhat happy with the outcome, but was wondering if anyone has seen both in person and what they thought looked better?
  17. Sep 9, 2012 at 7:20 PM
    #57
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The Depo black housings are satin, and that's what I used for my reflector bowls.
    After baking, the satin glossed up nicely on the bowls. I'd be worried that a gloss would be too much.
    Remember, you'll be looking at them through the clear lens, which will clean up the appearance. Gloss paint will add double reflections inside and might look odd.
  18. Sep 9, 2012 at 7:24 PM
    #58
    YFZ450MOE
    Moe
    Thats what i was thinking, my gloss black bezels in the light i have now seem really reflective. Does the satin have a more black look? More so than a gloss? I am thinking of doing a satin now. Thank you very much rich!
  19. Sep 9, 2012 at 7:36 PM
    #59
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    This is satin black . . . .
  20. Sep 9, 2012 at 8:05 PM
    #60
    YFZ450MOE
    Moe
    Thanks! Def thinking satin!
