Morimoto Mini Stage III Kit (H1) step by step with pics!
Discussion in 'Lighting' started by stattonmw, Feb 28, 2012.
  1. Sep 22, 2012 at 4:36 PM
    #61
    YFZ450MOE
    YFZ450MOE When you blow off steam you get an eyepatch
    Moe
    Auburn, WA / Roseburg, OR
    09 white DCSB TRD (it's getting there)
    Icon Extended Travel 2.5" Coil Overs All-Pro U-Bolt Flip Kit Bilstien Rear Shocks Fabtech Add-a-Leaf Icon Upper Control Arms All-Pro Rear Bumper w/ Wrap Arounds & Hitch with custom LED plate light BHLM and Morimoto III D2S retrofit Satoshi Grill 2 Hella Black Magics behind Grill Bestop Supertop BAMF sliders
    Is the solenoid for switching between high and low supposed to be really loud? I just got mine in the truck so i can align them and switched em to make sure they work and was really suprised at how loud the clicking was.
  2. Oct 9, 2012 at 10:39 AM
    #62
    stattonmw
    stattonmw [OP] Well-Known Member
    Statton
    Redmond, WA
    2014 DCLB Tacoma TRDsport
    5" RCD Lift TOYO ATII Extreame 295/70R18 XD Addict wheels Factory toyota side steps TRD exhaust
    I know mine make some noise, I never really paid too much attention to it. I wouldnt worry about it too much but if it bothers you I am sure matt at TRS could answer this a lot better than I could.
  3. Oct 9, 2012 at 10:43 AM
    #63
    stattonmw
    Statton
    Redmond, WA
    Just to clerify this is true for the mini gatling shroud but not the standard one which is much larger. it used a shroud centric ring that needs to be glued to the shroud and then again to the projector. I used that standard shroud in my retro.
  4. Oct 9, 2012 at 10:46 AM
    #64
    stattonmw
    Statton
    Redmond, WA
    I cut the inner piece of the shroud that look like tabs which fit into the centric ring. prolly has just over a quater inch left... I just fitted the centric ring and used a sharpie to draw an even line then cut it with a dremel. I had to repeat this process twice to get it to the height I wanted and checked fitment after the first cut, it sits in there with the perfect amount of room.
  5. Oct 11, 2012 at 5:42 PM
    #65
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Can anyone tell me how the mini gattling shrounds attach to the H1 projectors? I've got them in my hands and I'm not seeing it... :confused:
  6. Oct 15, 2012 at 11:07 PM
    #66
    jeverich
    jeverich Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
    Hey all, just a heads up...
    Looks like TRS revised the Morimoto Mini's with the "5.0 Version".
    I installed the original Mini's about a year ago, only to have to replace them with FXRs 6 months after my install. Due to the fact that I'm running 55 Watts on my rig, the Mini's lacked adequate surface area to dissipate the heat; the reflective coating inside the projector bowls melted/flaked off. TRS was really cool about refund/exchange, and acknowledged that it was a known issue...even have me a bitchin discount off of a set of FXRs...
    Anyhow. I digress.
    The Mini's were super easy to install, and provided excellent performance to price. But the cheap pot metal retaining ring for the bulb corroded and was fused to the projector housing. Had to get the cutting wheel on the Dremel out and cut the ring off the threads. Wasn't a big deal, since I was replacing the whole setup anyways.
    Really feel like that cheesy bulb retainer setup really kills an awesome product. I had issues with the retainers loosening up on me, also.
    Basically, what I'm trying to say is think about putting some kind of anti-seize on the threads when you assemble. Otherwise, you may be shit out of luck when it comes time to replace a bulb.
  7. Oct 16, 2012 at 5:15 AM
    #67
    Pugga
    Massachusetts
    So you're saying you have to unscrew something just to change a bulb?!?! :confused:
    You're correct about the version 5 on the H1 minis. V5 has a foreground limiter and supposedly a better solenoid (that might have been updated in one of the previous versions).
  8. Oct 16, 2012 at 8:27 AM
    #68
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    yeah just the final ring on the back, not the lock ring but the one that secures the bulb.
  9. Oct 16, 2012 at 8:34 AM
    #69
    Pugga
    Massachusetts
    I suppose if I actually got to doing my retrofit instead of staring at the parts, this would all make sense, huh? :rolleyes:
  10. Oct 16, 2012 at 8:41 AM
    #70
    CayucosTacoma
    2004 Double Cab 4x4
    yes it would haha
    there's two rings that screw on the back of the retrofit projector. The first one secures the projector to the headlights, and the second one secures the bulb into the projector. When you see it in person it will make a lot more sense.
  11. Oct 16, 2012 at 7:10 PM
    #71
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Not sure about the Mini-H1, but the D2S set no longer uses the potmetal rings.
    They are now aluminum.
  12. Oct 16, 2012 at 7:37 PM
    #72
    YFZ450MOE
    Moe
    Is there a way to test the ballasts? I'm pretty darn sure one went out on me
  13. Oct 16, 2012 at 7:40 PM
    #73
    Rich91710
    Rich
    Los Angeles
    08 Base
    Double check your grounds on the harness. These things are touchy for a good ground.
    Failing that, swap right and left and see if the problem follows.
    If it doesn't follow the ballast, the swap the lamps.
  14. Oct 16, 2012 at 11:30 PM
    #74
    YFZ450MOE
    Moe
    It followed to the other side leading me to believe it is the ballast for sure. Is there anyway to electrical check it besides resistance?
  15. Oct 17, 2012 at 6:36 PM
    #75
    Rich91710
    Rich
    Los Angeles
    08 Base
    Not really... there's a moderately complex circuit in there.
    Premature failures happen... shoot a note to Andrew.
  16. Oct 18, 2012 at 10:38 AM
    #76
    stattonmw
    Statton
    Redmond, WA
    After about a year I am having issues with one of the solenoids after using the high beams the one projector changes the cut off line somehow to where it is way below the original spot... good news, it goes back up after going over several hard bumps.
    Called TRS they said I need to adjust the tabs on the shield, wow f'ing great I get to do a whole nother tear down because I have hours of time to fix what should work without me modifying it!
  17. Oct 21, 2012 at 4:57 PM
    #77
    Pugga
    Massachusetts
    Call me silly but I got my retrofit done and I'm not seeing what I have to unscrew to change out the bulbs... The bulbs are held in with a retainer clip, similar to the stock headlight unless I did something really wrong... :confused:
  18. Oct 21, 2012 at 5:08 PM
    #78
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    mine do that too sometimes, along with whenever i use my highbeams they always stick a little bit so it makes the cutoff line look yellow, but after driving for a few miles it normally goes back. I just dont use my high beams that much
  19. Oct 21, 2012 at 5:41 PM
    #79
    Rich91710
    Rich
    Los Angeles
    08 Base
    What projectors did you use?
  20. Oct 21, 2012 at 5:47 PM
    #80
    Pugga
    Massachusetts
    Morimoto Mini H1
