Morimoto Mini Stage III Kit (H1) step by step with pics!
Discussion in 'Lighting' started by stattonmw, Feb 28, 2012.
  1. Oct 21, 2012 at 8:25 PM
    #81
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    H1 bulbs are usually held in with a retaining clip or spring from my past experiences but the D2S bulb is held in by a retaining nut that threads on.
  2. Oct 21, 2012 at 8:42 PM
    #82
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ahh... going back to the OP I see that.
  3. Oct 22, 2012 at 5:04 AM
    #83
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Good, so I didn't screw anything up. I was getting worried when people were talking about some sort of nut holding the bulb in place!
  4. Oct 22, 2012 at 12:54 PM
    #84
    stattonmw
    stattonmw [OP] Well-Known Member
    Statton
    Redmond, WA
    2014 DCLB Tacoma TRDsport
    5" RCD Lift TOYO ATII Extreame 295/70R18 XD Addict wheels Factory toyota side steps TRD exhaust
    Nope! you are good to go, sounds like you have it the way it should be. Like mentioned above the D2S have that retaining screw on ring and the H1 is much like the clip that was used for the oem bulb set up.
  5. Oct 24, 2012 at 8:54 AM
    #85
    Runnerstrom28
    Runnerstrom28 Well-Known Member
    Derek
    Summerville, SC
    05 Black Decepticon DCLB
    Decepticon emblem, 3inch lift, 33inch trail grapplers and XD series Monster rims, Dual Exaust 40 series flowmasters, 18% tint around and 35% tint on front windsheild, 55w 10000K HIDs, blacked out taillights, pioneer deck, kicker 750 mono amp pushin a memphis 12
    hey guys im interested in doing this to my truck but i want to add the Halo ring....has anybody done that and is it difficult?
  6. Oct 24, 2012 at 12:00 PM
    #86
    parboy
    parboy FORE!
    Brian
    Sherwood, AR
    '13 MGM DCSB 4x4 TRD sport, Tow and Entune
    Tonnopro tonneau cover, Weathertech digital fit mats, Magnaflow 18" muffler with black exhaust tip, blacked out badges/emblems, Passport 9500ix, Pop & Lock PL8521, EZdown tailgate mod, 17" KMC XD addicts, 265/70/17 Nitto Terra Grapplers, OME 884 springs, Bilstein 5100's at zero, BHLM, FX-R retrofit, 80mm and 110mm morimoto rgb halo's with Bluetooth control, Raptor style led's in grill, LED's for dome, maps, reverse, license plate, parking lights, switchback DTRL's, ultra-gauge, Kenwood DNX690HD, Hertz HDP4, Hertz HSK165's, Memphis 12" in custom box, Black/Grey Roadwire leather kit with seat heaters, cool white interior led's from oznium.com, 20" AVEC dual row light bar in lower bumper, 19" AVEC single row light bar in grill,
    Not difficult at all to add the halo's. It's just a little extra wiring and securing the halo rings to your shroud. I used jb weld steel putty to secure mine and wired them to switched 12v so they are always on when the truck is on.
  7. Oct 25, 2012 at 11:54 AM
    #87
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Any concern for rust on the jb weld?
  8. Oct 25, 2012 at 11:58 AM
    #88
    08navytrd
    08navytrd Well-Known Member
    Kenneth
    Italy
    08 Prerunner TRD Sport
    K&N CAI Flowmaster super 40 dual exhaust, Upgraded 6 disc from factory single disc, mag light attached to driver door, bilstein 5100 set at highest up front and 5100s in the rear, 1.5'' add a leaf in rear, aftermarket black headlights, 35w hids 6000k low beams, 4 85w HID off road lights 6000k color,
    Subd nice write up
  9. Oct 25, 2012 at 12:12 PM
    #89
    parboy
    parboy FORE!
    Brian
    Sherwood, AR
    No concern at all. Quote from the jb weld site:
    SteelStik is a hand-mixable, steel-reinforced, non-rusting epoxy putty that quickly repairs or rebuilds anything made of metal. After mixing, it forms an industrial-strength polymer compound that can be molded into shapes or used to build up, patch and repair steel components. SteelStik sets in 3-5 minutes and after 60 minutes, can be drilled, tapped, machined, ground, filed and painted. SteelStik cures to a dark grey color, is rated at a tensile strength of 900 PSI and will withstand temperatures up to 300ºF.
  10. Oct 26, 2012 at 12:16 PM
    #90
    WiR3D
    WiR3D Well-Known Member
    James
    Clearwater, FL
    06 PreRunner SR5 TRD DCSB
    Bumb for sub
  11. Nov 10, 2012 at 2:42 PM
    #91
    willimatic
    willimatic Well-Known Member
    Will
    Rancho Murieta/Folsom, CA
    06 Tacoma AC 4x4 Sport
    For those of you that bought an extra set of headlights, can you adjust the aim vertically after everything is sealed up and put back on the truck? I see that everyone rec'd testing for horizontal before you seal the lights back up, or glue the shroud to the reflector bowl, but no one mentions testing for vertical at this point.
  12. Nov 10, 2012 at 2:44 PM
    #92
    Pugga
    Massachusetts
    Vertical and side to side is adjusted using the stock adjustment screws so you mess with that adjustment after everything is mounted for good. You need to get the cutoff horizontal before you seal the lights up.
  13. Nov 10, 2012 at 2:46 PM
    #93
    willimatic
    Will
    Got it, makes sense now. Thanks Pugga:D
  14. Nov 10, 2012 at 3:15 PM
    #94
    Pugga
    Massachusetts
    No problem, good luck!
  15. Nov 12, 2012 at 11:40 AM
    #95
    willimatic
    Will
    Has anyone ever seen pics with the mini gatling shroud in graphite? Curious to how the "glow" it says it provides will look.
  16. Nov 12, 2012 at 12:00 PM
    #96
    Pugga
    Massachusetts
    Eborgie has them. You can search through his photos to see what they look like. I'd say you could PM him but he won't be back by the time the current group buy has closed (he lives near me, that's the only reason I know that).
  17. Nov 27, 2012 at 1:53 PM
    #97
    willimatic
    Will
    I am playing around a bit with the projector and shroud before starting the project. I know the mini gattling and the H1 are suppose to screw in together. Has anyone had trouble getting the projector inside the shroud far enough to get the hole's aligned to screw in? Or am I just not using enough force to get the projector far enough inside the shroud to reach the holes?
    I have a few pics to show what I'm talking about. Also, did anyone's kit come with the screws for this, or did you have to go and buy them?
    Hope that makes sense.
  18. Nov 27, 2012 at 5:39 PM
    #98
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Are you sure you have them lined up correctly? The top and bottom have different widths. I think the bottom was the wider of the two, and it does fit on there pretty snug.
  19. Nov 27, 2012 at 5:46 PM
    #99
    Pugga
    Massachusetts
    ^^This, it's a snug fit. They will go together, it might take some light pressure (very light, don't go nuts with it). Make sure the holes are lined up properly.
  20. Nov 27, 2012 at 5:50 PM
    #100
    jerretxx
    jerretxx Some do, others talk
    Jerret
    North Carolina
    2017 DCSB Tacoma TRD Sport 4x4
    subbed! great write up!
