Morimoto Mini Stage III Kit (H1) step by step with pics!
Discussion in 'Lighting' started by stattonmw, Feb 28, 2012.
  1. Nov 28, 2012 at 10:34 AM
    #101
    willimatic
    willimatic Well-Known Member
    Will
    Rancho Murieta/Folsom, CA
    06 Tacoma AC 4x4 Sport
    Ya, I see the different widths and have that aligned correctly. Might just take a bit more force than I was using, don't want to break anything.
    I didn't get any screws though, so I'll have to go get those.
  2. Nov 28, 2012 at 1:20 PM
    #102
    stattonmw
    stattonmw [OP] Well-Known Member
    Statton
    Redmond, WA
    2014 DCLB Tacoma TRDsport
    5" RCD Lift TOYO ATII Extreame 295/70R18 XD Addict wheels Factory toyota side steps TRD exhaust
    I am sure if you call TRS they would be more than willing to send you some, I dont know why they wouldn't come without screws, kinda weird. But unless you are in a rush I would just do that!
  3. Dec 8, 2012 at 1:44 PM
    #103
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Could someone who has successfully wired the H1 kit take a picture of how they have everything connected? The only plug I has to assemble was the solenoid plug and I just did black to black, red to red. Everything else was pretty self explanatory I thought.
  4. Dec 8, 2012 at 2:06 PM
    #104
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    That's all there is to it.
    Be sure you have a GOOD ground.
    My passenger light wouldn't spark up. I unplugged the ballast from the harness and plugged in the spare connector, connected it to the headlight socket and it popped on.
    Went back to the harness, still no-go.
    Checked everything with my meter, seemed to be fine.
    I moved the ground from the radiator support to the air pump, problem solved.
    All of these adapter harnesses are made the same way... there's no reason the ballast ground shouldn't be run back through the harness to the relay box and provide one heavy gauge ground connection at the battery.
    I've installed 5 HID systems and I've had issues with one light not firing up on 3 of the 5 because of the stupid grounding issues.
    Stupid suggestion, but make sure you have the hi-lo connector connected to the solenoid and the power connector plugged into the ballast.
    Both use the same connectors... the connector with the short wire and a fork on the end (labeled "BATTERY -") plugs into the ballast.
    The connector with two smaller wires both running into the harness connect to the hi-lo pigtail.
  5. Dec 8, 2012 at 2:43 PM
    #105
    Pugga
    Massachusetts
    I'm going to pull the whole wiring harness out tomorrow and start over. There's got to be something stupid that I'm missing with this kit. Very frustrating :annoyed::annoyed:
  6. Dec 8, 2012 at 2:49 PM
    #106
    Rich91710
    Rich
    Los Angeles
    08 Base
    What is (or isn't) happening?
    Take it step by step... Connect the ballast directly to power to confirm that the ballasts and lamps are good.
    Connect the harness to the battery and the headlight socket and meter the harness outputs to confirm that you are getting power to the ballast connectors.
    Switch to high-beam, verify that you are getting power to the solenoid, and still getting power to the ballast connector.
    High beams, the red wires on all 4 connectors should be hot.
    Low beam, only two.
  7. Dec 8, 2012 at 2:51 PM
    #107
    Rich91710
    Rich
    Los Angeles
    08 Base
    And again... double check all of your grounds, and don't trust any of them.
    To confirm grounds, run a length of 14ga black from the passenger side to the body ground next to the battery, and connect all of the HID harness grounds to that instead of using the forks.
  8. Dec 8, 2012 at 3:00 PM
    #108
    Pugga
    Massachusetts
    But the solenoid uses the same ground as the rest of the system since the control box is grounded right? The low beams work so the ballasts are work so I'm assuming my grounds are good. I've also gotten into the habit of using the same ground with my test light as the system is question is using and it seems to ground well. I'm going to tear it all down anyways and recheck everything with a fine tooth comb. I'm at wit's end with this kit :mad:
    I'm grounded at that metal piece on top of the headlight, the one that goes across the width of the truck just in front of the radiator.
  9. Dec 8, 2012 at 3:12 PM
    #109
    Rich91710
    Rich
    Los Angeles
    08 Base
    Okay, both low beams work so yet, the harness grounds are solid.
    Do the low beams remain on when you switch to high beam, and you just don't get the barn door opening up?
    Double check the connectors on the projectors. I had some trouble getting the pins to seat properly. After connecting everything up, I ran a thin rod into the back of the connector to make sure the pins were seated, as two of them pushed back out when plugged in... the "top" of the pin where it crimps to the wire was pushed up flush with the edge of the housing/rubber.
  10. Dec 8, 2012 at 3:13 PM
    #110
    Rich91710
    Rich
    Los Angeles
    08 Base
    The harness relay ground, as well as the hi-lo solenoid ground, come from the original H4 socket. Only the ballasts need an external ground.
  11. Dec 8, 2012 at 3:20 PM
    #111
    Pugga
    Massachusetts
    Well, here's the thing. Everything worked perfectly for 2 weeks, hi beams, low beams, everything. Then, I flipped the high beams and everything went black. I went back to low beams, and they fired back up. It blew the 10A hi beam fuse. I replaced the fuse, then for 2 weeks, the low beams worked fine, and when I switched to high beams, they would just stay on low beams. TRS thought it was the controller box since I had power in all the places you'd expect, just not going through the controller box to cycle the solenoid for the the high beams. They sent me a new controller box , I swapped them out, now, the low beams work, but whenever I flip the high beams on, everything goes black and it blows the high beam fuse.
    I don't understand how they worked perfectly for 2 weeks, and now I can't chase my problem out. I'm resorting to a complete teardown and redo tomorrow. If that doesn't work, there will be halogens in the truck by the end of the weekend :mad:
  12. Dec 8, 2012 at 3:35 PM
    #112
    Rich91710
    Rich
    Los Angeles
    08 Base
    Interesting.
    Sounds almost like one of the solenoids has shorted.
    Build yourself a "tickler"... a 5a circuit breaker with some clip leads, and see if you trip it when you apply power directly to the solenoids.
    What happens if you just unplug the solenoids? Are you still blowing the high beam fuse then?
    Internally, the low beam hot applies power to the ballast relay.
    Switching to high beam, there is a delay circuit that momentarily holds the relay in while power switches over, so the high beam hot feeds exactly the same circuit in the relay box, but adds the connection to the solenoids.
    It's a very simple system.
  13. Dec 8, 2012 at 3:41 PM
    #113
    Pugga
    Massachusetts
    I'll try disconecting the solenoids and cycling the high beams tomorrow and see what happens. It's dark here now and raining, tomorrow is supposed to be nice and I want to tear the truck apart to run heated mirrors :D
    Thanks for the help Rich, I'll post back with the results. I hope I can get this figured out!
  14. Dec 8, 2012 at 4:03 PM
    #114
    Rich91710
    Rich
    Los Angeles
    08 Base
    Good luck Mr. Phelps!
  15. Dec 8, 2012 at 4:07 PM
    #115
    Pugga
    Massachusetts
    Thanks!
  16. Dec 8, 2012 at 5:49 PM
    #116
    Pugga
    Massachusetts
    Rich, do you know what colors on TRS's plug is supposed to receive what (ie, white is low beam power, blue is high beam power and black is ground, I made the colors up, just wondering if you knew).
  17. Dec 8, 2012 at 6:04 PM
    #117
    Rich91710
    Rich
    Los Angeles
    08 Base
    I'll try to remember to check tomorrow.
  18. Dec 8, 2012 at 6:12 PM
    #118
    Pugga
    Massachusetts
    Thanks, figure while I'm in there checking everything, might as well check that also.
  19. Dec 9, 2012 at 9:45 AM
    #119
    Pugga
    Massachusetts
    I just checked my plugs, here's what I have:
    Red wire - OEM high beam hot - Connects to TRS Red
    Red w/ Yellow - OEM low beam hot - Connects to TRS White
    White w/ Black - OEM ground - Connects to TRS Blue
  20. Dec 9, 2012 at 12:43 PM
    #120
    Rich91710
    Rich
    Los Angeles
    08 Base
    Okay... here's what I've got.
    I took the colors for the headlight socket from the passenger side, driver might be different for the low and high, but the relative positions on the socket are the same. High beam and ground are on opposite sides of the socket, low beam is in the "top" middle.
    Ground is going to be a white or white/black tracer.
    My TRS harness seems to have a brown wire on the ground.
    It sounds like your Blue and Red/Brown are reversed... that's why I included the landings on the white connector that plugs into the relay box.
