Morimoto Mini Stage III Kit (H1) step by step with pics!
Discussion in 'Lighting' started by stattonmw, Feb 28, 2012.
  1. Feb 6, 2013 at 9:11 PM
    #141
    DPCardoza
    DPCardoza Well-Known Member
    Yuba City
    06 PreRunner Sport Long Bed
    Forgot to update. Abot 3 days later I had a new contoller show up. Plugged it in and all is well. Sent back the old one, must have had a stuck relay or something.
  2. Feb 7, 2013 at 6:43 PM
    #142
    1YOTA6
    1YOTA6 1YOTA6
    Kyle
    Rochester, NY
    11 Db cab LongBed Tacoma 4x4 Sport
    ReadyLift 2.75 leveling lift, 1.5inch spider trax wheel spacers, Plasti-Dip wheels and front grill, Under carriage reverse spot lights, OTTRA Switches, wether tech floor mats, Toyo Open Country AT 285-70r17, on the waiting list for HomerTaco Grill :)
    good info to soak in. I have to replace everything so it sounds like i need to get new aftermarket headlight assembly aswell as this kit...
    any suggestions on good websites that have a good set of headlights to tear into?
  3. Feb 7, 2013 at 8:03 PM
    #143
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Amazon.
    About $180 shipped for a pair of Depo housings.
  4. Feb 8, 2013 at 11:12 PM
    #144
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    How are the quality of those?
  5. Feb 8, 2013 at 11:15 PM
    #145
    Rich91710
    Rich
    Los Angeles
    08 Base
    Very happy with mine.
    Identical to OEM.
    Depo is generally the supplier that body shops use.
  6. Feb 8, 2013 at 11:38 PM
    #146
    Drunknsloth
    Retribution
    South West
    Sweet. I might have to go with these if I do a retrofit
  7. Feb 8, 2013 at 11:55 PM
    #147
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    DEPO = good to go
  8. Apr 27, 2013 at 10:59 AM
    #148
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Can anyone tell me how to get the solenoid out of the H1 projector? :eek: I haven't had high beams since about 2 weeks after I did my retrofit and need to get the solenoid working. I have the projector out but it's not making sense how to tear it apart and I don't want to break anything.
  9. Apr 27, 2013 at 11:24 AM
    #149
    Pugga
    Massachusetts
    NVM, I got them apart and as of tonight, I'll no longer be running projectors. In pulling them apart, I've found out just how far TRS's QC has dropped and I'm frustrated beyond where I'm willing to repair the problems. The projectors will be put in my motorcycle that sees very little use or sold off cheap, they apparently can not handle being in a daily driver.
  10. Apr 27, 2013 at 1:47 PM
    #150
    Rich91710
    Rich
    Los Angeles
    08 Base
    :confused: Pictures?
    Did the reflector melt, or what's the problem?
  11. Apr 27, 2013 at 4:59 PM
    #151
    Kavik
    Kavik Kavik
    Texas, DFW
    Not your everday 5 lug
    Lowered: 3 inch drop blocks (Beefed Taco),Satoshi Grill, Morimoto bi-xenon H1 Retrofitted headlights, Flowmaster exhaust, Blue LED interior and exterior, blue LED dome light, Anzo black LED taillights, Hifonics Brutus 1100w Mono Block, Bazooka 300w Amp, LED license plate lights. Lifited: Fat Bob's rear shocks, Fat Bob's 3" spacer and rear AAL, Nitto Terragrapplers, weldertaco wrap around rear tube bumper, TrailWorx Fab tube front bumper
    I would call them up, they have great customer service.
  12. Apr 27, 2013 at 5:33 PM
    #152
    Pugga
    Massachusetts
    I don't have pictures (I don't have a good enough camera to take a picture of the chrome, it comes out looking like a flash) but the chrome is bubbling and peeling.
    I know, TRS has always done right by me, this is in no way a reflection on them. I did send them an e-mail since their closed today. So far I've had a controller box go, then my driver's side solenoid froze, then the passenger side started sticking in high beam. TRS sent me a new driver's side solenoid a while back but it was winter so I'm just getting around to putting it in and I was going to sand the passenger side solenoid because I heard they can get burrs on them and that can cause the sticking. I got everything pulled apart and then I found the bubbling. The projectors have a 3 year warranty on them so we'll what TRS does.
    Here's the thing though, TRS is closed on the weekends and I need my truck on Monday. I'm not really feeling putting everything back together with what I know is a broken projector and will need to be torn down again. I just don't have the time to keep messing with these lights so I'm probably going to convert them back to halogen, deal with TRS with the warranty and possibly put the projectors in the motorcycle.
    Once again, this is not a knock on TRS, their customer service has always been great and they've done a good job taking care of me so far. I think I've just had horrible luck with my kit :(
  13. Apr 27, 2013 at 9:20 PM
    #153
    jeverich
    jeverich Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
    Same deal.. On set # 3 of projectors, if this set dies on me it's back to conventional halogens.
    I know some others have given input on my situation before on here..
    Yes, I'm running 55 Watts - first set of Mini's died on me after about 10 months - chrome plating burned off. TRS sold me a set of FXRs to remedy the issue - they lasted 9 months.
    Took about 6 emails back and forth to get them to honor the warranty - ended up getting a set of new bowls for them. One of which the chrome plating is already chipped off in the corner. They acknowledged there was a poor manufacturing run in FXRs around the time that mine shipped out...
    I'm torn between going to 35 Watt ballasts; which will hopefully prolong the lifespan of projectors or just waiting to see how long these will last.
    Honestly, if these die I'm going back to halogen. Not worth the headache in my opinion. Yes, they are awesome when they're functioning, but the suck when they don't. I can't afford to have crappy headlights.
    Others have suggested limiting use of HID retrofitted headlights to prolong life expectancy.. They're headlights. How do you "limit use".
  14. Apr 28, 2013 at 6:16 AM
    #154
    Pugga
    Massachusetts
    I guess I'll 'limit use' by putting them in my motorcycle that only sees about 5,000 miles a year :cool:
    I honestly didn't mind just having the low beams but I can't pass inspection that way. I've got aftermarket lights that I use for my high beams on back roads anyways but I can't get a sticker like that. I'm going back to halogen until I get the warranty stuff worked out then I'll decide if I want to take my lights apart again for another go with the projectors or just do something else with the projectors. At this point, I'm just glad I didn't paint the reflector bowls and that I kept the halogen reflector pieces.
  15. Apr 30, 2013 at 7:25 AM
    #155
    Pugga
    Massachusetts
    Since I started my rant here, I figure I'll update as the process moves forward. I called TRS to follow up on the e-mail I sent over the weekend. As usual, their customer service is top notch. Zach couldn't believe all the issues I'm having with my kit and said it's generally a very nice setup so I guess I just have bad luck :eek: I need to take pictures of the reflector bowl to send to them to start the warranty process. I'll upload the pictures once I figure out how to take a good picture of a concave mirror :confused:
  16. Apr 30, 2013 at 9:53 AM
    #156
    stattonmw
    stattonmw [OP] Well-Known Member
    Statton
    Redmond, WA
    2014 DCLB Tacoma TRDsport
    5" RCD Lift TOYO ATII Extreame 295/70R18 XD Addict wheels Factory toyota side steps TRD exhaust
    wow what a hassel...
  17. May 3, 2013 at 5:33 AM
    #157
    Pugga
    Massachusetts
    Tell me about it... I sent pictures to TRS, only one of the projectors had the bubbling. The pictures are about as clear as mud, the only way you can tell there is a bubble is because the light distorts at that spot. Taking a picture of a reflector bowl apparently is not an easy thing to do :eek: We'll see what they say, I hope to have a response back from them sometime today.
  18. May 3, 2013 at 5:39 AM
    #158
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    In the end, 50w components do shorten the life of the parts, but since customers want them, we do still offer them. We'll definitely do our best to help sort it all out regardless of the situation!
  19. May 3, 2013 at 5:50 AM
    #159
    Pugga
    Massachusetts
    I'm running XB35 bulbs and 35W morimoto ballasts. I think I'm just having bad luck with this kit. :eek:
    So far, Zach at TRS has been great. I spoke with him on the phone earlier this week and just followed up with pictures last night (the delay so far as been my fault, got tied up with work). He's been apologetic and assures me that what I'm experiencing with the H1 kit is far from the norm.
  20. May 3, 2013 at 5:53 AM
    #160
    TRSAndrew
    ATL
    Yeah that's definitely abnormal for a Mini H1 setup. We'll get you all taken care of!
