Morimoto projectors installed!
Discussion in 'Lighting' started by Itsaerokyo808, Jun 6, 2017.
  1. Jun 7, 2017 at 2:05 PM
    #41
    TRD_Mike
    TRD_Mike Well-Known Member
    Pacific Northwest
    2015 DCLB TRD Sport - Gray
    YDCtaco likes this.
  2. Jun 7, 2017 at 2:06 PM
    #42
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    Listen I'll do the BHLM for $200 with the set of housings I have and you just send me your stocks back
  3. Jun 7, 2017 at 2:06 PM
    #43
    TacomaArto
    TacomaArto Well-Known Member
    Wisconsin
    2015 White DCSB SR5
    Is or was he associated with @RAD ?
    Build page looks copy/pasted from theirs. Just curious...
  4. Jun 7, 2017 at 2:20 PM
    #44
    LSC15
    Logan
    2008 TRD D-Cab
    No just because I build similar tables to help my customers understand doesn't mean I copied and pasted. Good try though
  5. Jun 7, 2017 at 2:21 PM
    #45
    LSC15
    Logan
    2008 TRD D-Cab
    So I apologize from my end buddy. What you wanna do going forward
  6. Jun 7, 2017 at 2:23 PM
    #46
    LSC15
    Logan
    2008 TRD D-Cab
    Been doing this longer here than rad
  7. Jun 7, 2017 at 4:31 PM
    #47
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    But with that being said...thats also ALL you need to get your projectors, HID kit, and all electronics needed. @jeff b, Im going to retro a local guys 2006 headlights with paint and projector install. Im gonna make a freakin write up just for your ass.
    TRD_Mike[QUOTED] likes this.
  8. Jun 8, 2017 at 5:38 AM
    #48
    Itsaerokyo808
    Itsaerokyo808 [OP] Active Member
    Darin
    Oahu, Hawaii
    2015 BR Xrunner
    Djm 3/3 drop
    Sorry forgot to mentions specs
    All purchased from theretrofit source during Memorial sale
    It's a morimoto mini h1 7.0 projector kit
    Mini turbine shrouds
    Xb35w ballast
    Xb5500k bulb
    Motocontrol h4/9003 harness
    110mm can switchback halos
    I went with the h1 over the d2s for two reasons
    I loved the look of the mini turbine shroud which only fits the mini h1 projectors
    2nd is for its sheer output. After looking around and digging up lots of dirt, the h1 7.0 may not be as sharp and clean as the d2s 4.0, but it definitely packs a punch in light output
    Zac of all trades and TRD_Mike like this.
  9. Jun 8, 2017 at 5:59 AM
    #49
    Itsaerokyo808
    Darin
    Oahu, Hawaii
    2015 BR Xrunner
    Djm 3/3 drop
    Few tips I could mention about the whole process
    When baking I did 260 degrees with the oven on for 7mins. Worked like a charm. Even after pulling it out of the oven the headlight seemed pretty solid and no where near melting.
    I honestly felt that if I had turn off the oven I woulda just wasted time having to do it over again just to get the butil soft enough
    Find a way to mask your headlight and bumper so you don't scratch anything while removing the headlight
    I scratched mines up a bit but luckily I was able to polish it out
    Zac of all trades likes this.
  10. Jun 8, 2017 at 6:02 AM
    #50
    TRD_Mike
    Pacific Northwest
    Hey if you remember, try to tag me in this write up you're going to do. I'm going to be doing the mod in the next month or so.
    Coot83[QUOTED] likes this.
  11. Jun 8, 2017 at 6:05 AM
    #51
    TRD_Mike
    Pacific Northwest
    Thanks for the info. At 260 degrees for 7 mins, were you able to pull them apart by hand, or did you use a tool? I saw a video of a guy using reverse pliers, and slowly went around the assembly prying it open, looked like the best way to go about it. Other videos I've seen the guy is man handling it to pry it open.
  12. Jun 8, 2017 at 6:25 AM
    #52
    TRD_Mike
    Pacific Northwest
    Did you also black out the headlights? Mind explaining that process?
  13. Jun 8, 2017 at 8:07 AM
    #53
    Coot83
    Scottsdale, Az
    2012 Baja TX
    No problem man! I plan to put it in my sig to help others out as well.
  14. Jun 8, 2017 at 8:08 AM
    #54
    TRD_Mike
    Pacific Northwest
    Thanks!
  15. Jun 8, 2017 at 8:09 AM
    #55
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I did the same amount of heat and time when I did my lights. I used an old cheap butter knife for mine that is kind of flimsy. I opened up half of it first, put back in the oven for another 6-7 minutes to reheat the rubber again to finish it off. You don't have to do this twice if you are fast, but I was being careful with my first time. Perfect guidance there though from @Itsaerokyo808!
  16. Jun 8, 2017 at 8:19 AM
    #56
    BlazingTaco
    BlazingTaco ~,!,,___(•v•)___,,!,~
    Exile
    2016 Tacoma SR5 BBP DCSB 4x2
    Mall landscaping pin stripes.
    You can get TYC housings for 106 bucks a piece. They don't need to be OEM, the housing is only an instrument to hold the projector, once you install a BiX projector. Typically aftermarket assemblies are easier to bake apart and if you destroy one during the retro, order another one while you still drive around with your OEM lights in place until you are done. If I retro my third gen, I'll buy TYC assemblies and use those so my OEM assemblies are tucked away safely and I can experiment with less skin in the game. Just another point of view and a money saver on doing a full retro. Also, TRS is dangerously close to having a LED D2S, that would be amazing!
    Coot83 likes this.
  17. Jun 8, 2017 at 8:28 AM
    #57
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Nothing wrong with that man, most complain that the sealant on them isn't that good and some say the clear coating isn't that great over time. If you are planning to retro anyway, then you forgo the sealant issue as you are taking care of it yourself. I personally got spyder lights which actually had a good seal, but doesn't matter cause I resealed anyway, but I wouldn't get OEM for these reasons as to me its not worth the price and I wanted something different anyway.
  18. Jun 8, 2017 at 8:36 AM
    #58
    Hummer911
    Hummer911 Well-Known Member
    Rick
    So. Cal
    2014 RC 4X4 MGM Auto
    BDS 6" lift, Toyo tires on Method wheels
    No need to be calling Logan a dick. He's building my retros right now for about $1300. and that's just fine with me. If you can't afford it then stick with your halogens. You pay for what you get bro...that's how shit is on the planet.
  19. Jun 8, 2017 at 8:38 AM
    #59
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I think as stated before, both sides got a little disgruntled over their communication but to be honest I felt the sale was pushed a little. Its one thing to bug someone for a discount on a good product, its another to need some persuasion in ordering. Atleast that is my take.
  20. Jun 8, 2017 at 8:43 AM
    #60
    Hummer911
    Rick
    So. Cal
    I agree...just don't like the name calling. Had a Fire Captain call me a dick once on a 911 call. The Fire Chief gave him 3 days off for that. He wanted me to run an elderly couple off the road because they wouldn't pull over to the right. I refused to do it.
