Morimoto projectors installed!
Discussion in 'Lighting' started by Itsaerokyo808, Jun 6, 2017.
  1. Jun 8, 2017 at 8:52 AM
    #61
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I agree man, we should be a strong community and to call someone out like that without decent provocation just shouldn't be needed amongst each other. Im sure that collectively, both probably wish that communication could of been handled a little differently. What is important though is that I think both parties have looked to see the brighter side of things and that an order might still take place.
    As far as with the fire capt, I normally never get an opportunity as I don't know many first responders, but that's cool that you did that. I always wondered if there was a line with creating possible hazards in responding to a call. I think the fire chief made the right call here as I don't think it was the name calling that caused that suspension, but to embrace the mentality that it was ok to create an unsafe environment for elderly citizens while in transit to a response.
  2. Jun 8, 2017 at 9:31 AM
    #62
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    Totally untrue. We put both under microscope and looked at material. OEM is way better quality and more reliable
    wasn't pushing at all. Just trying to help a customer out. It doesn't bother me if he orders or not, just trying to help people
    Coot83[QUOTED] likes this.
  3. Jun 8, 2017 at 3:31 PM
    #63
    BlazingTaco
    BlazingTaco ~,!,,___(•v•)___,,!,~
    Exile
    2016 Tacoma SR5 BBP DCSB 4x2
    Mall landscaping pin stripes.
    Marginal at best, let's see your findings professor? Plenty of people on HIDP would recommend aftermarket for a budget retro. Of course OEM is a little better, but nowhere in my prior statement did I say aftermarket was better, but for a budget BiX retro, they would hold up fine for many years. How reliable does a plastic housing and lens have to be? Sound like justification for inflated build pricing to me.
  4. Jun 8, 2017 at 4:05 PM
    #64
    Itsaerokyo808
    Itsaerokyo808 [OP] Active Member
    Darin
    Oahu, Hawaii
    2015 BR Xrunner
    Djm 3/3 drop
    I was able to do it by hand which I think is how it should be done. If you can't open it by hand then it isn't hot enough. However I used a flat head to follow the seam of the headlight so that the stretched out butyl wouldn't fall onto the housing or lens of the headlight
    I'll speak for guys baking there oem housings,and that it is solid and can only melt with carelessness.
    I can't say how aftermarket housings would hold up though
  5. Jun 8, 2017 at 4:09 PM
    #65
    Itsaerokyo808
    Darin
    Oahu, Hawaii
    2015 BR Xrunner
    Djm 3/3 drop
    Yes I did black it out with satin black spray paint. Not krylon though just a cheap one at lowes. It was a primer paint in one can
    I did scuff up the bowls using a 100 grit sanding sponge.
  6. Jun 8, 2017 at 4:11 PM
    #66
    LSC15
    Logan
    2008 TRD D-Cab
    I use aftermarkets to help people with pricing but OEM ones are way better. You can feel the difference in quality
  7. Jun 8, 2017 at 4:19 PM
    #67
    TRD_Mike
    TRD_Mike Well-Known Member
    Pacific Northwest
    2015 DCLB TRD Sport - Gray
    Again, thanks for all the great info, you've been very helpful. When you say you used a flat blade to follow the seam, do you mean you basically scored the seam after it cooked but before you split the casing?
  8. Jun 8, 2017 at 4:47 PM
    #68
    Itsaerokyo808
    Darin
    Oahu, Hawaii
    2015 BR Xrunner
    Djm 3/3 drop
    Sorry I'm not good with words lol
    After opening the headlights a little but, around half an inch gap, the butyl would just stretch instead of seperating so I took the flat head and "cut" the butyl all the way through the whole headlight by sliding it along the opening
    If that makes sense
  9. Jun 8, 2017 at 5:18 PM
    #69
    TRD_Mike
    Pacific Northwest
    Makes perfect sense now. Thanks!
  10. Jul 22, 2017 at 1:21 PM
    #70
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    OH NO! Hopefully not.
  11. Jul 22, 2017 at 1:24 PM
    #71
    LSC15
    Logan
    2008 TRD D-Cab
    In not bud. Just cuz I put pricing in same format doesn't mean anything
    1bad2k[QUOTED] likes this.
  12. Jul 22, 2017 at 1:34 PM
    #72
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    I read the next couple of posts and saw that.
    I've dealt with those guys before.......
  13. Jul 22, 2017 at 1:45 PM
    #73
    LSC15
    Logan
    2008 TRD D-Cab
    Bad experience?
  14. Jul 22, 2017 at 1:46 PM
    #74
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    Lol yeah you could say that
  15. Jul 22, 2017 at 1:56 PM
    #75
    LSC15
    Logan
    2008 TRD D-Cab
    Sorry to hear buddy
  16. Jul 22, 2017 at 2:16 PM
    #76
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    All good. Learned my lesson.
