Morimoto Xb Headlights Turning On
Discussion in 'Lighting' started by carrillocaleb, Sep 12, 2021.
  1. Sep 12, 2021 at 8:42 PM
    carrillocaleb
    carrillocaleb [OP] New Member
    Caleb
    2015 TRD Sport 4x4
    Hello,
    I just had the Morimoto XB Headlights installed on my 2nd gen and was really pleased with their appearance and performance. However, there seems to be a minor issue. That randomly turn on when the car is off. I have it set so the Amber DRLs are constantly on while the car is on. Is there a way to change this setting? And will it stop the lights from turning on by itself? What can I do to fix this issue?
  2. Sep 12, 2021 at 11:07 PM
    caribe makaira
    Caribbean, Puerto Rico
    What fuse/circuit did the instructions state you use? Was it IFE No.2?
  3. Sep 13, 2021 at 5:07 PM
    Hyland33
    Hyland33 Well-Known Member
    Andrew
    Leicester, MA
    2015 Tacoma TRD Offroad
    Don't use the fuse they tell you to use. The truck runs test occasionally and the drl will get power. I ran mine inside and tapped the washer fuse.
    sanchez likes this.
  4. Oct 22, 2021 at 10:52 PM
    STATIC
    STATIC New Member
    IZY
    Hey hyland33 I have the same issue can you give instructions on how you did your wiring please thanks
    Jlburke and sanchez like this.
  5. Dec 4, 2021 at 4:54 PM
    Jlburke
    Jlburke Member
    Jeff
    Ewa Beach
    14 MGM DCSB Manual
    Following
  6. Dec 4, 2021 at 8:32 PM
    caribe makaira
  7. Dec 4, 2021 at 8:37 PM
    Fixxxer
    Fixxxer Well-Known Member
    Port Angeles
    '13 TRD Sport DCLB Super White
    ARB Front/Rear Air Lockers, Nitro Gear 4:88's, Hutchinson Rock Monsters, SOS Concepts Front Aluminium Bumper, UpTop Overland Alpha XL Roof Rack, ARB Snorkel, AVS Rainguards, Redline Hood Struts, Weathertech Mats, Flyzeye led's, MESO Molle Rack, Meso LED Dome Light, K&N Air Filter, UNI Filter Mod, Bosch Wiper Blades, Snugtop Sportster Reinforced Canopy, Viper 2-Way Remote Start, ARB Twin Compressor,
    I have the same question regarding where to run the DRL power wire.
  8. Dec 14, 2021 at 12:30 PM
    Integerdy
    Integerdy Aspiring "SR5 Pro"
    Eric
    So-Lame, Oregon
    21 SR5 Silver Sky DCSB
    Use the INJ fuse tap
  9. Dec 14, 2021 at 12:31 PM
    caribe makaira
    It's a 2nd Gen:D
  10. Jan 4, 2023 at 4:40 PM
    Jc_dabs
    Jc_dabs Griselda.taco
    Jesus
    Long Beach ca
    2021 tacoma Trd or
    If u have led drls stock on your truck I don’t think you need the fuse tap giving by morimoto
