Morning group help me diagnose please.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FrankFL., May 15, 2024.
  1. May 15, 2024 at 6:53 AM
    FrankFL.
    FrankFL. [OP] Well-Known Member
    Franz
    2006 Toyota Tacoma
    Lift kit.
    So i just rebuilt my 2tr. I was getting a lot worse codes but got to figure it out the most. This are the last 4. And im getting a lot of noise from the head.
    If any one have come up on this and fixed would love to hear your ideas.
  2. May 15, 2024 at 6:54 AM
    FrankFL.
    Franz
    2006 Toyota Tacoma
    Lift kit.
    Now on the replaced parts has bith o2 sensors rwplaced. New spark plugs new crankshaft sensor new camshaft position Sensor.
    Im located in the SFL area if anyone recommends a mechanic would be apprexiate ir. Been to two other mechanics and both gave me wrong ideas. One told me the lifters neefed to be adjusted but for what i know they are hidraulic?
  3. May 15, 2024 at 7:39 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Is the purge valve leaking vacuum with the engine running?
    FrankFL.[OP] likes this.
  4. May 15, 2024 at 9:40 AM
    FrankFL.
    Franz
    2006 Toyota Tacoma
    Lift kit.
    Ill check it out today. Havent tested it. Ill check it today.
  5. May 15, 2024 at 9:42 AM
    FrankFL.
    Franz
    2006 Toyota Tacoma
    Lift kit.
    Now that h2os sensor heated its just replaced. So it could be defective
  6. May 16, 2024 at 5:44 PM
    FrankFL.
    Franz
    2006 Toyota Tacoma
    Lift kit.
    Just checked the purge valve. As shown in the picture the vacuum line in the bottom that is connected is sucking air but the one on the top when i umplugged it is not
