Moroso Oil Catch Can Observation
Discussion in '1st Gen. Tacomas (1995-2004)' started by billybop90, Feb 5, 2024.
  1. Feb 8, 2024 at 9:46 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Why do you say that?
    I would say that both should catch stuff. That blue one looks like it might be a pain to drain and keep clean. For sure, you'll want to upgrade the hoses that come with this things. Use some 3/8" fuel line if you can.
    Here is the one I run. Looks to be the same one @ControlCar posted earlier. Works well. The hardest part was figuring out how/where to mount it so the hoses were reasonable.
    https://www.amazon.com/gp/product/B06XK9PTP7?ie=UTF8&th=1
    ridefreak[QUOTED] likes this.
  2. Feb 8, 2024 at 1:05 PM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    Read up on Blowby. Pumping oil out of a crankcase breather to the point where it needs emptied every oil change is sign of excessive crankcase pressure, IMO the motor should have the PVC valve checked and barring a problem there a leakdown test done. Some 3rd gens have had the issue early on and seem more prone to pushing oil out of the CC breather due to it's location but in the earlier models it's typically indictive of a bad PCV or worn components and isn't unusual on a higher mileage motor that gets called to put out the majority of it's hp every time it's driven (read 4cyl) It's been discussed here before. Doesn't mean the motor is going to blow up on you, it'd probably run a long time like that but there's issues if you need to empty a catch can that often. I will concede that under certain circumstances (excessive angles when 4wheeling) can also cause oil to enter the breather system.
  3. Feb 8, 2024 at 1:56 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I think there is a misconception here on whether this is a need or a want. I want to know what the catch can is catching. Once I know that, I might as well empty it. But I certainly don't need to if I don't want to. I suppose it would eventually get full but that would take at least 10 or more oil changes to get near to that point. The amount of crap being captured is very small.
    I realize that not everyone doing this is going to have the same experience. And not all high mileage (without defining what that actually is) engines are going to be the same. FWIW, the Blackstone lab report indicates I have a very healthy 3.4L even though it has forced induction with more than 250K miles.
    ControlCar likes this.
  4. Feb 9, 2024 at 3:10 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Ha agreed!^^^^
    Here’s my ‘excuse’
    -to protect my investment of 10 freakin cans of brake cleaner I used to clean the carbon from intake and plenum!!!!
    (There is no argument that intake air will be cleaner as filtered by OCC)
    -had that cheapo red OCC laying around garage for 1yr or so
  5. Feb 10, 2024 at 2:26 PM
    billybop90
    billybop90 [OP] Well-Known Member
    Bill
    Black Hills SD
    1996 Taco, 2.7, 4WD, 5 spd
    Yep, 100%
    Is it necessary, well that's debatable BUT every engine I have torn down, cleaned and put back together I have always gone overboard and put a little something extra to help protect them. Besides, I love shiny things in an engine bay
    ControlCar[QUOTED] likes this.
