Most 2nd wheel bearing replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoMitch93, Jan 13, 2017.
  1. Jan 13, 2017 at 12:57 PM
    TacoMitch93
    TacoMitch93 [OP] Tasty Taco
    Mitch
    Nova Scotia, Canada eh
    09 Tacoma SR5
    My driverside wheel bearing is on its way out, this will be replacement number 7 (between both sides).
    I always replace both seals, and I recently replaced the axles because the seal face on my original axles were pretty chewed up.
    Has anyone replaced more than me?!
    I've owned the truck for less than 3 years.
  2. Jan 13, 2017 at 12:59 PM
    icallhertaco11
    icallhertaco11 Well-Known Member
    Jamie
    Texas
    2008 Tacoma Prerunner v6
    Engage Long Travel 6 over with race spindles. 2.5x8 sway a ways wrapped in King Coils.
    Are you going through Toyota for them?
    I reccomend buying from one of the two vendors on this site. They sell the complete hub assembly's.
  3. Jan 13, 2017 at 12:59 PM
    h.zack801
    h.zack801 Scumbag Extraordinaire
    Zack
    Columbus, OH
    Truck Parked Mod
    Door Dings
  4. Jan 13, 2017 at 1:02 PM
    TacoMitch93
    Mitch
    09 Tacoma SR5
    I know right, where I live it's fairly wet and muddy. It chews up wheel bearings!
  5. Jan 13, 2017 at 1:03 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Damn, that is fucked up
    TacoMitch93[OP] likes this.
  6. Jan 13, 2017 at 1:04 PM
    TacoMitch93
    Mitch
    09 Tacoma SR5
    I buy the seals from Toyota and my bearings are normally SFK (or whatever it is) or Timken.
    I thought about ordering the assembly, but I'm canadian and between shipping and stuff I wouldn't safe any.
  7. Jan 13, 2017 at 2:08 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    X7 WTF I bet U R the Winner ! Wonder If someone will come up with what U R doing wrong. I've replaced mine once in 100k. Tacoma seals R infamous for failing but U R special IMHO.
  8. Jan 13, 2017 at 5:15 PM
    TacoMitch93
    Mitch
    09 Tacoma SR5
    Then seal setup is garbage. And I can't say I'm doing anything wrong aside from wheeling the truck. It gets soaked up to the hubs in water more often than not, and my dad presses the hubs in for me. He's been a Toyota tech since 92, I imagine he's doing things right.
  9. Jan 13, 2017 at 5:24 PM
    george3
    New Jersey
    There's the answer - seals NG - crap gets in and bearings R gone. Lucky 4 U Dad can bang the job out.
  10. Jan 13, 2017 at 6:01 PM
    TacoMitch93
    Mitch
    09 Tacoma SR5
    Well, I do all the grunt work and he presses the hub in for me. The press I have at work isn't capable of pressing the hub out of the bearing!
  11. Jan 13, 2017 at 7:01 PM
    evilcorvette
    evilcorvette Well-Known Member
    oderus urungus
    Syracuse NY
    What were your symptoms? Ive got a 2015 with 19K miles on it and Im getting the slightest 'howling' at speeds above 35 MPH. I cant tell if its tire noise, bearing or just a Tacoma thing.
  12. Jan 14, 2017 at 3:40 AM
    TacoMitch93
    Mitch
    09 Tacoma SR5
    I normally can't hear any howling because of my tires. But since I have my winters on I could hear howling and when I turned right it would go away.
    Normally I just shake my wheels (like I'm checking for balljoint play) every time I do an oil change, or any other reason the tires aren't on the ground.
  13. Jan 14, 2017 at 5:18 AM
    george3
    New Jersey
    After 7 I'm sure U can do them in your sleep - my brother in law and I did ours and the last one done in 1.25 hrs.
  14. Mar 10, 2017 at 4:27 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    You haven't mentioned the O-rings. Have you replaced them? It goes on the bearing assembly when you bolt it to the knuckle. I even put a dab of gasket sealant on both sides of the brake dust shield to help keep water out.
