Most aggressive looking tire but lightest in weight 265/70/17
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1tacoplease, Jun 27, 2014.
  1. Jun 27, 2014 at 5:31 AM
    1tacoplease
    1tacoplease [OP] I like my truck!
    Temecula
    2008 BSP 4x4 6 speed
    265/70/17 BFG RT's, FJ 17" rims with 1.25" spidertraxx Debadged, HID's, URD short shifter, Bilstein 5100's in the front, TSB and 1" block rear, URD TCAI with maf calibrator, JBL long tubes, DT Y pipe, Gibson exhaust, Walbro 255 fuel pump, Pioneer stereo, Bak flip G2 tonneau, TRD skid plate, MB Quarts all around with dynomat, Viper Alarm with motion sensor
    I hardly go off roading but I like my truck to have an aggressive look but tire be as light as possible. Can anyone help me out?
  2. Jun 27, 2014 at 5:40 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    I would guess duratracs or wrangler authorities, both are borderline mts (if u squint a little) and from what i understand goodyear left a lot to be desired in the sidewall department to save weight.
    ikon4x4 likes this.
  3. Jun 27, 2014 at 7:29 AM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    Hankook dynapro Atm is 38.6lbs in that size. My BFG TA KO's are 45lbs each!
    Shamangue likes this.
  4. Jun 27, 2014 at 7:41 AM
    09TRDSpt
    09TRDSpt African Light Infantry
    Atlanta, GA
    09 TRD Sport DC 4x4
    Totally agree here, love my BFG AT's but they will cost you 1-2mpg and weigh a ton.
  5. Jun 27, 2014 at 7:42 AM
    14TACO4X4
    14TACO4X4 Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    I know that the shop I use for tires has all the specs for every tire, including weight. If you go into a tire shop they can tell you definitively which tires fit your search.
  6. Jun 27, 2014 at 7:48 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    tirerack.com
    check out the Goodyear Wrangler All-Terrain adventure with kevlar's
  7. Jun 27, 2014 at 7:52 AM
    14TACO4X4
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    Good call... forgot about the "specs" section of tire rack. They list the weights of the tires most of the time, as well.
  8. Jun 27, 2014 at 7:53 AM
    Wiggins
    Wiggins Well-Known Member
    Jacksonville
    14 MGM DCSB 4x4 TRD OR
    TRD Sport Hood, ICON 3" Lift - 700lb coils, Total Chaos UCAs 5% Tinted Windows Crystal Front Window Film 2.5 resi shocks front and rear, dakar leaf packs Wheelers Bump Stops All-Pro Offroad APEX Front Plate Bumper, PIAA Fog Lights, PIAA Fog Lights, Black Line-X All-Pro Offroad Skid Plates, Black Line-X All-Pro Offroad APEX Rear Plate Bumper, Side Armor for Plate, Hidden Receiver Hitch, Black All-Pro Offroad APEX Sliders,Line-X All-Pro Offroad APEX Pack Rack, Black Line-X, 16" height ScanTool 427201 OBDLink LX Bluetooth Hankook Dynapro ATM 285/75/16 Vision Manx 16"x8" rims, 4.5" Backspacing Warn M8000-s Winch, Factor55 Flatlink, Factor55 1" Hawse Fairlead RIGID Industries Ditch Lights Tractor Supply Bed Box 260amp H.O. Alternator Big 3 Cable Replacement NorthStar AGM34 battery Pelfreybilt Battery Cage Plefreybilt Fuse Plate BlueSea fuse block Kenwood TS-B2000 Short Wave Radio, Remote face, Pack Rack Mounted Antenna Uniden Bearcat CB Cab Mount Chop (BAMF Inserts) TODO: ARB Air System ARB Rear Air Locker w/ 4.88 gears ARB Front Air Locker w/ 4.88 gears HID Retrofit Headlights Rigid Industries RDS-Series 54" Midnight Edition LED Rigid Industries R2-46 Combo Round Light (x2)
    Just get the druatracs, they're a good balance of looks, weight and price. They look a very aggressive to the average Mall Lot Lizard.
    Dicktrickle92 likes this.
  9. Jun 27, 2014 at 8:00 AM
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2016 F150 Lariat 4x4
    5100s (2.5" front), OEM Raptor wheels, 315/70/17 BFGs, Undercover, tint, Weathertechs.
    Whatever you get, get a P-metric AT tire. If you don't need the LT tire, no reason to get it. That will save you a lot of rotational mass.
    Mattman72 likes this.
  10. Jun 27, 2014 at 8:04 AM
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
    Less aggressive looking and 2.5lbs heavier then the Hankook dynapro ATM
    surfandturf likes this.
  11. Jun 27, 2014 at 10:23 AM
    Haskett039
    Haskett039 Well-Known Member
    Rob
    Ontario, Canada
    2012 TRD Alpine White
    I just installed the General Grabber AT2s in 265/70/17 SL and they look and run great. Maybe not the MOST aggressive looking tire but the weight and ride on them are great so far and the price came in at $375 cheaper than the BFG AT KO
  12. Jun 27, 2014 at 10:35 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Duratracs have greater tread depth than General Grabber AT2, BFG AT, Hankook ATM, etc., but unfortunately don't come in P-metric. At 44 lb the load range C tire is still reasonable weight. This is going to be my winter tire when my current Firestones wear down.
    @1tacoplease: By restricting yourself to 265/70-17 instead of 265/75-16, you will never reach optimal weight, since the 17" wheel will be heavier than an equivalent 16" wheel. ;)
  13. Jun 27, 2014 at 10:56 AM
    karmatp
    karmatp Well-Known Member
    Trevor
    Chandler, AZ
    2016 4x4 4Runner
    A lot of the tires mentioned are a bit heavier than your current set up. I just purchased some 265/75/16 Cooper ATP's that were only 40 lbs compared to my 265/70/16 BFG rugged trails at 38 lbs. Going up a size and adding a much better tire for only 2 lbs a tire is a win in my book.
  14. Jun 27, 2014 at 11:07 AM
    nd4spdbh
    SoCal
    where are you getting weight specs for the Dynapro atm rf10?
  15. Jun 27, 2014 at 11:17 AM
    oldstick
    oldstick Medicare Member
    GA
    For little off roading and you want some good looking AND very smooth/quiet/long tread life, check out the Toyo Open Country H/T tires in that size.
    Put the white letters out too for the old school sport look.
  16. Jun 27, 2014 at 11:33 AM
    Phils514
    Phils514 Well-Known Member
    Phil
    Dcsb
    You got a side view and front pics? I'm curious because that's what I was thinking of getting. Also, any lift on your truck?
  17. Jun 27, 2014 at 1:02 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Don't concern yourself with tire weight on a 4500 lb truck. My tires and wheels weigh 170 pounds each. It would be hard to find a heavier wheel and tire combo out there and it still gets decent mileage and drives fine. It does eat parts, but that's mostly because of my maniacal driving style and terrain. On a 2000 lb race car, tire weight is important. For me, I would rather have tough sidewalls than a 10th of a second faster quarter mile time in the Tacoma. Nitto's in your favorite flavor are a good choice for a mall crawler tire, and they perform well if you take a wrong turn and end up in the dirt.
  18. Jun 27, 2014 at 1:17 PM
    1tacoplease
    Temecula
    Looks like Hankook Dynapro Atm's.
  19. Jun 27, 2014 at 1:17 PM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    toyo at II 265/70r17 41lbs
    cooper at3 265/70r17 41lbs
  20. Jun 27, 2014 at 1:20 PM
    nd4spdbh
    SoCal
    Wow didnt realize the Dyanpro ATM RF10's were light as they are.... for the P265/75R16 its 39.019 lbs as quoted from hankook themselves (they just emailed me back)
    hmm i might of found my new tire!!!
