Most aggressive looking tire but lightest in weight 265/70/17
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1tacoplease, Jun 27, 2014.
  1. Jun 28, 2014 at 7:21 AM
    #41
    JAGER91374
    JAGER91374 Well-Known Member
    Des Plaines
    3 TRD O/R
    OME 883's and Dakars, OME Shocks, Gray Wire, Deck Plate, Blacked Out Chrome, RAT Skids, BAMF BPV Bracket, Toytec Diff Drop, Braided Extended Brake Lines Front and Rear, In-Dash Nav.
    I just put 265/75/16 Duratrac's on my 1st gen a little over 3 weeks ago. So far i've not seen a drop in mileage that I can attribute to the tires.
    I've run 2 tanks through the truck since mounting. The first tank was slightly under my average per tank while the 2nd tank was slightly over.
    I can tell you that I like the solid feel of the "C" load tire and I've not seen any negative effects since mounting except that they do "touch" the frame rail on full lock with stock 2003 TRD wheels and a 3 inch lift.
  2. Jun 28, 2014 at 7:28 AM
    #42
    Ebg18t
    Ebg18t Member
    I see a lot of folks suggesting the a Hankook ATM. I didn't have that great of luck with the ATM, as they wore (5k mike point) I found the wet traction lacking. More so than other tires I have run in the past. Maybe the Taco is drastically different, but in didn't like them on the 4Runner.
    The Cooper AT3, Toyo AT and Nitto Terra Grappler are a few other options to look at. All in a P rated, not LT since weight is a concern
  3. Jun 28, 2014 at 7:34 AM
    #43
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Edit: went BFG Commercial T/A stock size been great for 5 years
    BWilley likes this.
  4. Jun 28, 2014 at 9:28 AM
    #44
    Phils514
    Phils514 Well-Known Member
    Phil
    Dcsb
    Does anybody with bilsteins get tire humming noise after install?
  5. Jun 29, 2014 at 6:20 AM
    #45
    Haskett039
    Haskett039 Well-Known Member
    Rob
    Ontario, Canada
    2012 TRD Alpine White
  6. Jun 29, 2014 at 7:41 AM
    #46
    JAGER91374
    Des Plaines
    3 TRD O/R
    Did you install the the bilateins at stock height or lifted?
  7. Jun 29, 2014 at 8:52 AM
    #47
    Phils514
    Phil
    Dcsb
    Front at 1.75. 2" aal in the back. I will be putting 265-70-17 grabbers soon and bilstein 5125s in the rear for the 2"
  8. Jun 29, 2014 at 9:20 AM
    #48
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  9. Jun 29, 2014 at 9:28 AM
    #49
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    or P rated Hankook ATm's in 255/75/17
  10. Jun 29, 2014 at 9:36 AM
    #50
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    These tires just came out last August. I picked up a set this past January and have about 16,000 miles on them.
    Although the look is unaggressive and understated, this set has by far increased the ride comfort of my DCSB. I've only had 2 previous sets, Revo 2's, and the stock Dunlops, and the Wrangler Adventure has given me the best off road grip, and on road ride comfort. They have a 60K mileage warranty too. Not cheap though...
  11. Jun 29, 2014 at 10:29 AM
    #51
    1tacoplease
    1tacoplease [OP] I like my truck!
    Temecula
    2008 BSP 4x4 6 speed
    265/70/17 BFG RT's, FJ 17" rims with 1.25" spidertraxx Debadged, HID's, URD short shifter, Bilstein 5100's in the front, TSB and 1" block rear, URD TCAI with maf calibrator, JBL long tubes, DT Y pipe, Gibson exhaust, Walbro 255 fuel pump, Pioneer stereo, Bak flip G2 tonneau, TRD skid plate, MB Quarts all around with dynomat, Viper Alarm with motion sensor
    I'm going to go with either 265 or 275. If I go 275, I will take off my Spidertraxx wheel spacers, but I think the 265's will be lighter.
  12. Jun 29, 2014 at 3:58 PM
    #52
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    I did not notice any difference.
  13. Jun 29, 2014 at 3:59 PM
    #53
    OZ-T
    Peter North
    British Columbia
    Did you get an alignment ?
  14. Jun 29, 2014 at 5:49 PM
    #54
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    I just went from a street tire at 39# to an AT tire at 52#. They both measure the same outside diameter, the AT is 1" skinnier.
    With the AT tire it accelerates a bit slower and stopping is about the same. Where I really notice the difference is when the torque converter is always unlocking and the gear hunting on gentle grades with cruise control on while on the highway. I also saw a 3mpg loss even though I drive much more economically now. It's much more than just raw acceleration and breaking.
    In my case a regear might help but for me I'm not sure it'll be worth the money. And besides I'm happy with my truck as it is.
  15. Jun 29, 2014 at 6:35 PM
    #55
    Phils514
    Phil
    Dcsb
    Yes I did.
  16. Jun 29, 2014 at 7:38 PM
    #56
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    The Grabber AT2's are a pretty darn heavy tire. FYI.
    44 lbs for a measily 265/70R16
  17. Jun 29, 2014 at 8:56 PM
    #57
    otis24
    Mark
    California
    My 235 85 R16 General Grabber AT2's are 52lbs... they're also 10 ply.
  18. Jun 29, 2014 at 9:29 PM
    #58
    nd4spdbh
    SoCal
    ^yeah no..... talk about heavy pizza cutters there!!!
  19. Jun 29, 2014 at 9:36 PM
    #59
    Husky Driver
    Husky Driver Kyna's chauffeur
    Kipp
    40°35'09.0"N 105°04'38.3"W
    2k T4R3 SR5 (Sport Edition Highlander SX) TRD
    Toytec Ultimate 3" lift susp w/ OME 891 rear coils, Bilstein 5100 shocks front & 5125 rear, ARB 'Roo Bar, Warn VR10k, 0.7, 2 & 11-meter 2 way radios FCC Lic KE0TDD, Nitrogen inflated 33" BFGoodrich All-Terrain T/A KO2s, FlexFuel E-85 conversion, AFe lifetime filter, Savage Offroad rock sliders, Ryno All Terrain 4.5mm skid plates, Line-X coatings on the armor, LifetimeLED & Rigid Industries LED headlights, UltraGauge 1.2, T3q 4.10 eLocker with armor from LROR, AmsOil lubricants used throughout. CBI plate rear bumper with swingaway, SPC Light Racing UCAs, ARB SS170HF Safari snorkel w/ Afrikaans centrifugal pre-cleaner, Tacoma antenna mod, TRD Supercharger w/ URD 7th inj. & URD pulleys, Anti-Dark engine bay lighting system. Having gone 250k, Aug 2016 was the time to replace the original clutch & get the driver's seat rebuilt/stuffed. Front & back Weathertech liners. '05 Tundra front disc brake swap. Full length Rocky Mountain Rack with 40" lightbar, Alternating strobe rear dust lights. I used a warm weekend in March 2022 to finally install my brand new from old stock 2000 4Runner driver's seat. $800 directly from the factory in Sapporo, Hokkaido, Japan.
    Hankook DynaPro ATM RF10 Has the performance you're looking for in an inexpensive, lightweight, great traction yet surprisingly quiet at highway speeds tire. Aggressive mall-crawler for $100 less per tire compared to the BFG MS. As tire companies go they are also one of the most 'green' there is. Another extra bonus, not made in China (South Korea).
  20. Jun 29, 2014 at 9:37 PM
    #60
    OZ-T
    Peter North
    British Columbia
    My ATm's are made in China
