Most Comfortable 3" kit
Discussion in 'Suspension' started by travistheone, Mar 28, 2016.
  1. Mar 28, 2016 at 5:32 AM
    travistheone
    travistheone [OP] Well-Known Member
    2012 black sport double cab
    I have a 2012 DCSB with a cheap spacer lift or something on it now. Installed by previous owner.
    I drive around 30k a year on the road. I need something comfortable. I hit the trails here and there when camping.
    No extra weight to speak of. Plate bumper in rear.
    I had an OME on my 4runner and loved it, but that was years ago.
    I have a pre order in for the All Pro LOLA kit, but I am impatient and they are well back ordered.
    I want zero maintenance, smooth ride.
    Coilovers or just go OME? Are the dakar leafs super stiff?
  2. Mar 28, 2016 at 6:30 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    I've installed a number of different "kits" and/or brands of lifts for other people. When it came time to do my own, I wanted to end up with a quality ride, good on and off road performance, and NOT spend every last penny I have.
    What I did was to use Bilstein 5100's on all corners, fronts set @ 0" with OME 885X coils, a plate spacer to get rid of the lean, (took 1/2" on mine, most level with 1/4" spacer) and Deavers 2"AAL in the rear. It rides better than any 4wd I've ever owned. The AAL carries weight well enough to handle what a Tacoma should be hauling, and the end result LOOKS good. (2-1/2+" front lift, 2" rear) Cost was $733 to my door from Headstrong Offroad.
    TBlack, youngsurfrat, Mully and 2 others like this.
  3. Mar 28, 2016 at 6:46 AM
    travistheone
    Thanks,
    I was thinking bilsteins or OME instead of coilovers if there wont be a ride quality difference.
    I need full leafs though because mine are well worn at 90k.
  4. Mar 28, 2016 at 9:52 AM
    travistheone
    Just ordered OME from @HeadStrong Off-Road. Excellent experience. I wish I knew about those folks sooner.
  5. Mar 29, 2016 at 1:10 PM
    Tac11
    Tac11 Well-Known Member
    Luis
    2011 white Tacoma sport TRD
    3" Front lift OME/5100 set at 0, 1/4 spacer on driver side CMC, BFG 285's, SCS ray 10’s -38 offset 1 inch rear block N-Fab steps Bumper Cali Raised LED light bar Cali Raised LED fog lights After market exhaust, and muffler tip Redline hood struts Tacoma Bed-liner mat Tailgate lock Tinted windows 20% HID headlights Short antenna Clazzio Seat covers Joying head unit
    @travistheone yes. So far I had great costumer service. What did you end up getting? I'm still doing a bit more research
  6. Mar 29, 2016 at 1:22 PM
    Mjordan
    Mjordan Well-Known Member
    Michael
    Denver, Colorado
    2015 Super White DCSB 4WD TRD Offroad
    TRD Beadlock Wheels, Bilstein 5100s all around, BFG K02 265/75R16, 20% tint, WeatherTech Floormats, LED Interior Lights, Tailgate lock, Salex Organizers, Shorty 5" Antenna, LED license plate lights
    I have bilstein 5100s all around, and fronts set at 1.75" with stock springs. 1.25" block in the rear.
    Not that it rides bad, but I wish all the time that I would have spent a little extra and done exactly what @Bluegrass Taco said.
  7. Mar 29, 2016 at 1:27 PM
    Tac11
    Luis
    @Bluegrass Taco is that only for 4wd set up someone told me the 885 is only for 4wd. Also the spacer. 4 wheel parts sales man said he never heard of that lean that will require a spacer. Is it dramatic? Should I invest in a spacer? Thanks
  8. Mar 29, 2016 at 2:53 PM
    HeavyLifter
    HeavyLifter Well-Known Member
    Jeff
    Athens, Ohio
    2013 TRD Sport
    Starting to do more research on getting a 3" lift as well.
    Question: I have 5100's all the way around. The fronts are adjustable (leveled the rake). Can I keep the 5100's, add coils in the front and new leaf pack in the rear and call it a day?
  9. Mar 29, 2016 at 3:38 PM
    Mjordan
    Michael
    Denver, Colorado
    OME 885 coils with the 5100s set at 0. Then an AAL in the rear. A 1/4" front top plate spacer for the drivers side to correct taco lean.
    Of course to get good alignment specs you'll probably want new UCAs too. Look into LR UCAs by SPC.
    Alignment after front end stuff installed.
    Around $1,200ish if you install everything yourself + whatever an alignment costs you. Now call it a day.
  10. Mar 29, 2016 at 3:43 PM
    HeavyLifter
    Jeff
    Athens, Ohio
    2013 TRD Sport
    Thanks for the reply. That's about what I thought.
  11. Mar 29, 2016 at 5:05 PM
    Tac11
    Luis
    Would you recommend 5100 all around even if I don't plan rear lift?
  12. Mar 29, 2016 at 5:09 PM
    TacoBrad
    TacoBrad Well-Known Member
    Brad
    VA
    2011 TRD Sport Debadged
    Fox Ultimate Lift Package, Spider Trax Wheel Spacers 1.25, URD Short shifter, K&N Cold Air Intake Air Filter, Bestop Supertop
    If you have the money but the Fox Ultimate 2.5 . I have it and love it
    WOODEX M.E. likes this.
  13. Mar 29, 2016 at 5:24 PM
    Mjordan
    Michael
    Denver, Colorado
    Yeah I would. Definitely a better ride and better quality shocks. Resell your stock ones if they're still worth anything and recoup some of the cost.
  14. Mar 29, 2016 at 7:02 PM
    Tac11
    Luis
    @Mjordan thanks for the info. I'm going to try to install them myself I'm not very mechanically inclined but doing the front is enough since I'm on a budget. Btw I'm getting that set up the 5100 and 885x for 365. Is that good?
  15. Mar 30, 2016 at 3:01 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    I'm not the right person to ask about 2wd lifts....No knowledge whatsoever of that subject.
    Anyone who's dealt with Tacoma's and lifts will know about the "Taco Lean". You will need some sort of spacer, OR, get used to drivers side being noticeably lower.....
  16. Mar 30, 2016 at 7:56 AM
    Mjordan
    Michael
    Denver, Colorado
    @Tac11 FYI that lean is because the stock coils are side specific and the drivers side one is designed to accommodate for the heavier load which causes the slight lean when aftermarket coils are installed.
  17. Mar 30, 2016 at 7:59 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Even the stock coils eventually sag on drivers side. I had to have a 1/4" spacer on drivers side with stock coils/shocks to sit level.
  18. Mar 30, 2016 at 8:08 AM
    Tac11
    Luis
    So a 1/4 is enough or a 1/2nspacer instead. Is it subjective?
  19. Mar 30, 2016 at 8:11 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Most people get by with 1/4". In fact, my truck is the only one I know of personally that needed 1/2" spacer to level. Not sure why I'm so lucky, but......Maybe too many Big Mac's....
    NeedmoreTaco and Tac11[QUOTED] like this.
  20. Mar 30, 2016 at 8:58 AM
    NeedmoreTaco
    NeedmoreTaco Garage full of white Toys...
    Eric
    Travelers Rest, SC
    2012 Super White DCSB Prerunner
    LEDs and stuff
    Prerunner and 4wd have the same suspension, only difference being that you can do a spindle lift on a prerunner and not a 4wd. OME 885 coils will work on both. Now a 5-lug 2wd is an entirely different suspension I believe.
