Most Common Impact Socket Sizes for Gen1?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04tacoma trd, Nov 21, 2020.
  1. Nov 21, 2020 at 1:55 PM
    04tacoma trd
    04tacoma trd [OP] Well-Known Member
    What are the most common impact socket sizes used on the Gen1? Don't want a full set with sockets I will never use.
  2. Nov 21, 2020 at 1:57 PM
    goldentaco03
    goldentaco03 Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    I have no idea, I just got a set of 10-12 duralast ones from autozone with the lifetime warranty...was like $30 and I’ve used all but one or two of them
    Anton338 likes this.
  3. Nov 21, 2020 at 1:58 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Buy a full set. 3/8", 1/2" drives. Metrics up to 21 mm.
    Combination wrenchs same range
    Set of Allen key/wrench
    Torque wrench
    You will still end up going to the store for the one you don't have.
  4. Nov 21, 2020 at 2:02 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    There is a TW list of socket sizes for the first gen. Search is your friend.
  5. Nov 21, 2020 at 2:04 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Forgot the 35mm socket, if you've got a 4x4 with ADD, or lock ring pliers for manual hubs.
    10, 12, 14mm are most commonly used
    TWJLee likes this.
  6. Nov 21, 2020 at 2:05 PM
    TacoJohn4x4
    TacoJohn4x4 Captain Save-A-Ho
    Central Valley
    2002 Tacoma DC 4x4
    For impact 17 and 19 in 1/2 are used the most for me. If you work on multiple vehicles you’ll end up using most if not all of them. I would go for the larger sets for impact.
  7. Nov 21, 2020 at 2:06 PM
    Bishop84
    Bishop84 Well-Known Member
    10, 12, 14, 17, 19, 21, 35.
    Tie rods I just use crescent wrench.
    Honestly just buy a full set.
    TWJLee, Wyoming09 and Wulf like this.
  8. Nov 21, 2020 at 3:47 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I second these a good start you can pick up the odd ones as needed
  9. Nov 21, 2020 at 3:50 PM
    Lastplace
    Lastplace Well-Known Member
    Southeast VA
    I would have to buy 2 10s, I lose them all the time.
  10. Nov 21, 2020 at 3:53 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I have 6 in the truck (I have a dedicated tool bag that lives in the truck).
    4 are between deep socket, short, 6 point and 12 point. Other 2 are swivel style which have proven very useful.
    3 were actually a gift from last years TWSS :cool:
  11. Nov 22, 2020 at 2:33 PM
    04tacoma trd
    Thanks guys. Probably not going to use a 10 mm or a 12 mm on an impact gun though - I would think the fastener head would shear right off. 14, 17, 19, 21, 35 sound good based on what I have run into so far.
  12. Nov 22, 2020 at 2:53 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Adjustable wrench fits them all! The most common use would be 21 MM for the lugs depends how deep you want to get into it.
  13. Nov 22, 2020 at 3:45 PM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    Make sure you get at least five 10mm sockets... you know what happens to them.
    djm228, ciaman96 and Wyoming09 like this.
  14. Nov 23, 2020 at 2:03 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    The thing is depends on your impact guns i have 3/4" 1/2" and 3/8" I use the 10 and 12mm all the time on the 3/8" impact .
    You will learn just how your impact works.
    They are not all created equal I have had some over the years that were just glorified nut runners.
    davidstacoma likes this.
  15. Nov 23, 2020 at 5:03 AM
    goldentaco03
    Liam
    NJ
    You should be using impact sockets with a beaker bar as well. I’ve shattered a few chrome sockets with a breaker bar
    Kevins60 and davidstacoma like this.
  16. Nov 23, 2020 at 2:14 PM
    mattvivsound
    mattvivsound Well-Known Member
    Southern MD
    '01 Tacoma TRD, 4x4, V6
    it might be cheaper to buy a pack of sockets than it is to buy 5 individual sockets.
    I think 10, 12, 14, 17 and 21 are the most commonly used ones.
  17. Nov 23, 2020 at 4:19 PM
    04tacoma trd
    Now that is a good piece of advice there and one I have violated.
    Arctic Taco likes this.
  18. Nov 23, 2020 at 5:01 PM
    goldentaco03
    Liam
    NJ
    95% of the time you’ll be fine but when you throw a cheater pipe on the end of the breaker bar things start getting sketchy and either the breaker bar or the socket is gonna break. Impact sockets are just much beefier and I use them when I remember to
  19. Nov 24, 2020 at 3:02 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    The only time I don`t use 6 point impact sockets is because a clearance issue
    Arctic Taco and goldentaco03 like this.
  20. Nov 24, 2020 at 7:47 AM
    Madjik_Man
    Colorado Front Range
