Most Common Impact Socket Sizes for Gen1?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04tacoma trd, Nov 21, 2020.
  1. Nov 24, 2020 at 10:30 AM
    goldentaco03
    goldentaco03 Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    ^ good price for a set but not impact rated sockets
  2. Nov 24, 2020 at 10:47 AM
    Madjik_Man
    Colorado Front Range
    Nope. I have the Tekton impact socket sets too.
    But 95% of my wrenching on the Tacoma doesn't need impacts. Figured I'd help the OP out with a good starter set.
    Arctic Taco likes this.
  3. Nov 24, 2020 at 10:55 AM
    Tacoscar-the-grouch
    Tacoscar-the-grouch Well-Known Member
    Josh
    North Idaho
    2001 Reg. Cab Tacoma
    OME kit 4.56's 235/85/16
    You are less likely to break a bolt with an impact than a wrench due to the shock loading being more likely to break apart the corrosion and spin out. wrench just adds torque and does not jar things loose. My impact saved my ass on all the rusted 12mm bolts in the frame and brake lines.
    I have only broken one bolt with an impact, and that was because I was an idiot and did not work the bolt back and forth a few times while removing.
    Nitro52 likes this.
  4. Nov 24, 2020 at 12:02 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Just get a set. By the time you get 4 or 5 individual sockets, you've spent the same amount.
  5. Nov 24, 2020 at 12:32 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Might be good advice for the first few sets .
    Now I just get the sizes I use the most because it works for me .
    I picked the 13 and 15 mm wrenches out of the one drawer I had 25 wrenches it will make it easier to sneak up on the 10mm wrenches
  6. Nov 24, 2020 at 1:33 PM
    04tacoma trd
    04tacoma trd [OP] Well-Known Member
    ^^^ This. When I first started working on stuff many years ago, I bought the whole S-O set. 1/4" drive, 3/8" drive, fractional, metric, short, deep, medium deep, etc. Years later, 2/3 of them have never been used. Now that I am using my impact gun (one of the best Christmas presents ever. How did I live without one all these years!), I was just looking for individual sockets. I like the protos - made in USA and not even close to the S-O cost.
  7. Nov 24, 2020 at 1:47 PM
    goldentaco03
    Liam
    NJ
    Get an impact set on Amazon on Black Friday there’ll definitely be some deals
  8. Nov 24, 2020 at 7:04 PM
    Madjik_Man
    Here's a dumb question. I don't have an impact gun (yet) but have an impact drill. Sometime I use the impact drill (with impact sockets) to bust free stubborn bolts.
    Is that stupid?
  9. Nov 25, 2020 at 2:36 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Only if you feel it should be.
    Many times I use Impact Sockets on ratchets because it is right there or it is the first one in the right size I see.
    Wulf likes this.
  10. Nov 25, 2020 at 8:02 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    I bought a GearWrench impact socket set with everything from 8-21 mm and I have found that I have used damn near every one since purchase.
    YMMV
    Madjik_Man likes this.
  11. Nov 25, 2020 at 8:51 AM
    Madjik_Man
    I was more concerned about using an impact drill vs impact gun/wrench.
  12. Nov 25, 2020 at 9:57 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    You mean a hammer drill ?
    GQ7227 likes this.
  13. Nov 25, 2020 at 11:07 AM
    Madjik_Man
  14. Nov 30, 2020 at 9:54 AM
    Tacoscar-the-grouch
    Josh
    North Idaho
    I don't see a problem. That is essentially a small impact with a different chuck on the tip, optimized for slightly different applications. The only downside I see using it for wrenching is that it would not generate as much force as a larger impact gun designed for higher torque applications.
