Most Compact Tool to Jack Up Tacoma for Maintenance?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CenterKnurl, Feb 5, 2022.
  1. Feb 5, 2022 at 8:29 PM
    CenterKnurl
    CenterKnurl [OP] Well-Known Member
    What's a safe way to Jack up a Tacoma to do basic maintenance like oil changes and trans fluid drain and fills? Rhino ramps work but I'm looking for a solution that has an even smaller footprint. Severely limited in space. I was thinking maybe a really strong bottle jack that could fit in one of the storage compartments in the back seat area and some jack stands. Thoughts?
  2. Feb 5, 2022 at 8:31 PM
    Bishop84
    Bishop84 Well-Known Member
    I have a standard bottle jack for offroading, but honestly if you want a small bottle jack... you already have one in your rear cubby.
    Rainoffire likes this.
  3. Feb 5, 2022 at 8:45 PM
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    I haven’t needed a jack to do any fluid changes on my 2017 4Runner, and the Taco has even more ground clearance (haven’t changed any fluids myself yet on the Taco because it’s still under Toyota’s free 2 year maintenance). But there’s plenty of room under there to get to all the drain plugs and filter and everything without jacking it up (unless perhaps you’re a really really big guy). The bottle jack that came with your truck and 1 jack stand is all you’d need to rotate your tires.
  4. Feb 5, 2022 at 9:02 PM
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    Following this
  5. Feb 5, 2022 at 9:06 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Unless you’re a big dude you can do all that work without jacking up the truck at all.
  6. Feb 6, 2022 at 12:43 AM
    duckytw
    duckytw Well-Known Member
    Curb outside an autozone.
  7. Feb 6, 2022 at 3:35 AM
    Montana_Actual
    Montana_Actual ;)
    Bottle jack. Ramps. But tbh, most that stuff can be done without it, like oil changes.
    Also, if you are thinking a smaller footprint means safer, then you are not doing it right. If you jack your vehicle up and get under it, you need jack stands and tire chocks. Tire chocks when using ramps too.
    Greg-tacoma, Tocamo and mquibble like this.
  8. Feb 6, 2022 at 5:34 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    I like the curb idea. I use something similar. I would never get under a vehicle with just a jack (big or small) I don’t even like ramps unless they are really heavy duty. Had a friend many years ago who’s father jacked up the car for a quick look and it was his last look. Terrible but true. I sprayed crc on the undercarriage during the fall and I just crawled under with all 4 wheels firmly on the ground, wheels chucked. Don’t be that guy
  9. Feb 6, 2022 at 7:54 AM
    Metric Rider
    Metric Rider Well-Known Member
    Gar
    Valley Farms, AZ
    2017 Tacoma TRD Sport
    Body Armor Front Bumper, Smittybilt XRC 9.5 GEN2 Winch, Fab Fours rear bumper, 400 watt inverter anytime, Front camera, On-board ARB air compressor.
