most lift without replacing uca's?
Discussion in 'ToyTec Lifts' started by h22dx, Nov 8, 2012.
  1. Nov 8, 2012 at 6:27 PM
    h22dx
    h22dx [OP] Well-Known Member
    louisville,ky
    07 trd sport
    i would like to go with the ome setup but i dont want to get into replacing uca's and all that. i just want to fit 32's so what setup would you recommend? thanks a lot!
  2. Nov 8, 2012 at 6:31 PM
    HomerTaco
    HomerTaco Grill Sergeant Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    No need to lift at all to fit 265/75 r16 - that's a 32" tire,...
  3. Nov 8, 2012 at 6:32 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    You can fit 32's without a lift. 265/70R17
    Max I'd go without UCA's is around 2" but some have had luck lifting the truck to 2.5" with stock UCA's.
  4. Nov 8, 2012 at 6:33 PM
    Hairy Taco
    Hairy Taco Masterbrachiator
    Manitoba
    08 TRD
    ^^this.
  5. Nov 8, 2012 at 6:33 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Yea, as Homer said that will fit. Although if you're under 3" of lift you should be fine without new UCA's. At 3" it's hit or miss. Some need them to get within factor alignment, some don't. I just went ahead and bought them right off the bat with my 3" lift so I wouldn't have to worry about it later. I'd recommend them regardless with 3" but what do I know.
  6. Nov 8, 2012 at 6:33 PM
    HomerTaco
    Craig
    Bucks County Pa.
    I'm at 2.5 with stock UCA's... Zero issues...
  7. Nov 8, 2012 at 6:33 PM
    Hairy Taco
    Manitoba
    08 TRD
    ^^^and this:D
  8. Nov 8, 2012 at 6:35 PM
    h22dx
    louisville,ky
    07 trd sport
    yea but i wouldnt want them all stuffed in there. i would want some flexing room. or is there enough?
  9. Nov 8, 2012 at 6:35 PM
    Hairy Taco
    Manitoba
    08 TRD
    at 2.5" of lift my alignment was barely in spec, and the truck drifted like a ship without a rudder when at highway speeds
    Hollywood459 likes this.
  10. Nov 8, 2012 at 6:37 PM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2010 TRD Sport DC LB 4x4
    Work in progress, but installed so far; 265/70/17 Duratracs, Spidertrax, OME885X coils with OME lean spacer, OME N140S and N182 shocks, Wheeler's 1.5" 3 Leaf Progressive AAL (kept the overload), LR UCAs. TP14 spacers
    X2
  11. Nov 8, 2012 at 6:37 PM
    HomerTaco
    Craig
    Bucks County Pa.
    Plenty... I ran 265's on a stock setup for quite some time with no problems at all.
  12. Nov 8, 2012 at 6:38 PM
    jtav2002
    Josh
    Reading, PA
    You'd have room. Depends what tire you get too since some run a little bigger. I have Duratracs and they were fine before I had a lift. But regardless of tire they're not going to be stuffed in there.
  13. Nov 8, 2012 at 6:38 PM
    HomerTaco
    Craig
    Bucks County Pa.
    I have heard this before too... Did not have this issue myself though... :notsure:
  14. Nov 8, 2012 at 6:43 PM
    Hairy Taco
    Manitoba
    08 TRD
    :D .... and here we are back at the same old 2.5" crossroads.
  15. Nov 8, 2012 at 6:45 PM
    h22dx
    louisville,ky
    07 trd sport
    i apologize if this is a common topic. i come from jeeps and just got my tacoma. i love it!
  16. Nov 8, 2012 at 6:45 PM
    Pugga
    Massachusetts
    F-150 Mod
    I'm under 2" and was barely in spec with my alignment. No wandering though :D
  17. Nov 8, 2012 at 6:47 PM
    Hairy Taco
    Manitoba
    08 TRD
    no need to apologize. It comes up now and again for good reason..
    yep, I got a little greedy and ended up payin for it...but thems SPC's are a little prettier...:p
  18. Nov 8, 2012 at 6:52 PM
    h22dx
    louisville,ky
    07 trd sport
    so how can i lift it about 2 inches and have it level without blowing the bank? its my dd and drive a lot of highway.
  19. Nov 8, 2012 at 6:54 PM
    dad32509
    dad32509 Thinking of something clever
    Dave
    San Diego
    Blacked out 05
    5100's front and back, OME 885x's, LR UCA's, OMD rear springs, Pioneer AVH-P2300DVD, HVAC Green led's MOD, Blacked out bumper, Plastidip emblems, custom front tube bumper, 32" combo led bar, rigid duallys, otrattw switches, my own Satoshi grille, shorty antenna, Spyder LED halo headlights. csjumper2003 map/dome, 3rd brake, DTRL white/amber and parking LED's. Pelfreybilt IFS skid, Cab mount chop, sliders and rear light bar w/blitzpro 5LR dust light. Uniden CB, Magnaflow 18" exhaust, Rear tire carrier, sway bar removed, spidertrax 1.25" spacers, Wheelers 16" Alloys w/265/75r16 Goodyear DuraTracs
    5100's
  20. Nov 8, 2012 at 6:55 PM
    HomerTaco
    Craig
    Bucks County Pa.
    Go with a spacer lift if you're not going off road... Not the best lift but easy on the wallet.
