Most Miles till Spark Plug change?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SurfnWolf, Dec 28, 2008.
  1. Dec 28, 2008 at 3:53 PM
    SurfnWolf
    SurfnWolf [OP] Well-Known Member
    Fayetteville NC
    2006 Tacoma Prerunner Double Cab
    I just went to 35,000 and replaced with Denso Iridiums, however my oem plugs looked fine...probably could have gone to at least 50,000. But since they call for replacing at 30,000 I did the change.
  2. Dec 28, 2008 at 4:07 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    I changed mine at 80k. The oem plugs had a little wear, but not bad. I put in NGK irridiums.
  3. Dec 28, 2008 at 5:58 PM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    I also changed mine at 30K
  4. Feb 6, 2009 at 8:16 PM
    cpac97
    cpac97 New Member
    Albemarle, NC
    03 prerunner dbl cab sr5
    Im at 94k with stock everything, truck still runs perfect. I plan on changing plugs wires and other things at 100k. I get around 20-22 mpg.
  5. Feb 6, 2009 at 8:22 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    138,000 miles on a 2000 tacoma. Toyota said that their was little wear on those original plugs.
  6. Feb 6, 2009 at 8:23 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    Just did my mothers Corolla. 176,xxx miles. Original plugs. There was no center electrode left but that little 1.6 never skipped a beat.
  7. Oct 9, 2010 at 8:54 AM
    c005jjc
    c005jjc Statistics are boring…until you become one!
    East Tennessee
    01 Prerunner DoubleCab SR5
    Axle wrap mod, Fumoto oil drain valve, Tinted windows
    I have 163,632 on original spark plugs 2001 Tacoma Prerunner V-6! Toyota shop said they were fine at 130,000 but I am now getting a very small miss at idle sometimes. I don't know if it is the 10E gas or the plugs. Can't do anything about the 10E gas since most all gas stations are mandated to change over soon but I can change my plugs. Right now I am trying to decide if I am going to do it myself...this post gives me the encouragement to do so...or let a shop do it. I'm leaning at doing it myself and saving a boat load of money and I know it will be done right! It is getting harder to find a shop that will treat your vehicle like it should be treated!
  8. Oct 9, 2010 at 8:58 AM
    04LTtacoma
    04LTtacoma Well-Known Member
    Morty
    Outer Space
    I changed mine at 30k miles. I started to notice the truck not having as much power as I was getting closer to 30k miles... It seemed like after replacing the spark plugs I had more power.
  9. Oct 9, 2010 at 9:52 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    I done mine, I used Chris 4x4 DIY....it was well outlined. PS....tape the socket to the extension like it says in the article.:D
  10. Oct 9, 2010 at 9:54 AM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    Got a friend who has 250k on his stock plugs.
  11. Oct 9, 2010 at 10:18 AM
    tussery
    tussery Well-Known Member
    Corpus Christi, Tx
    09 PreRunner SR5
    Magnaflow muffler, TRD CAI.
    There are no wires to change on second gens.
  12. Oct 9, 2010 at 10:43 AM
    carolinatlc
    carolinatlc Member
    NC
    05 DBL Cab Prerunner
    Had mine changed at around 40k because of a lite miss occasionally. Now at around 169k on the second set of NGK plugs. Still driving like a champ. This is a 05 DC Prerunner.
  13. Oct 9, 2010 at 11:35 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Pacific Northwest
    2018 OR DCSB 4x4
    I changed mine yesterday right at 50k.. They looked pretty dirty. I don't plan on going that long again...
  14. Oct 9, 2010 at 12:17 PM
    IslandBoy71
    IslandBoy71 Well-Known Member
    Reggie
    Lakewood, CA
    06 TRD PreRunner Sport SR5 DC
    TRD Intake,Flowmaster Super 10 exhaust, King 2.5 c/o adjusted to 3inch front and King 2.5 rears w/AAL. Custom bed rack, rock sliders and rear tire carrier.
    i changed mine out at 75k with NGK iridiums. the original plugs looked good.
  15. Oct 9, 2010 at 4:28 PM
    Jessrin
    Jessrin Oh, okay...
    Jesse
    Upper Michigan
    16 Tacoma Double Cab TRD Off Road 4X4
    Readylift 2.25 front, 2.0 back block. BFG KO2 265/75R16. AMP bed step. Weathertech floor mats, window visors and bed cover. GT3 LED Low/High headlight bulb. TRD Pro fog lights. Clazzio Seat Covers
    just changed mine on my 05 tacoma sport with the 4.0 at 160000 miles.. and yes, they were the stock factory plugs still.. Used Chris's thread to help..
  16. Oct 9, 2010 at 4:42 PM
    2TRunner
    2TRunner Well-Known Member
    Ohio
    At least my Tacoma (08/2.7/4x2/RC), under severe service, spark plug replacement is not recommended until 144 months or 120,000 miles.
  17. Oct 9, 2010 at 4:55 PM
    Duck760
    Duck760 The Duck
    I did mine ay 32k miles but stock ones looked good
  18. Oct 9, 2010 at 5:06 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Note: He has an 04.......
    I changed the plugs on my wifes 4Runner at 60k, I figured previous owner did them at 30k, but nope, ran good though.
    I also changed them on my Taco at 90k and some moron put in Autolite Platinums, yuck!!! I switched back to the regular old NGK's, it seems to run much better now.
  19. Oct 9, 2010 at 6:39 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    why the heck would you go that long on original plugs?! plugs are what..$3/each, so your looking at $20 and some quality time w/ the truck! dont see any reason why you would want to go that long...enlighten me...
  20. Oct 9, 2010 at 7:15 PM
    tussery
    Corpus Christi, Tx
    09 PreRunner SR5
    I think the 2004's have ignition coils also.
    Confusing info on the internets. I was wrong they do have wires.
