Most power out of a cat-back system for a 97
Discussion in '4 Cylinder' started by karlkx3, Feb 12, 2010.
  1. Feb 12, 2010 at 10:28 PM
    karlkx3
    karlkx3 [OP] Member
    Karl
    619
    97 Taco
    Broken Exhaust right after the cat... So its an exhaust manifold and cat, really really LOUD!!!
    Does anyone know which aftermarket cat-back system provides the greatest power increases? Really the only new ones I can find are from Gibson and LC Engineering. I know that there must be others out there but how do they compare? Right now my exhaust is broken right after the cat, so the way the new system sounds isn't a big concern because anything will be better. I want performance more than sound.
  2. Feb 12, 2010 at 10:42 PM
    PacNWgen1
    PacNWgen1 NewHere
    Adam
    Oregon
    96' Tacoma Reg Cab 2.7l 4x4 5-speed 150,000+
    DynoMax ST, Deck Plate, Full Syn, Soon Header and Slotted Rotors
  3. Feb 24, 2010 at 5:50 AM
    thenrie
    thenrie Well-Known Member
    Stafford, VA
    2000 Tacoma, SR5, TRD, 2.7L (LEV), 4wd, 5sp m
    Magnaflow cat and cat-back exhaust, AFE Stage 2 cold-air intake system, 2.5" lift via Skyjacker leaf packs, Bilstein 5100s.
    You aren't going to get a noticeable power increase from any cat-back system over stock. It just sounds like you do. I have never seen anybody, who wasn't selling one, produce any tested numbers to indicate a power increase. Just a lot of folks who say, "I got a lot more power!" or "I felt more power in the upper rpm range." In reality, it sounds more powerful, but it isn't. They are a lot less expensive than replacement with oem stuff, so pick the one that has the sound you want and go with it.
