Most Powerful naturally aspirated 6cyl
Discussion in 'Performance and Tuning' started by tostidos, Aug 8, 2012.
  1. Aug 8, 2012 at 5:52 PM
    #41
    tostidos
    tostidos [OP] Well-Known Member
    Apple Valley, CA
    07 LT 6spd
  2. Aug 8, 2012 at 6:21 PM
    #42
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    are you 4x4?
    If not, get rid of the stock sub frame and go center mount but with a less than 85" track width. You get more travel but you stay narrow, thus, 7200 class legal :D
  3. Aug 8, 2012 at 6:29 PM
    #43
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    You are allowed a sealed Ecoboost engine according to the 7200 rules. It makes 365 hp and 420 lb-ft stock.
  4. Aug 8, 2012 at 7:16 PM
    #44
    tostidos
    Apple Valley, CA
    07 LT 6spd
    I think center mount violates the rules :notsure: hmm on the ecoboost
  5. Aug 8, 2012 at 7:19 PM
    #45
    tostidos
    Apple Valley, CA
    07 LT 6spd
    and if I was doing that much work doing center mount and new engine I would want to push the engine back as well seems like a waste of fab time if I decide to switch to 1400 down the road... or not worth losing the experience in 7200
  6. Aug 8, 2012 at 7:20 PM
    #46
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    LOVE the S54 omfg :drool:
  7. Aug 9, 2012 at 8:54 AM
    #47
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    I think your best bet is to contact LCE for info and prices.
    http://www.lceperformance.com/
    The $5000 price cap for a Toyota V-6 race motor is pretty unrealistic unless you do all the work yourself or have someone to do it for next to nothing. Maybe a buddy who is a Toyota master tech?
    Finally, you should probably spend money on fixing weak points on the truck rather than looking for more power. Going faster wont help you if your truck breaks and doesnt get across the finish line. Heidi Steele's Ranger had a close to stock V-6 and they still dominated. The truck was dialed and that is what won races.
  8. Aug 9, 2012 at 9:02 AM
    #48
    tostidos
    Apple Valley, CA
    07 LT 6spd
    ...truck is in the shop for all that right now... this is something i will look at doing in a year or 2 but i want to find out what to work towards doing. i need to learn to drive the truck first but the truck is being beefed up right now as we speak. solid motor and tranny mounts and engine cage + gusseting. not to mention a rear end rated to 600+HP to give me a good buffer.
  9. Aug 9, 2012 at 9:05 AM
    #49
    tostidos
    Apple Valley, CA
    07 LT 6spd
    and thanks for the link this is what im looking for! i need to find the specs tho
  10. Aug 9, 2012 at 9:07 AM
    #50
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Curious question, and possibly a Newb one when it comes to off-road racing, but is it normal to solid mount the engine and trans in that style of racing?
  11. Aug 9, 2012 at 9:12 AM
    #51
    tostidos
    Apple Valley, CA
    07 LT 6spd
    research has me to believe that they are getting 410-450 to the wheels with the $6500 model
  12. Aug 9, 2012 at 9:14 AM
    #52
    blackhawke88
    SGV, CA
    07 TRD Offroad
    Definitely solid mount that engine for racing, but i know certain race trucks that run stock mounts still
  13. Aug 9, 2012 at 9:15 AM
    #53
    tostidos
    Apple Valley, CA
    07 LT 6spd
    yes the constant hits and jolting around tears the mounts up real quick.
  14. Aug 9, 2012 at 9:27 AM
    #54
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  15. Aug 9, 2012 at 9:42 AM
    #55
    tostidos
    Apple Valley, CA
    07 LT 6spd
    X2
  16. Aug 9, 2012 at 9:45 AM
    #56
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    A done NA Buick V6 will kick the crap out of most all V6's you can put together....inexpensively. You could build 3 Buicks for the cost of 1 Honda. The wrecking yards are littered with 4.1 blocks.
  17. Aug 9, 2012 at 9:54 AM
    #57
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Increased compression, Cometic head gaskets, ported heads, welded and ported lower intake plenum, TCR custom intake manifold, custom adjustable cam gears, automatic transmission. He was shooting for 300 whp I believe, while staying N/A. Add some cams, headers, and a free flowing Y-pipe to the mix, I could easily see it being around 350 whp.
  18. Aug 9, 2012 at 6:31 PM
    #58
    KenLyns
    Belly of the Beast
    With all the forged internals, can the redline be safely raised? Another way to make power.
  19. Aug 9, 2012 at 6:33 PM
    #59
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Yes but you'll need to know the limits of the oil and water pumps.
  20. Aug 9, 2012 at 6:35 PM
    #60
    tostidos
    Apple Valley, CA
    07 LT 6spd
    true but that would be high end power, nice and all but low end power is kinda what im looking for... an option tho. I might consider getting a 4.0L tearing it apart bore it out maybe stroke it to get 400 with intake exhaust headers and cam? possible?
