Most Powerful naturally aspirated 6cyl
Discussion in 'Performance and Tuning' started by tostidos, Aug 8, 2012.
  1. Aug 14, 2012 at 7:24 PM
    #81
    Lucario Runner
    Lucario Runner Resident SUV racer
    Robert
    San Antonio, TX
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, LC Engineering sway bushings, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    WANT!!!!!!!!!!!!!! SO MUCH WANT.
  2. Aug 15, 2012 at 7:08 AM
    #82
    Twistinemup307
    Twistinemup307 Well-Known Member
    Alex
    Wyoming
    2012 DCLB tacoma SC sport
    lol yeah man thats the only performance mod you need! and underglow :cool:
  3. Aug 15, 2012 at 9:45 AM
    #83
    Speed Freek
    Speed Freek Turbo lover!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Currently under the knife for turbocharger..
    Whats the deal with that?
    Overbore sleeves? If so how much displacement is added, and is there a stroker crank as well to compliment this?
    I remember you and Balsby doing something a while back with APR, is that what it is?
  4. Aug 15, 2012 at 11:00 AM
    #84
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    These are Darton Modular Integrated Deck (M.I.D.) sleeves. Completely replace the factory sleeves. Gadget shipped themone of my spare blocks so that they could cut it apart and get all the necessary measurements to the sleeves. With these, one could have them bored without worry of sacrificing cylinder strength. Obviously. The only question would be how much you could go based off of the combustion chamber. Easily .020 over. How much more than that, I do not know. And engine builder would have to make a recommendation on that.
    There are also stroker cranks already available from Brian Crower. Have to order them from a place called Sub-Zero performance, or something like that, out of the UAE. That Brian Crower crank was $4k last I checked, and made the engine a 4.3 L
    Or have LCE make one for half of the cost. $2200. They use a company that makes one off racing cranks.
    Balboa was supposed to have custom sleeve inserts done to his block. Those still left the factory sleeve, bit bored it out for the inserts to fit. Still leaving the open deck. Still allows for top of cylinder wobble too.
    The Darton sleeves you see in the picture are what I did/am doing.
  5. Aug 15, 2012 at 11:10 AM
    #85
    Torspd
    Torspd Tor-nication
    Tor
    Houston
  6. Aug 15, 2012 at 12:24 PM
    #86
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I just read through that whole thread and after the sleeves were complete, nothing else happened. I was really looking forward to Gadget getting his engine built by APR but they sound like a bunch of incompetent jackasses. I can't wait to see either yours or Gadget's engine built up although both seem to be leaning towards a boosted setup...
  7. Aug 15, 2012 at 1:00 PM
    #87
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
  8. Aug 15, 2012 at 1:30 PM
    #88
    whippersnapper02
    whippersnapper02 Well-Known Member
    Christian
    Yorba Linda, CA
    10 MGM TRD OR 4wd Auto DCSB
    Banks Monster Exhaust, Pop n Lock tailgate lock, Hook-Ups tie down brackets, USA Spec Ipod adaptor, WO seat covers, color matched grill with Grillcraft insert, Tuffy locking bed box
  9. Aug 15, 2012 at 2:20 PM
    #89
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    Correct. I am building mine because i am planning to run a lot of power and boost through it. I want it to be "reliable." Thus the sleeves.
    However, the point I am trying to make about the sleeves, if someone reeeeeeeally wanted to, they could get the block sleeved and over bore the engine. Increasing displacement and still having a strong cylinder.
    The other way would be to just swap in a stroker crank. But leave every thing else relatively the same. As far as internal specs go.
    That would be cheaper than rods and pistons, if one only wanted to swap that in, a 'unknown' good amount of power would be picked up from just the stroker crank.
    Add to it a UCON for tuning, with its cam gears and lower t-stat. Then you will have an easy and relatively cheap build that should be over 300whp.
