Motive or Vacuum bleeders
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ARB1977, Sep 7, 2019.
  1. Sep 7, 2019 at 5:24 PM
    ARB1977
    ARB1977 [OP] It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Ive got a motive brake bleeder. Although the manual says to do two person method. Has anyone used either bleeder with success? I used it when I had my 2002 Tacoma with no issues although that truck had no abs. Thanks.
  2. Sep 7, 2019 at 5:35 PM
    Gixerkiller
    Gixerkiller TW...what a silly place
    Dennis
    Taylor, TX
    2015 Tacoma Pre Runner DCLB White
    decals, morale patches, headlights, tail lights, toytech lift w 5100s, Falken Wildpeaks.....
    I use the old tried and true method.
    Mason or Gatorade bottle and a 1/4 inch tube about 3 feet long. Add some clean fluid to the bottom of the bottle, attach line to bleeder tit,
    Open tit, push the brake pedal about 8 times, check fluid level in res, fill as needed....repeat.
    Never a bubble or air intrusion.
    (Will use a vac pump for master cylinder or line replacement just to get the fluid moving. Usually a hand pump though)
    spitdog likes this.
  3. Sep 7, 2019 at 5:52 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    PzTank likes this.
  4. Sep 7, 2019 at 5:56 PM
    ARB1977
    North Texas
    Thanks
  5. Sep 7, 2019 at 5:56 PM
    ARB1977
    North Texas
  6. Sep 7, 2019 at 6:02 PM
    Lord Helmet
    Nick
    '24 X3 M40i
    :thumbsup:
  7. Sep 7, 2019 at 6:39 PM
    TacoTuesday1
    SD CA
    OP,
    what is this "the manual" you speak of?
  8. Sep 7, 2019 at 6:46 PM
    ARB1977
    North Texas
  9. Sep 7, 2019 at 6:51 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    This is the easiest, fastest and cheapest way.
  10. Sep 8, 2019 at 8:05 AM
    Rob MacRuger
    Rob MacRuger Well-Known Member
    2006 4X4 SR5 4.0
    Any hardware store should carry it. Didn't one come with the Motive unit?
  11. Sep 8, 2019 at 11:58 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    My one person bleeder.
    Just make sure fluid is above end of tube in bottle.
    Worked good on my 08
    Kolunatic likes this.
  12. Sep 8, 2019 at 4:57 PM
    ARB1977
    North Texas
    Even though you let off the brake air won’t get sucked back in because the hose is submerged? Thanks
  13. Sep 8, 2019 at 4:57 PM
    ARB1977
    North Texas
    I don’t think so
  14. Sep 8, 2019 at 5:02 PM
    IcyHott
    IcyHott Active Member
    Western MA
    2012 Toyota Tacoma 4x4
    Lord Helmet likes this.
  15. Sep 8, 2019 at 5:22 PM
    ARB1977
    North Texas
  16. Sep 9, 2019 at 3:50 AM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Yes no air is able to get back in.
    If it sucks it sucks fluid.
    If a second person is available I do the two person pump hold bleed.
    The bottle actually worked well for me.
  17. Sep 9, 2019 at 4:51 AM
    ARB1977
    North Texas
    Awesome man, thank you. Now does the truck have to be running for the abs system or does it really matter?
  18. Sep 9, 2019 at 5:22 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Just pick up one of these bad boys: For $33 it is very handy; you can bleed/flush lines in under 30 minutes for the whole truck. Sure it's more expensive than the soda bottle method, but less fuss.
    ARB1977[OP] and JGO like this.
  19. Sep 9, 2019 at 7:40 AM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    I’ve done both didn’t seem to matter.
    I’ve also just let gravity do it’s thing.
    ARB1977[QUOTED][OP] likes this.
  20. Sep 9, 2019 at 10:41 AM
    mystert
    mystert Well-Known Member
    Eric
    Ventura CA
    2005 Tacoma TRD Sport 4x4 6spd
    I have the same adapter and it works fantastic. I've used it to bleed my Tacoma, and my neighbors Scion TC and Tundra. Makes bleeding the clutch super easy as well. One issue to look out for is the condition of the hoses with the motive bleeder. They are not reinforced and tend to get brittle after a few years. I replaced mine with reinforced hose after the stock hose burst and sprayed brake fluid all over the place.
    ARB1977[OP] likes this.
