Motivx Oil Filter Drain Tool Alternative?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CenterKnurl, Feb 3, 2022.
  1. Feb 3, 2022 at 10:09 PM
    CenterKnurl
    CenterKnurl [OP] Well-Known Member
  2. Feb 3, 2022 at 10:23 PM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    I've got the MotivX model, along with the fill funnel, wrench, etc. It's awesome but I bet the others are close. Worse case, buy it and if it's not solid and machined well, send it back!
  3. Feb 3, 2022 at 11:14 PM
    Montana_Actual
    Montana_Actual ;)
  4. Feb 3, 2022 at 11:41 PM
    soysauce021
    soysauce021 Well-Known Member
    Bay Area, CA
    2021 DCLB Sport
    The oem filter also come with a plastic piece to drain the oil from the housing. It’s not as nice as the motivx but works just fine.
  5. Feb 4, 2022 at 1:29 AM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
  6. Feb 4, 2022 at 1:35 AM
    Kevin Jones
    Kevin
    Va
    Works fine if you don't mind getting oil all down your arm and on the floor when you insert it into the housing.
    The ones above allow you to insert the valve, route hose into oil drain pan, then open valve to release oil from the housing. Thus no mess.
  7. Feb 4, 2022 at 3:55 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I use that plastic gizmo that comes with a new filter and a short piece of hollow metal tube i had laying around the shop. The tube is about a foot or so long and the plastic drain gizmo fits into the end of the tube perfectly.
    Just point the bottom end of the metal tube at your drain bucket and jam the plastic thing (that's mounted in the other end of the tube) up into the filter housing hole. The oil drains through the metal tube and into the bucket with zero mess. Cheap solution that works great.
    Lenny Dykstradamus likes this.
  8. Feb 4, 2022 at 4:08 AM
    hfjeff
    hfjeff Well-Known Member
    Frozen Tundra
    2021 Army Green Off Road
    Tons of knock-offs on FleBay. I just searched for Toyota oil drain tool and found a bunch. Not a huge investment so maybe worth trying out. I just use the plastic one that comes with the filter.
  9. Feb 4, 2022 at 4:25 AM
    gForceDude
    gForceDude Well-Known Member
    I use the plastic drain 'gizmo' that comes with the filter.
    I hold it in the end of the cardboard tube left over from an empty roll of paper towels; and when I shove it up in there, all of the oil goes down the inside of the tube into the pan, instead of down my arm.
    Its a bit of a crude, homegrown solution; but it works, it's readily available, and it's free.
  10. Feb 4, 2022 at 5:07 AM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    The cheap one works great and i cut the tube to hang just below the rim of my catch can so it doesnt get all oily.
    Fumoto valve takes 20+ minutes to drain due to the hole being much smaller than the hole in the oil pan. Hard pass!
  11. Feb 4, 2022 at 5:15 AM
    GrizzledBastard
    Tim
    Central Coast, CA
  12. Feb 4, 2022 at 5:20 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I just take the housing off without draining it.
  13. Feb 4, 2022 at 5:23 AM
    Cereal_killer
    Cereal_killer Well-Known Member
    Dan
    '18 Off-road, ‘96 V6
    Yeah
  14. Feb 4, 2022 at 5:34 AM
    GrizzledBastard
    Tim
    Central Coast, CA
    That's bitchin. Is that the correct thread for our Tacos? I forget so I'll have to look up my old order unless you confirm.
    EDIT: Yep, Same thread. Good to go. You guys with the short nipple....does the drain hose still snap on to that okay? I have a longer nipple on mine. TWSS.
    Montana_Actual likes this.
  15. Feb 4, 2022 at 5:41 AM
    Cereal_killer
    Dan
    Yeah
    Yes that’s the one for our 3.5’s.
    I use a short section of some random blue silicone hose I had laying around, it pushes onto the stubby nipple just fine.
  16. Feb 4, 2022 at 7:55 PM
    GrizzledBastard
    Tim
    Central Coast, CA
    I have the Fumoto hose that comes with a couple plastic couplers, one straight, the other 90* that snaps over that little rib on the valve outlet. I'm sure it fits now that I think about it. It's designed specifically for that purpose. I ordered the new style. It'll be here tomorrow, I think! I'm creeping up on my 10k change so I'll switch it out then. Thanks for the heads-up on this!
    Cereal_killer[QUOTED] likes this.
  17. Feb 15, 2022 at 5:50 AM
    udrunk2002
    udrunk2002 Well-Known Member
    I swapped out my oil filter housing for a metal one. I couldn't get that retainer pin back on. Does everyone just trash them or is there a trick to it? I tried using needle nose pliers to crimp it back on with no luck...looked like it was loose and would fall off
