Moto Metal wheel question
Discussion in 'Wheels & Tires' started by rotate, Mar 21, 2010.
  1. Mar 21, 2010 at 8:23 AM
    rotate
    rotate [OP] Member
    Rick
    Georgia
    prerunner SR5
    Anyone running 18 inch Motometal on stock suspension?I,m looking at 18x9 with 18 offset.Checking forums.Looks like biggest tire I can run is 265-65-18 on stock suspension.Wondering if this wheel and tire compatible.I have stock 2010 prerunner with 245-75-16.I checked site calledwww. big wheel.net,and it state this is only 18 motometals that compatible. Under tire recommends it state 275-60-18,265-60-18 and 275-55-18.Does not mention 265-65-18 but it may be cause they dont stock that size.Appreciate any input.thanx
  2. Mar 21, 2010 at 4:33 PM
    rotate
    rotate [OP] Member
    Rick
    Georgia
    prerunner SR5
    Somebody out there has to know soemthin about this.Let me hear from you
  3. Mar 23, 2010 at 4:10 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    I'm running moto metal 17x9's, the issue I had with tire fitment is finding a tire to fit a 9" wheel....some brands of the same sizes are not suggested for a 9" wheel. I'm running Nitto TG's.
    So check the specs for whatever brand of tire you want and see if they work for a 9" wheel and also which size is 32" or smaller. Over 32" will definately rub. I had to trim a little to fit 265/70/17 on stock suspension.
    Don't know if this helps...
    IMO 18's are going to look huge.
  4. Mar 23, 2010 at 7:13 AM
    rotate
    rotate [OP] Member
    Rick
    Georgia
    prerunner SR5
    Appreciate your help.Was about to give up on Tacoma World.You answered what I was thinking.Figured it would depend on wheel.Are you running 951 chrome by chance?appreciate pics if you have.Thanx again
  5. Mar 23, 2010 at 7:22 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    here are the 958's they are similar to the 951's
    mine are 285x65x18"
  6. Mar 23, 2010 at 1:35 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I'm running 18x9's on stock suspension with 265/65/18's, no issues. My offset is +10mm though. +18 will push it pretty close to the UCA. On the tire manufacturers website it will say what size rim it is safe to run their particular tire on, for a given tire size.
    My rims aren't moto metals, but this can help you visualize the size.
  7. Mar 25, 2010 at 1:19 AM
    rotate
    rotate [OP] Member
    Rick
    Georgia
    prerunner SR5
    Thanx for info guys and girls.For 1500-2000 outlay,want to be sure I get something that wiil work.Soon as I get some tires I,ll post some picks.
