Moto Metals on unlifted Tacoma
Discussion in 'Wheels & Tires' started by Nolz, May 4, 2010.
  1. May 4, 2010 at 9:58 PM
    Nolz
    Nolz [OP] Active Member
    Eddie
    Jacksonville, FL
    09 Timberland Mica DC TRD Off Road
    TRD Decals (Removed), Mud Flaps (Removed), Undercover Tonneau, Bed Mat, All-Weather Mats, Bug Shield, Tint
    Let me first say that I've searched for 3 days and have read several threads regarding Moto Metal rims. I am looking at picking up a set of 955s for my 09 Double Cab prerunner (TRD OR). I have read that some folks have installed these rims (or the 951s) with 265/75-16 rubber and have had rubbing issues. I took the mud flaps off my truck months ago, but I'm not looking to lift my truck and would rather not trim in the fender well area. My question is... if I stay with the stock tire size (265/70-16) or possibly go with the narrower tires (245/75-16) will I still have to deal with rubbing?
    Rim info...
    -4.501 backspacing
    -0mm offset
    -106 hub bore
    -16x8, 6 on 5.5/bolt pattern
    Any input is much appreciated :)
  2. May 4, 2010 at 10:05 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Thats perfect size, and you will not have any rubbing issues, you will have no problems with that setup
    Actually, make sure they are hub centric and your good
  3. May 4, 2010 at 10:09 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Yep, what he said^^^
  4. May 4, 2010 at 10:18 PM
    Nolz
    Eddie
    Jacksonville, FL
    I love this site! Thanks for the quick reply. Which of the 3 tire sizes are you referring to?
    265/75-16
    265/70-16
    245/75-16
    I get the impression that the Moto Metals (referred to in my original post) stick out slightly more than the current TRD OR rims. Is that correct? If so, does that determine which tire size will allow me to avoid lifting and trimming?
    Thanks again, guys!!!
  5. May 4, 2010 at 10:23 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    You can run 265/75/16s with no rubbing issues...I did it with stock wheels and no lift
  6. May 4, 2010 at 10:24 PM
    ktmrider
    Junk
    Yes, the rims will stick out about an inch more, and none of those tire sizes would have a problem, I would go 265/75/16 the biggest will look better IMO. Lifting and trimming will not be necessicary
  7. May 4, 2010 at 10:26 PM
    Nolz
    Eddie
    Jacksonville, FL
    Thanks, guys :)
  8. May 4, 2010 at 10:32 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    And post pictures when it is installed!
  9. May 4, 2010 at 10:35 PM
    Nolz
    Eddie
    Jacksonville, FL
    Pics? Sure thing! Give me a about a week...
  10. May 5, 2010 at 10:23 AM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    Just to throw a wrench in the works. I also have heard that the 16x8 Metal Moto 951s will rub on the front caliper, and that the Metal Moto 951s in 16x9 will rub slightly when the wheels are fully turned.
    Neither of these sound like great options to me, but I'm considering the 16x9s anyway, because I really like these wheels and how often really do you turn the wheels to the max anyway, right?
    I also do not plan to lift my truck.
    There must be some more 951 owners on here willing to verify either way, because there are plenty of 951 pics on here.
  11. May 6, 2010 at 4:47 AM
    crazybayman
    crazybayman Oh 'eah
    Newfoundland
    09 4x4 4.0L V6 Access Cab Standard
    AutoStart, Sirius Satellite Radio, 16x8 Moto Metal 955s, 265/75/16 Duratracs, Fog Lights, Skid plate
    I'm looking at getting that same setup..........Moto Metals 955 with 265/75/16s
    Any idea if the tire will make contact with the mudflap and potentially tear it off?
    I've been told by a guy at my local Toyota dealership that running a 265/75/16 can tear the mudflap off, while going in reverse. I assume he means while turning. Any idea if there is anything to this?
    Also, did any of you Moto Metal owners have any issues installing the pressure sensors on them?
    Do they need to be hub centric?
    Apologies for the barrage of questions......
  12. Jun 17, 2010 at 11:01 PM
    supermace
    supermace New Member
    Los Angeles
    09 Prerunner TRD Sport Debadged. Speedway BL
    Nerf bars, Bull Bar, Billet Grill, Window Tint,
    true the moto metal 951's rub slightly on the mud flaps and front plastics. im gonna take flaps off and trim a bit.
  13. Jun 18, 2010 at 12:01 AM
    ColtsTRD
    Scott
    AZ
    x2
  14. Jun 18, 2010 at 4:24 AM
    crazybayman
    crazybayman Oh 'eah
    Newfoundland
    Yep, sure enough, they rubbed my mud flaps, too. Trimming did the trick.
    The motos aren't hub centric, and I have no issues so far. I ordered spline lugs nuts with mine, and from what I understand the spline lugs support the wheel instead of the hub bore, so it centres the wheel that way.
  15. Feb 7, 2013 at 9:34 AM
    shrek
    shrek I am lost on what to do.
    Shane
    Concord, NC.
    07 PreRunner Stock
    Weathertech mats. Led interior lights, 3rd brake light, and lic light. 13" Euro antenna from Antennax, Front windows tinted, EGR In Channel Vent Visors.
    I have heard that the 16x8 will hit the caliper. I am looking for a set but having a hard time finding them.
  16. Feb 7, 2013 at 9:38 AM
    tsup74
    tsup74 Well-Known Member
    Alberta
    2013 Tacoma Double Cab
    Extang Solid Fold, pop and lock
    my apologies for hijacking this thread.
    My question is; would dropping from a 17" rim to a 16" still fit on my 2013 DC?
    I see on some forum threads that the brake callipers may rub?
    I'm specifically looking at the KMC 122 Enduros with a 265/65/16 tire.
    Thanks
  17. Feb 7, 2013 at 9:42 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    16s are the smallest you can run on a 2nd gen Tacoma...
    And holy thread revival :laughing:
