Motor BLEW UP...Used or Rebuilt replacement?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rumrunners2k, May 5, 2020.
  1. May 5, 2020 at 7:58 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    The problem as I see it is no machine shop has built literally millions of the exact same motor and therefore no machine shop can claim the same reputation that a Toyota built motor comes with. With Toyota the sample size is high enough to feel good about your chances. No shop can offer that.
  2. May 5, 2020 at 8:05 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    You do realize that engines aren't on the level of precision of a mechanical wrist watch, right? A quality machinist has tools and skills to check and verify that their work is within spec - the same spec that Toyota manufactures to.
    cosmicfires likes this.
  3. May 5, 2020 at 8:23 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    $18,000
    specter208 and US Marine[QUOTED] like this.
  4. May 5, 2020 at 8:40 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    That's about what I've got into my new sbc for my Camaro !!!
    henryp likes this.
  5. May 5, 2020 at 8:42 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    What year is the truck? If it's pre-2012 find a low miles J-VIN from a 2007-2009 FJ. Post 2011 any low miles from a Tacoma.
    Best bet is find an engine from a known local source.
    Either case, BEFORE you install the engine, no matter how many miles on it, pull the valve covers and upper oil pan and inspect it and put a camera in the cylinders. That's about the best you can do to protect yourself without pulling the whole engine apart. I got a 1GR-FE one time that was 100% legit pulled from a truck with 47K miles on it, looked perfect! Pulled the valve covers and, yup it it did have 47K miles on it, problem was.... Never had an oil change since brand new. Shipped it right back to them.
    If your going to swap the engine, I'd also go ahead and replace...
    - Valve cover gaskets
    - intake gaskets
    - exhaust gasket
    - PCV valve
    - hoses
    - Radiator
    - pulley bearings
    - thermostat
    While you got it out of the truck.
    Also inpect the fuel injectors, especially 5 and 6, alot easier to replace while your doing the other stuff than later :)
  6. May 5, 2020 at 8:45 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    1GR-FE are close to a wrist watch in precision as compared to most engines actually. It doesn't take much to throw everything out of whack. You can't machine much.
    Skyway and Rumrunners2k[OP] like this.
  7. May 5, 2020 at 8:51 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Above all do not buy an engine from a 2004-2006 4Runner, 2005-2006 Tacoma.
    Rumrunners2k[OP] and crazy joker like this.
  8. May 5, 2020 at 9:18 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    plus it’s hand built. If the machinist is skilled and careful it will be built to a higher standard than a machine made factory motor.
  9. May 6, 2020 at 5:39 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    From a cost/benefit view, I would do a good used engine all day before doing a rebuild or buying a rebuild. You can inspect, check the compression, and do all the maintenance before you put it in the truck.
    jboudreaux1965 and jetfishn like this.
  10. May 6, 2020 at 6:40 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    I have nothing to add but really want to know the reason for driving your truck even though every possible dash warning lights are illuminated?
  11. May 6, 2020 at 9:38 AM
    Rumrunners2k
    Rumrunners2k [OP] Well-Known Member
    This is the type of response I was looking for. Someone with experience with a swap/replacement/rebuild. My truck is an '08 4x4. What is the advantage of a 2007-2009 FJ engine over a Tacoma of a similar year?
    I found an engine from a 2011 Tacoma with 70k miles on it. Ran a carfax and it has maintenance history (regular oil changes), including a 50k and 60k service (actually done at 69k per the carfax history report) right before it was totaled at 70k. The Carfax indicates it was maintained at the dealer through its entire life and only had 2 owners, so it's looking like a solid runner, and it comes with a 6-month warranty.
    I will do all the checks you suggested and replace the gaskets.
    Thank you!
  12. May 6, 2020 at 12:26 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    You have to check out the machine shop carefully. The one I've used rebuilds all sorts of exotic engines. When I first went there they showed me the shop, there were 12 cyl Ferrari engines and others that you probably couldn't get another one if it got messed up. I'm confident they can assemble a better engine than the factory.
    Factory pistons said they were balanced to 1 gram on the box, they static and dynamically balanced the engine to 0.1 gram, an order of magnitude better.
    The 22R engine with a factory red line of 6000 rpm was now safe to 8000, with the long duration cam it ran great.
    I would take an engine this shop rebuilt over a new factory engine.
    Torspd likes this.
  13. May 6, 2020 at 12:36 PM
    1997tacomav6
    Denver
    You can find a used motor with under 100,000 miles for 1500.00 from a rolled truck or rear end crash if you have time to look.
    Do a carfax on it, look on Craigslist.
    Shop around and you can find someone that will do the swap for 1500.00
    It will cost you in the range of 3000.00 depending if you reseal the new motor that you buy.
    Rumrunners2k[OP] likes this.
  14. May 6, 2020 at 2:06 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Crazy. I can build a full on 500 hp 327 Chevy race motor for less than 12k.
  15. May 6, 2020 at 2:13 PM
    #35
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Get a 3.5 out of a wrecked 3rd gen. Toyota says it's the better engine.
    landphil likes this.
  16. May 6, 2020 at 4:24 PM
    #36
    Rumrunners2k
    I don't think that's plug and play
  17. May 6, 2020 at 8:51 PM
    #37
    DanaPtTaco
    DanaPtTaco Never-ending problems
    Thomas
    Orange County, CA
    07 ACLB Prerunner 4.0 AT
    Lots of good info on here, sub’d cause I’m in the same boat
  18. May 7, 2020 at 8:51 AM
    #38
    Rumrunners2k
    Thanks, I plan on doing the swap at a buddies shop, so I'm willing to spend a little more on the motor since Ill be saving a ton on labor.
  19. May 7, 2020 at 9:12 AM
    #39
    1997tacomav6
    Denver
    Cool,
    Because the motor will be out of the truck and if you have the time these are things you can do
    AND will be so easy with the engine out.
    Do
    1) rear main seal
    2) clutch, pilot bearing
    3) timing belt and all those parts
    4) valve cover gaskets
  20. May 21, 2020 at 10:46 PM
    #40
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    2007-2009 J-VIN 1GR-FE were made in Japan, not the US or Mexico. They are generally accepted as the best 1GR-FE and they will drop into a pre-2012 Tacoma with no issues. So if your going to do a swap, that's what I would recommend. Got 2009 J-Vin in mine :)
    kingk0ng likes this.
