Motor Mount bolts working loose
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drwambo, Mar 12, 2018.
  1. Mar 12, 2018 at 7:40 AM
    drwambo
    drwambo [OP] Member
    Hi all,
    The frame on my 06 truck was replaced in 2015, and all was well. Last September (2017), I took my taco in for a squeaking noise. They diagnosed it as a loose rear motor mount on driver's side. Tightened it down, etc. It is now March 2018, and I'm here again with the same exact problem.
    Even the tech is confused. They should not work loose. I suggested locktite!
    Any ideas??
    Doug
  2. Mar 12, 2018 at 7:45 AM
    Clearwater Bill
    Billy
    Largo Florida
    Blue locktite.
    If they are going to charge for the work, DIY
  3. Mar 12, 2018 at 7:50 AM
    drwambo
    drwambo [OP] Member
    Oh there's NO WAY, I'm paying for this. It's the second time it's been here for the same problem.
  4. Mar 12, 2018 at 9:52 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Loctite and torque it down.
  5. Mar 12, 2018 at 10:16 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    There are only two engine mounts on the 1GR. Is the noise coming from the single top nut, or the 4 bolts which connects the mount to the frame?
    Regardless, like the others said. They need to use a thread locker. Inspect it afterwards, or have them show you that they used it.
  6. Mar 12, 2018 at 10:53 AM
    drwambo
    drwambo [OP] Member
    It's the bolts themselves. I was standing there when he loosened one with his fingers and just pulled it out. The front one was loose as well. Both bolts were new (replaced last september when this happened the first time) He for sure used some sort of thread locker on them...
  7. Mar 12, 2018 at 11:00 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Good. To be honest. I have removed and installed mine many a time. Never had an issue, and never used a thread locker. Always just made them tight.
