Motor Mounts: How Much Movement is Too Much?
Discussion in 'Technical Chat' started by samiam, Aug 9, 2016.
  1. Aug 9, 2016 at 6:24 PM
    samiam
    samiam [OP] Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    Below is a video I took of my passenger side motor mount. It was taken on pavement at a max speed of 35 mph. On occassion when I shift to 1st gear from nuetral at a complete stop I get a light thud from the drivetrain. My shifter also moves quite a bit under acceleration in 1st gear.
    So I'd like you all to take a look at the video and give some feedback on whether the movement is normal.
    Thanks in advance.
  2. Aug 9, 2016 at 7:09 PM
    Celphdesigns
    Celphdesigns Member
    Texas
    2012 TRD Sport AC
    I get the same light "thud" coming to a complete stop as my automatic shifts from 1st to neutral and then again when I let off the brake to get back on the gas. Figured it might be motor mounts but not sure.
    samiam[OP] and ChadsPride like this.
  3. Aug 9, 2016 at 7:34 PM
    samiam
    Sam
    Stinky Vegas
    Thus, my delima. But I'll probably replace them.
  4. Aug 9, 2016 at 7:39 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    I have never taken a video of a motor mount but IMO that is probably perfectly normal. They are supposed to flex a bit. Back in my hot rod and drag racing days I would either use solid mounts or chain one side of the engine to the frame to prevent rubber mounts from tearing in half under acceleration.
    samiam[OP] likes this.
  5. Aug 9, 2016 at 8:04 PM
    samiam
    Sam
    Stinky Vegas
    Chain the engine to the frame...hmmm
  6. Aug 9, 2016 at 8:19 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    Lol. It didn't stop the normal flex, just prevented the mounts from flexing enough to destroy themselves.
  7. Aug 9, 2016 at 8:31 PM
    samiam
    Sam
    Stinky Vegas
    I took the video because of some clunking from the front end when driving over bumps. Only the motor mounts looked suspicious to me.
  8. Aug 13, 2016 at 1:56 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Yes chaining the Engine to the frame brings back memories.
    The feel of launching a 750 plus horsepower car is something one never forgets
    the torque would just pull the right mount apart making a big mess
  9. Aug 13, 2016 at 7:04 AM
    JDM
    JDM Well-Known Member
    Jimmy
    CO
    2009 DCSB TRD OR S/C
    TRD supercharger, TRD exhaust, skids, sliders
    This. Nothing wrong with that mount.
    BTDT. Have used a turnbuckle setup as well.
    I'm wondering if the noise is the common axle wrap issue with the factory rear leaf springs. The one which produces the noise is the passenger side. You should see the leafs flexing enough to separate, then slapping together once the torque is done (after you've come to a complete stop, etc.).
  10. Aug 13, 2016 at 8:01 AM
    samiam
    Sam
    Stinky Vegas
    I've had Dakars on for a few months. The noise pre-dates installation, but still worth a closer look.
    JDM[QUOTED] likes this.
  11. Aug 14, 2016 at 9:14 AM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    Clunking over bumps sounds like the classic ball-joint failure situation. Had this on my previous ranger. Sounded like shocks slapping with no oil, but wasn't. Sounded like lots of things, but was ball joints.
    samiam[QUOTED][OP] likes this.
  12. Aug 14, 2016 at 9:53 AM
    samiam
    Sam
    Stinky Vegas
    Thanks. Balljoints are on my "short list".
